Question about Kenmore Dishwashers
GE Dishwasher - poor cleaning
A couple of months ago our GE(Sears) dishwasher stopped pumping out the dirty water after washing a load of dishes. We diagnosed the problem as a bad pump and I replaced it. We've had very poor cleaning since changing the pump. I thought maybe my wife wasn't using hot enough water or cheap dishwasher soap, but after a couple of months of very dirty dishes I finally looked into it and found that water enters the tub during the start of the wash cycle but either not enough or its draing out almost as quick as it's going in. The water level doesn't even cover the entire floor of the tub. Spary arms are ok and spray a little it until there is no more water left to spray. Can the water inlet valve be bad in that it doesn't let enough water in? Is it possable for the water to drain out during the wash cycle? Did I maybe not hook something up right when I installed the pump? Could the new pump be bad? Pump p/n WD26X10013
  • Samuel Charles Spriggs May 11, 2010
    It sounds like the pump valving is malfunctioning. It should switch from "pump-out-to-drain" to "pump-up-to-washer" as appropriate. Sounds like the pump is stuck in the pump-to-drain mode. Sounds like the pump wasn't correctly installed -- it's probably anelectromechanical issue. Have you checked the pump installation?
    Habit-Forming:
    New Friend:
  • 23 Answers
I believe there is a screen/filter on the water line before or at the water fill valve. If that gets plugged it can restrict the flow. The fill valve can also fail/get plugged and restrict the flow.
Also, dishwashers usually have a level sensor to tell when there is enough water to do the wash. It may be a float inside the tub that operates a mechanical switch or it may have a hose to a pressure sensor. Either type can get greasy/dirty/plugged and as a result cause improper water levels.
Check both the water supply filter/fill valve and the level sensor. One or both of those may be involved.
Posted on Mar 10, 2017
  • 213 Answers
SOURCE: Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Posted on Nov 20, 2007
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
SOURCE: Water not fully draining during washing dishes. Stays approx 2 inches.
I did check out the Drain Hose. It is not clogged. I also pulled out the dishwasher from the cabinet and replaced the Drain Pump. You mentioned the Drain Valve. How and Where can I check out the Drain Valve??? If I hit Start/Restart twice It drains a little at a time until all the water is drained out. The next and all other times leaves the 2 inches of water in the Dishwasher. Jack
Posted on Apr 23, 2008
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
Upper tray does not wash clean, bottom does
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 10, 2010 | Kenmore 24 in. 15782 / 15784 / 15789...
I have a Whirlpool GU2600XTPS7 dishwasher - long washing time
You could have a couple things going on here. It could be either related to water temperature, build up in the sensor area or poor washing.
If the dishes are coming clean then you can discount the poor washing.
1st thing to try is clean out the dishwasher, a build up or residue can form on the sensors in the bottom and they can be fooled into thinking the water is cloudier or cooler than normal and it would take longer to heat the water and wash. Here is a link to some instructions I put together on how to clean it out.
Clean Out Procedures
2nd thing to try would be to run the hot water in the kitchen sink until it is hot before you start the dishwasher. By doing this the dishwasher will not have to slow down and pause while it is heating the water enough to clean the dishes
May 01, 2010 | Dishwashers
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Dishwasher
Make sure not to prewash your dishes before you put them in the machine. The water needs to be dirty to activate the enzymes in the detergent. Are the dishes coming out cloudy? Also a sign of prewashing your dishes. Use only powder detergent and clean your machine by running 2 cups of vinegar on hottest cycle once a month. No gel and no tabs. They cause a build up in the unit and causes poor performance. Use rinse aid. Hope this helps.
Mar 29, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water not draining and not clean
When dirty water is left in the dishwasher the pump assembly is a primary cause. To assure that the dishwasher gets fully repaired and you are going to do the work yourself, I would order and install this part:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-16529000-%3d%3dc261i1065702&PartID=1065702
Also, check that the heating element is working. Many people replace the heating element whenever they replace the pump/ motor.
Good Luck!
Mar 27, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE Triton XL, Dishwasher, while washing dishes in the sink
Ho could be a blockage in the dishwaser pump, is the drain plug clear .............
Jan 17, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishes not clean
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Apr 04, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dirty dishwasher
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 24, 2007 | GE 24 in. GLD5500L Built-in Dishwasher
Dishwashers Logo
71 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
