Question about Cameras
Flashing triangle and 3123
My camcorder continually flashes a symbol and 3123 which the manual says means high humidity and I should be able to fix myself by drying it out. It's not damp and never has been-HELP Tom Thompson torutom@gmail.com
Damned if the old 'slap it till it works' did it. I guess I'm a camcorder techie now. Thanks,Tom
Posted on May 12, 2009
I have a Sony PDX-10 and it's giving me two blinking yellow symbols (underlinded triangle and tape with line through it) when I fire it up loaded with a tape. Tried changing with tapes that work fine in...
Looking at PDX 10 User Manual Page 232
Your description -
Under lined Triangle
Cassette Ejection needed
Slow Flashing: The Write protect tab exposed
Fast Flashing: Moisture Condensation
Cassette out of tape
Self diagnosis display function activated
Sounds like the diagnosis function maybe your best shot......
Check displayed error codes in viewfinder on Page 231 of the User Manual or let me know if you dont have copy of them.
Tape Symbol Flashing:
Tape near end
No cassette inserted
The write protect tab exposed.
I think this is basically telling you the loading mechanism has a problem, the viewfinder is displaying an error code indicating the nature of the fault..... IF error Code is : E61:........ or E62........ (dots indicate extra numbers) these MUST be referred to Sony Service Centre.
Hope this may help
Ian 561
Jun 24, 2010 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
My printer won't print. (HP P2015dn)
If the triangle is on and the powe light is on too, is a Manual Feed or Continuable Error
This state can be reached in the following circumstances:
Manual feed,
General continuable error
  • Memory configuration error
  • Personality/Job related errorSOLUTION: To recover from the error and print whatever data is possible, press theGo button.If the recovery is successful, the printer goes to the Processing Data state and completes the job.If the recovery is unsuccessful, the printer returns to the Continuable Error state
    another reason is that the cartridge cap may be open or not closed, remove the cartridge and put it again, should work
    If you've put a dimm memory (memory expandable to one side of the printer, remove it and try one more time
    if you did not work, it may be a fan failure the printer, or the engine, or the DC controller, if that is your problem is preferable to contact an authorized hp.
    I have the same machine, it is good quality, and does not give many problems. regards
Apr 05, 2010 | HP LaserJet P2015dn Printer
Flashing red symbol on screen - not 'no cassette loaded' symbol.
I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
Dec 19, 2009 | Canon ZR800 Mini DV Digital Camcorder
Triangle symbol on our printer with a AMBER LIGHT FLASHING?
There is an issue with the media/paper. First thing is to make sure there is paper, and if so, that it's touching the intake rollers. Next is to check for jams, which are usually under the imaging drum. Open the front lid and remove the drum (it's in the front; follow the directions shown on the label on the front right.) Also, check for jams where the paper exits the printer.
Final two things. The lid could be ajar - simply push down firmly to ensure all the contact switches are closed. The last thing is an issue with the fuser, which may require replacing it. I highly recommend getting the service manual from HP, as it is easy to follow and has extensive troubleshooting.
Jul 01, 2009 | HP LaserJet 2550n Printer
Sharp AL-1631 copier. Red flashing triangle no owners manual. Dosn't work. Help
Flashing triangle of dots? for your reference, this is, and always has been, the universal symbol for add toner.
...and here's your manual:
http://www.sharpusa.com/files/cop_man_AL1641CS_1631.pdf
Feb 25, 2009 | Sharp AL 1631 Copier
Code C:31:23 quikly flashing over a underlined triangle...HELP!
Error C:31:23 problem means that System Control is not getting Supply Reel pulse. This can be electronic or mechanical problem in camcorder.
Qualified camera tech will fix it properly.
Feb 22, 2009 | Sony Handycam CCD-TRV318 Camcorder
What does the triangle symbol with small objects in it mean?
It´s the descaling indicator, you need to descale the machine.
Jul 09, 2008 | Schaerer Opal Espresso Machine
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Canon MV550i Mini DV Digital- red flashing symbol
from canon's support page:
This symbol indicates an empty or missing backup battery. The backup battery allows the camcorder to retain date, time and other settings when the main power source is removed.
The flashing symbol is not recorded by the camcorder so you can continue filming without problems.
To stop the flashing symbol remove the old backup battery and replace it with a new one, or recharge the built-in lithium battery if the camcorder has a built-in rechargeable battery.
Note: when the backup battery runs out during filming please do not remove the power supply (battery pack) before the camcorder is powered from a household power source and power adapter, or the user settings and date/time will be reset.
For more detailed information please consult the instruction manual.
Feb 12, 2008 | Canon MV550i Mini DV Digital Camcorder
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
