Question about Breville Coffee Makers & Espresso Machines
My breville bes870xl filter light won't stop flashing single and double. I've unplugged the unit and plugged it back in and turned it on and it still continues to do this.
  • 5 more comments
  • Andrew Josland
    Andrew Josland Sep 27, 2015
    Your grinder is in unlock position. Turn lock button down & lights will go off. Josso
  • Masina Boatwright
    Masina Boatwright Jun 15, 2017
    The year 2017 and your answer is still helping people :) Thank you Andrew.
  • David Darrow Aug 20, 2017
    And if the "Hot Water System" light is flashing, your right-side-upper knob is not in the 12 o'clock position.
  • Stacey Hanks
    Stacey Hanks Dec 31, 2017
    January 2018 and your answer just saved my day!
  • ivan beaupre
    ivan beaupre Jan 29, 2018
    i have the same problem wath is the solution
  • Alessandra Santo
    Alessandra Santo Apr 06, 2018
    Thank you. Your answer made my day!
  • Heather Smith Jun 10, 2018
    thank you Andrew!
    Top Expert:
  • Breville Master
  • 9,098 Answers
PDF]Getting to know your machine - Breville
https://www.brevilleusa.com/media/.../BES860XL.pdf
Translate this page
rested coffee beans produce espresso with much more taste .... filter size you select, and along with the GRIND. AMOUNT dial ...... create steam. When the steam lightstops flashing it is ready .... cappuccino machines is purchased. THE RIGHT ...
Posted on Sep 27, 2015
SOURCE:
SOURCE: Cuisinart programmable espresso maker em-200C
Currently, both my manual and steam button are flashing. No idea why. Any help?
Posted on Feb 29, 2008
SOURCE: Breville expresso filter
Put the coffee filter in the oven (yes the OVEN) and run a auto-clean cycle, it will turn all to hashes. Run a clean water cycle after to clean it.
It may discolor the filter a bit, but this is only cosmetic.
It happened to me because the grinder at the grocery store had trouble without anybody noticing it. It's then I decided to buy my own grinder.
Good luck,
JF
Posted on Oct 17, 2009
SOURCE: Error 2-Unit will not heat or brew. Stopped in
Error message 2 is a result of the water heating element burning out. The element is replaceable, if you can find a vendor who sells the element assembly. Price of a new element may be more that a new pot though, if you're lucky enough to find a parts vendor that sells one.
Posted on Dec 31, 2009
  • 1833 Answers
SOURCE: I've had my Keurig Mini
According to your problem first check the electric outlet where you have plugged your machine and also check the power cord of the machine if there anything loose or voltage tripping. You have to clean the infuser and the brewer first. Make it clean properly and check the settings also. Then clean the spout holes. If it doesn't help you then you have to replace the brewer unit.
Posted on Jun 28, 2011
heatman101
  • 43501 Answers
SOURCE: The display keeps flashing Not Ready. Water is
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Posted on Sep 05, 2011
Clean cycle does not work
Unplug the machine for a minute, and then plug it back in. The Needs Cleaning light will likely stay off!
Jul 20, 2014 | Breville Barista Express Espresso Machine...
How to cancel clean me light
Unplug the machine for a minute or two. The light should go off and stay off.
Hi my breville barista express does not grind the beans, and the "single/double" light is blinking, what is the problem?
My wife tried to make my coffee and long story short, she removed the lid to "move the beans around"..The grinder stopped working and the filter size lights began flashing intermittently. After taking the whole thing apart, the only REAL problem is that the lock mechanism inside the hopper came unlocked. So put your machine back together and "lock" the hopper. The lights will stop flashing...lets hope
Sep 26, 2013 | Breville Die Cast 800ESXL Espresso Machine
I just bout the 870 barista i pulged it and the filter size led keep flashing i cherthe hopper and its properly seated
As it is new I suggest that you contact the store where you bought it - may be simple fix or a fault under warranty. Maybe a small sensor that needs to be contacted by when the filter is in the right position.
Aug 24, 2013 | Breville Barista Express Espresso Machine...
My 1999 Buick Park Ave started hesitating and the CEL would flash. I would back off the accelerator and it would smooth out and the light would go off. About a month ago the car died while I was driving it...
Have you tried the reset method? Turn key to the ON position and leave it there for 10 minutes, or until the security light goes off. Then turn key to off, and back to on and start-see if it starts after letting it sit for a few minutes like that with the key in the on position.
Apr 11, 2017 | 1999 Buick Park Avenue
I have a rennai energysaver 556ftr heater, and the filter and on light keeps flashing red, i've taken out the filter and cleaned it, but still the lights are flashing. what's wrong?
If you removed the filter to clean it, while the unit was ON, that may be the problem. Turn the Master ON/OFF Switch to OFF and unplug the unit from wall outlet. Leave unplugged for 15 minutes. Remove and replace the filter. After 15 minutes has elapsed, plug the unit into the wall outlet and turn the Master ON/OFF Switch to ON. The unit should have reset itself and reverted back to the original factory default settings. In which case, you can change the settings to what you desire.
Just remember to always turn the Master ON/OFF Switch to OFF, when removing the filter to clean and replace it.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Heating & Cooling
My Panasonic SC-HT995W keeps on flashing W and the rear speakers wont work. Ive tried turning off all other wireless devices but it still persists
I had exactly the same problem. My unit worked fine until a loose power cable resulted in the receiver being turned on and off a couple of times in quick succession and then after this the a/c in light on the rear speaker was lit but the wireless link light would not come on (and the 'W' on the main unit flashed constantly). The solution for me was basically a reboot. This is what I did;
- unplug the wireless receiver
- unplug the main unit
- remove the digital transceiver unit from its slot in the back of the main unit
- plug the main unit back in and turn it on - the 'W' won't flash as the transceiver has been removed (not sure if you if it's necessary but I made sure it was producing sound to the front speakers)
- unplug the main unit again
- reinsert the digital transceiver
- plug the main unit back in, turn it on and set it to produce output/sound (the 'W' will be flashing)
- then plug the wireless receiver back in again
...presto the link is made, the 'W' stops flashing and the rear speakers work again.
Hope this elaborate reboot works as well for you as it did for me.
Aug 08, 2010 | Panasonic SC-HT995W System
Feb 27, 2008 | Cuisinart Programmable Espresso Maker
Open Questions:
No water flowing through Breville Infuser Espresso machine during the cleaning cycle Here's the likely answer:Okay, I have a new Breville Infuser espresso machine. I've used it for a few weeks, without many issues, other than getting the grind settings for the amount of coffee and coarseness adjusted the manual for my Breville Smart Grinder Pro, recommended 17.8 seconds of grind time, at the 12 espresso setting, however, the coffee came through VERY SLOWLY, and at too much pressure, at or past the second screw on the dial. I adjust it to 14.8 seconds and setting 20 for coarseness after MANY trials tweaking it, and the pressure now is just shy of the first screw, and produces a very good espresso/lattes. Today, when I turned the machine on, the cleaning/descaling light was flashing, indicating that a cleaning cycle of the brew head should be done. I read the instructions, watched a video, inserted the single cup filter into the portafilter, inserted the cleaning disk with the tab side up, as well as the cleaning tablet, in the round space provided for it. I locked the portafilter into place on the machine, turned on the machine with the water tank full, placed a large bowl under the portafilter because the instructions and online videos showed LOTS of water running through the portafilter/filter/cleaning disk/tablet set up, as the machine went through the cleaning cycle. I simultaneously pressed both the single/double shot buttons, as well as the power button. The machine went into cleaning mode for about 5 minutes, and beeped once the cycle was complete. During the cleaning cycle NO WATER at all, went through the portafilter, NONE! So, I reread the instructions, looked through the trouble shooting pages in the manual, I even looked on Breville's site, there was NOTHING at all on either the problem, or how to fix it. So, I looked online to see if anyone else was having the same problem. And yes, yes there were! However, NOONE gave a complete response, as to what the exact problem was, and how the problem was corrected. Many people online gave suggestions such as try the dual walled single filter, maybe the disk shouldn't be pressed down, etc. None of those suggestions helped. So, I called Breville's online helpline number. The menu of services included one for dealing with drip coffee machines a helpline that could assist 24/7 but specifically stated, for people that own espresso machines, to call back M-F, during regular office hours. Really?! I was going to stay on the line, simply to complain about no service being available, but after 41 minutes of waiting for an agent to help me, I was disconnected, hearing a message to call back later. Again, REALLY?!!! So, I was irritated and called back. Tonya answered, and listened to my concerns, she tried to trouble shoot the problem, and agreed, that I had likely received a cleaning disk, that was probably meant to be packaged with a European version of the machine. Someone here commenting, had said that they called customer service, and was told that European machines do not have water flowing through the portafilter during the cleaning process, but American models, most certainly should have water flowing through the portafilter during cleaning. So, Tonya said that should would ship an American cleaning disk to me one with a hole in it, and also consult with her colleagues on Monday when the espresso experts are there, to make sure that the wrong disk was the problem. I also mentioned how the machine doesn't have water flowing through the brew head very quickly drops kind of dripping at a very moderate rate, and the suggested grinder setting, being way off, as far as having a decent flow during brewing. She also is going to have an espresso machine specialist call me on Monday, to make sure that all of the problems had been addressed and dealt with properly/thoroughly. I should mention, that during the cleaning cyle, where no water flowed through the portafilter, water did collect in the drip tray. Also, the cleaning tablet did dissolve, but remnants of it remained on the cleaning disk. I asked Tonya if running the machine through the clean cycle twice, with no water flowing through, could possibly damage the machine. She said that the machines are designed to self purge, any time that it needs to be cooled down, and that no damage should have occurred. So, for now, it appears that the problem, was receiving a cleaning disk, that did not have a hole in the center, thus no water could go through. Sorry for the LONG reply, but I hope that it is of some help, to anyone else that is having the same problem, take care. UPDATE TO QUESTIONS ABOUT BREVILLE INFUSER: I literally just got off the phone with an espresso expert from Breville. She informed me that the Breville Infuser (and several other models including the Barista) SHOULD now have a SOLID cleaning disc, WITHOUT a hole in it. She said that now, the cleaning process is VERY different than it previously was. The new method is to have the cleaning tablet and solution, dissolve and backflow through the machine, and distribute the cleaning solution into the DRIP TRAY and NOT come out of the portafilter, at all. So, there is no problem with either the machine, or the cleaning disc, they are operating as they are now supposed to. I asked why Breville hadn't made any change to their instruction manuals, online tutorials, or even their website, or any other communication, to inform their customers of the rather significant change. She said that the new procedure has only been around for the last few months, that they are aware of it, and are getting around to making the necessary changes. I asked why they don't take about 5 minutes and get their I-T staff on it, thereby, at least making a change to the instructions on their website, as well as putting this new information into their FAQ area of their website. She got rather defensive, stating how it was a comprehensive change that takes time, and again, they are aware of, and getting around to it. I reminded her, that it's the manufacturer's responsibility to inform and educate their customers, and not the other way around, and that Breville really dropped the ball by not making basic informational changes (via their website instructions, FAQ sections) at the very least. I informed her that there were many people experiencing this same issue, being told by their instruction manual, website and tutorials one thing, when it now should actually be done differently, at least as to where the significant amount of water is to flow during the cleaning process. I also told her, that as a result of this, there was a lot of misinformation being suggested online, as how to correct the "problem", that actually doesn't exist. Also, there have been reports online regarding various and similar issues that people have been having with their products, for years. I reminded her that the only problem, was on Breville's end, by making significant changes to their instructions without informing their customers from the beginning, BEORE they ship such products, so, in that regard, they really dropped the ball. She went on to saying how the internet was a "rabbit hole" where there's lots of misinformation, to which I agreed. But with all the information that's on it, both good and bad, Breville hadn't effectively done anything, either proactive, or even reactive, to correct the misinformation, that they themselves, were responsible for causing. Further, I also informed her, that when I called their customer service number for assistance, virtually all of their other products have assistance 24/7, but specifically state that assistance for their espresso machines, are only available M - F, during regular office hours. Now when I called the number anyway, on a Saturday, mid-afternoon, after being on the line for 42 minutes waiting, I was disconnected. I called back in, got through to customer service, and the lady there was actually very willing to assist me. She admitted that she didn't know all that much about espresso machines, had not ever heard anything about the issues that I brought up, but would do her best to help me. She took down the information/concerns, and passed it along to the espresso team, which got back to me today, Monday morning, which I do appreciate. When I got the call today, I informed their representative that it's very bad form, bad for business actually, to not only NOT have the proper and RELEVANT information available, at least online, but also, of all their various products that they produce and sell, why would they not also provide 24/7 customer service, for their customers that are on average, spending a LOT more than the average customer, as espresso machines are one of their higher end products. She had no decent answer for that, other than to again say that they are working on making the informational changes, to update the procedure/expectations, for how the cleaning process should now work. Again, the lady that helped me initially at customer service, Tonya, was great, the lady that called me back today (I forgot to ask her name), has a lot to say, did call me back in a timely manner, but as far as effectively responding to customer concerns, just doesn't get it. Hopefully that changes soon, take care.
Mar 23, 2019 | Breville Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
6,274 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
superdad1976
Gene Pitts
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
