Question about Emerson MW8777W Microwave Oven
It just stopped working. It's plugged in and the fuse is not blown. Is it broken for good? We haven't had more than 6 months.
  • 718 Answers
Emerson MW8777W
If it stopped working while it was running it is almost certainly the thermal fuse. To see the location go to;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=261105
and click on Cabinet and stirrer in the left-hand side.
This fuse protects the unit from overheating and fires. If the machine is under warranty you can get them to fix it. If not, you can remove the therm fuse and take it to Radio Shack® and get a replacement.
Posted on May 12, 2009
Microwave stopped heating #mv1608bb
Open the back and look for a blown glass tube fuse. If the filament is broken, replace the fuse. If it's a solid fuse, do a continuity test. If you have continuity, then it is still good. Good luck!
Jan 17, 2014 | Goldstar Microwave Ovens
Ge 1235ww microwave went dead..no power,,breaker & plug good
The main fuse in the microwave oven has blown, sometimes replacing it will get it up and running. If it fails again the most likely problem is caused by one or more latch door switches that have encrusted food particles or it has stopped working. Unplug microwave and remove top, "2-6 screws" next look at the right side where the keypad is and look for a silver rectangular capacitor near a circuit board, short a screwdriver across the two points of the capacitor to remove high voltage that may be present, you should see a small fuse that is clipped, remove and replace with same current rating and use extreme caurtsion when power is applied with top off, it can kill.
Mar 01, 2012 | Microwave Ovens
There are condensation, water drips between the glass on the door of my over the counter microwave/convection oven. Is this a problem? How can I clean this? Microwave is only 6 months old.
HELLO.
Yes.Water can only drip between the glass on the door when the door do not seal properly due to dirt on the microwave door.follow these steps given below to clean the door.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
Thanks.
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave just stopped working. No problems until now. In the middle of cooking it just stopped. No display, no beeps, no bouttons working, no light inside. There is power to the outlet I can plug in...
for the microwave to stop suddenly it has blown its internal fuse this is located under the top panel of the unit it should be white with two silver tips ( ceramic fuse) in some cases the fuse will blow for no good reason on the other hand it can be a serious fault the fastest way to check this is to replace the fuse and re test the unit if the fuse blows instantly then bin the microwave if not it the fuse may have simply failed
best of luck always remember unplug the unit first and always replace with same size and and current fuse
please rank this advice if it helped you
Dec 28, 2010 | Kenmore 80402 Microwave Oven
E-Wave over the range microwave has blown main fuse
My Ewave has stopped heating eventho it appears to be running. Is is possible the power has been reduced or does the microwave need to be replaces
Nov 16, 2009 | Microwave Ovens
Stopped working
just had this myself......the problem IS A BLOWN 15 AMP fuse INSIDE the microwave... you must FIRST make sure plug is UNPLUGGED....remove the 3 screws on back maybe 4 ??,,,then lift off the top and side panel...the fuse is located in the red wire behind the start button....GOOD LUCK !!
May 09, 2009 | Emerson MW8777W Microwave Oven
Microwave has no power
HELLO I BELEIVE THAT YOU HAVE A BLOWN FUSE, OPEN THE MICROWAVE AND LOOK FOR A WHITE FUSE, NORMALLY IS ABOUT 250V/15A TRY TO GET THE SAME ONE AT RADIO SHACK
GOOD LUCK
CAYPIANAN@YAHOO.COM
Oct 20, 2008 | Kenmore 80809 Microwave Oven
MICROWAVE WILL NOT HEAT
In my case I found an additional fuse, a high tension fuse (5KV 0.8A) in a white on-line isolation slave next to the transformer.
The fuse was blown.
I guess replacing it should solve the problem.
Oct 07, 2008 | Microwave Ovens
Microwave stopped working
Generally, you get something unless the fuse inside is blown. There is generally a fuse inside the unit when you remove the button package. First, make sure that the outlet you have is good. Plug something else into it and see that it works.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson MW8777W Microwave Oven Logo
424 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
