SOURCE: Wifi Problems with Asus A2500H notebook
Asus A2500H Model Notebook asking for Hard Disk Password
I need the solution for this problem
Email ID: [email protected]
SOURCE: won't connect to wireless internet
Try re-installing the hardware. Your drivers may be currupt. It could also be that the wireless card is not detecting a strong enough signal to connect, try searching for other connections. If the problem presists. It may be a hardware malfunction. In that case you'll need to replace the wireless adaptor. If you still cannot connect, contact your local PC repair shop.
SOURCE: My asus Eee pc 4g 701 will not connect wireless
yes! when it comes to wireless networking just make sure that your connection setting are correct just match the settings from your other laptops and do the same to the one you have probles if the persist just do a diognistic check for problems if that doesnt works just hit me back on my link ok!
SOURCE: asus eee pc 4g wont connect to internet with
Can you connect through a "wired" connection? Is your router connected to the Internet? If you're using wireless encryption, have you told your netbook what that encryption key is?
SOURCE: Asus PC 900 HD wifi connection failed?
click f2. if that doesnt work then
go to start and go to control panel,
then click on internet options, click on the advanced tab, and click reset, there you will find connectivity or internet or something, click on the cross which brings more info up, it should bring up atheos ethernet, and atheos wireless, delete/uninstall them both. then try to connect again.. should work.
