Back to:
Tags:
Corona 23-DK Compact Heater
Change the wick (by 6 users)
posted by hanfoo on Oct 13, 2007
How do I change the wick
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by Guest, posted on Nov 09, 2008
how do i change the wick
Comment by eridon, posted on Oct 09, 2008
I have a Corona DK 23 kerosene heater. I changed the wick; it is perfectly smooth and goes up and down fine, but it is too low for the coil to light it. I disassembled the heater, down to the wick assembly to see if I did anything wrong when I inserted it. But it doesn't seem like I did.  There must be some kind of way to adjust this but I can't find it. If there is an adjustment screw, I don't know where it is.
Comment by Guest, posted on Feb 24, 2008
HOW TO CHANGE WICK
Comment by Guest, posted on Dec 18, 2007
how do you change the wick of a corona 23-DK kerosene heater?
Comment by KETWET, posted on Nov 07, 2007
I have a dyna glo kerosene heater and the fire wont stay lit. After about a minute it goes out. Do I need to change the wick. If so how do I do it?
Best Solution
posted on Sep 14, 2008
FixYa! (100)
garjame
Rank:Apprentice Apprentice
Rating: 100%, 9 votes
how do i change a wick on a corona kerosene heater. model 23dk
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on change the wick:
I don't want to Accept this solution
Solution #2
posted on Dec 06, 2007
FixYa! (100)
pjmma
Rating: 92%, 6 votes
Do yourself a favor and check out the Wick Shop at milesstair.com.
Lots of great info on Kerosene Heaters.
Thank You!
Solution #3
posted on Nov 08, 2007
Helpful (85)
catman526
Rating: 89%, 8 votes
Sounds like a wick problem. If you search kerosene heater on ask.com there are a couple of links with wick replacement instructions. One thing they don't tell you is that you have to be carefull to leave enough slack between the adjustable part of the wick holder and the stationary part. It's a little tricky but be patient. Be sure you work on an empty heater to ease the frustration.
Thank You!
Solution #4
posted on Nov 17, 2008
Not Rated (0)
lisaransbott
Rating: 0%, 0 votes
I have a kerosene heater that is being lite for the first time this year, and it has a heavy black smoke. Any suggestions would be greatly appreciated. How often do change the wick?
Thank You!
Solution #5
posted on Jan 20, 2008
Not Rated (0)
JCMATT
Rating: 0%, 0 votes
I have a Dyna Glo heater with a pined wick. I have disassembled the unit, cleaned the tank replaced the wick, but on testing the wick movement before complete reassembly..it will not budge when I turn the knob. It moves freely until I put it on the tube. I have tried several times with no change. I am certain it has to do with the pins but not sure what.
Thank You!
Can you Help with these Heaters problems?
Heaters
We have a presto dish heater with footlight. I think we...
Heaters
I have broken the ignitor switch off the heater, could you...
corona 23 dk is hard to **** down
I actually have a Dyna-Glo RMC 95 heater. Just changed the...
I just put in a new wick, and new batteries. The coil...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
