Question about LG 42LC2D 42 in. LCD HDTV
No signal i have no manual for my tv and im trying to hook up my satelite to my tv what settings should my tv be on when i have the menu screen up
  • 55 Answers
Satellite usually comes in on channel 3 or 4. If you cant get it, you can also use av in on line one or two.
Posted on May 11, 2009
How to connect to HDMI
newer tvs need to know that HDMI is attached to give you signal also need to turn on device from where HDMI signal comes from.post the model of your tv ,or if universal remote has input try this,1.- connect hdmi ,2.- turn on device(dvd,ps3,blue ray, etc.) 3.- press input on remote ,or go to menu manually on tv and find input.hope it works.
Dec 14, 2013 | Televison & Video
My sanyo modle DS20424 has sound but not picture. We have DISH and their info shows up on the tv when the satelite is on, just no picture. Help??
I would first see if set works with a DVD etc directly hooked to one of the rear audio/video inputs.
If so I would next unplug the dish box and wait and then power it up again to see if it will reboot and cure this issue--you can also contact them....
If getting the on screen Menu but nothing else it is either a signal issue or a problem in the set---If using a receiver also reboot it as well.
May 21, 2012 | Sanyo Televison & Video
Keep getting no signal on 32 in lg
Start at the beginning:
Hook a DVD to one of the rear sets of audio/video jacks--go to that input and verify it works.
If so, hook the direct TV to another rear input and select that---if no picture that way---the box may be the issue or wrong hookup--composite to composite or component to component (most likely).
If the set works with DVD and not DIRECT TV it is not smart enough to know what is hooked to it.
In that case a setting or the connection out from the box is the problem---check on screen menu for the box in setup.
Box may need to be rebooted with it connected to set or wrong hookup of cables.
Mar 31, 2012 | Televison & Video
Cannot lose close captions from screen even though it has been turned off at the menu. Any suggestions?
Check the caption settings in the menu for your video source, (cable box or satelite reciever), the signal could be originating there.
Dec 04, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
How to connect Panasonic Plasma tv with satelite hookup to playstation 2
U can't hook the satelite signal to the PLaystation 2.The satelite hook up to the main in the Antana input.The playstation 2 must use the RCA cable came with the Playstation 2 hook up in any Audio,Video in put in the the tv.Tune in what input u hook up like 1,2,3,extra..use ur Playstation 2.
Aug 25, 2009 | Panasonic Viera TH-50PX80U Plasma TV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
No signal
LOOK N THE MAIN MENU ON THE SATELITE CONVERTER BOX LOCATE WHAT CHANNEL TV IS PROGRAMMED TOO TUNE TV TO THAT CHANNEL WILL EITHER WORK ON AIR OR CABLE
Dec 13, 2008 | Televison & Video
No signal when hooking up to dish network.
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
Dec 11, 2008 | Polaroid FLM-323B Television
Volume won't work in satelite mode
A few possibilities - try volume + on satellite box itself/reset satellite box
Are you using coax or RGB cables? unplug and replug composite or component audio cables if using those
Aug 19, 2007 | Hitachi 51F59 51" HDTV Projection...
LG 42LC2D 42 in. LCD HDTV Logo
62 people viewed this question
Computer Repairing
Computer Repairing
