Question about Sansui HDLCD-2600 26 in. LCD Television
Cannot see computer through vga- connected cable and keep getting "no signal or not supported" message
  • 192 Answers
Your computer may be sending out a signal that too high of a resolution for the TV to display. Try reducing the resolution of the computer video signal.
Posted on May 14, 2009
2 Suggested Answers
SOURCE: no pc signal..help
checked the connection. Make sure you set your tv as video 1 or 2. If has no signal still,checked the cable...use right cable
Posted on May 20, 2009
I connected my 32" Funai LCD TV to PC CPU with VGA cable. I could watch the movie once. However, not able to get the connection again. TV gives message "Not Support". Do i have to change the settings
Make sure your VGA chord is connected to both TV and Computer. Right click on your desktop and go to screen resolutions. Click on Connect to a Projector and click the Duplicate icon.
Jan 29, 2013 | Televison & Video
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
well why not test it on another system
DT or LT
desk top or laptop.
why connect 2 data cables at once, this is SO wrong.
only 1 at a time.
Mar 09, 2017 | HP LP2065 Monitor
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
My DVI has no signal but my VGA does! what do i do? Please help me!!!
Your HP2009M monitor supports (3) methods of accepting signals from a computer. They are: 1) VGA, 2) DVI and, 3) HDMI.
You would connect the computer to the monitor using one connection only. Generally the VGA is the least desirable as it is an analog signal. The DVI and HDMI method provide digital paths into the monitor and often perform better. Your computer may only offer 1 or 2 connection choices, so you'll have to choose a cable type that is supported by both the computer and the monitor. The HDMI choice will pass audio signals to the the speakers in the monitor without needing to run a second cable between the stereo audio jack of the computer and the audio input jack of the monitor (located next to the HDMI jack) or to a set of external speakers (unless of course you prefer the external speakers).
The message you're seeing is normal. Once the monitor is connected to your computer, there will only be one active selection; VGA, DVI or HDMI. Since you're using the analog VGA jacks and cable, it is expected that you'll see a message that there is no signal present on the DVI (and HDMI) inputs when attempting to view signals on other inputs.
I hope this helps and good luck! Please rate my reply, thank you.
Feb 26, 2011 | HP 2009M Monitor
Hi, I am trying to connect my laptop to my TV using VGA (MALE) to VGA (MALE) cable. I am able to see black lines on the TV with noise.How can i correct this ?
You didn't say, is the TV HDTV??
From Windows help menu, press F1, type in "VGA connection" I found this:
Why can't I hear audio when I connect my computer to an HDTV?
VGA, DVI, and component video cables do not support audio signals. HDMI cables do support audio signals, but not all HDMI-enabled video cards support audio. If your HDTV has an audio input, you might be able to connect a separate audio cable from your computer's sound card directly to the TV. Otherwise, you'll need to connect the audio signal to a different output device, such as external computer speakers or your home stereo system. For more information about sound cards, see Sound cards: frequently asked questions.
From Wikipedia.org search VGA connection:
1.
Video Graphics Array (VGA) refers specifically to the display hardware first introduced with the IBM PS/2 line of computers in 1987,[1] but through its widespread adoption has also come to mean either an analog computer display standard, the 15-pin D-subminiature VGA connector or the 640×480 resolution itself. While this resolution was superseded in the personal computer market in the 1990s, it is becoming a popular resolution on mobile devices.[2]
VGA was the last graphical standard introduced by IBM that the majority of PC clone manufacturers conformed to, making it today (as of 2010[update]) the lowest common denominator that all PC graphics hardware can be expected to implement without device-specific driver software.[citation needed] For example, the Microsoft Windows splash screen appears while the machine is still operating in VGA mode, which is the reason that this screen always appears in reduced resolution and color depth.
VGA was officially superseded by IBM's Extended Graphics Array (XGA) standard, but in reality it was superseded by numerous slightly different extensions to VGA made by clone manufacturers that came to be known collectively as Super VGA.
2.
The same VGA cable can be used with a variety of supported VGA resolutions, ranging from 640x400px @70 Hz (24 MHz of signal bandwidth) to 1280x1024px @85 Hz (160 MHz) and up to 2048x1536px @85 Hz (388 MHz). There are no standards defining the quality required for each resolution, but higher-quality cables typically contain coaxial wiring and insulation which make them thicker. A quality cable should not suffer from signal crosstalk which occurs when the signals in one wire induce unwanted currents in adjacent wires, ghosting which occurs when impedance mismatches cause signals to be reflected (note that ghosting with long cables may not be the fault of the cable but may instead be caused by equipment with incorrect termination or by use of passive splitters), and other signal degradation effects; shorter VGA cables are less likely to introduce significant degradation. Some higher-end monitors and video cards featured 5 separate BNC connectors for RGBHV signal, allowing highest quality connection using five 75 Ohm coaxial cables.
I hope this helps, I find the sales reps at Best Buy very helpful.
Dec 04, 2010 | Computers & Internet
Monitor not connecting to tower. it is plug in to the tower. but shows that it is not connected.
three things can be the issue here:
1. No signal from the tower (VIDEO CARD)
2. Bad cable or bent pin on the d-sub 9-15 pin vga connector.
3. Bad signal board inside the monitor itself.
Things to try:
1. another computer.
2. check the signal cable for bent pins.
3. check the video card in the tower.
Before you "think its a bad monitor" you always want to assume the computer first as computers are 9 times out of 10 why the monitor is not coming on such as BIOS errors, Bad video card, bad power supply etc etc.
PLEASE BE CONSIDERATE! When rating and leaving positive feedback for your free answer today.
May 27, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
An Out of range box
frankr2327
If you are getting this message this means that you are connecting a device to the monitor and/or a connection that is putting out a signal that is not supported but the monitor. You may also need to look at the cable you are using. Example I have an XBOX 360 with the official VGA cable when I use it to connect to my monitor it works fine. However I have been testing cables to get a setup for my PS3 as I have not been able find an Official one from Sony. So when I connect my RBG to VGA cable to the end of my RGB XBOX cable then to my monitor I get an Out of Range message. So something with the cable is case a problem with the signal to not to be sent properly.
Note with monitors they have a safety feature that they would turn off if they got a signal they did not properly support and/or not read properly. This has always been there they just not got where they would show you a message. Plus with monitors getting bigger they have stopped supporting lower resolutions so you may see this issue more often when hooking up older devices. I my self still have a 15 and 17 inch on my work bench for toubleshooting.
Hope this helps clarify things. Feel free to reply back with what device you are having trouble with.
Issken
Dec 30, 2009 | Envision Computers & Internet
No pc signal..help
May 20, 2009 | Televison & Video
Sansui HDLCD-2600 26 in. LCD Television Logo
245 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
