Question about Canon FAXPHONE L80 Laser
How do you print on legal paper from memory?
We have a fax sent on legal paper how do we print it from memory?
You have sent a fax? Or you have received a fax.
If you have sent it, it's gone and can't be printed.
If you have received it, then you obviously have to put legal paper in the tray, and program the paper size in your system settings to tell the machine it is Legal paper in the tray. However, once again, if it has already printed the fax (likely on 2 pages) then it's gone from memory and can't be re-printed.
Posted on May 12, 2009
How do i retreive and receive faxes? My machine has recieved material in memory, yet when i try to print them, the alarm rings after first page and display reads "CHECK PAGE SIZE, press OK" It will re
If you are able to print normally from this model, despite the 'stuck' faxes, then it could be that you have been sent a document that is not the same size as that in your tray. Try cutting A4, if that is what you have, down to 'legal' and see if will move on to next page. If this works, cut some more and print job till finished.
If the above makes no difference, you may have to do a memory reset to clear a corrupt fax record. Caution! this would clear all faxes queued in your machine.
Dec 16, 2014 | Canon PIXMA MX340 Inkjet Multifunction...
How do I clear the in use alarm on a canon mx340 printer?
The in use alarm appears to be related to fax reception and printing. There are some options below that you could try:-
Memory Reception If the machine receives a fax under one of the following conditions, it will not be able to print the received fax and will store it in its memory. The In Use/Memory lamp is lit and Received in memory is displayed on the LCD. When the problem is resolved as described, the fax stored in memory is printed automatically.
  • Ink has run out: Replace the FINE Cartridge.
    i_green_arrow.gifRoutine Maintenance
    i_note_e.gifNote
    • You can set the machine to forcibly print a received fax even if the ink has run out.
      However, part or all of the fax may not be printed since the ink has run out.
      Also, the contents of the fax will not be stored in memory.
      If the ink has already run out, we recommend that OFF be selected for Auto print in FAX user settings to store the received fax in memory and print the fax manually after replacing the FINE Cartridge. After you replace the FINE Cartridge and select ON for Auto print, the fax stored in memory will be printed automatically.
  • Paper has run out: Load the paper and press the OK button.
  • A different size of paper from that specified by Page size is loaded:
    Load the same size of paper as that specified by Page size, then press the OK button.
  • Page size is set to other than A4, 8.5"x11"(LTR), or Legal (or 8.5"x14"):
    Set Page size to A4, 8.5"x11"(LTR), or Legal (or 8.5"x14").
  • Media type is set to other than Plain paper:
    Set Media type to Plain paper.
  • You pressed the Stop button to cancel printing of a fax:
    Press the FAX button
Alternatively turn the printer off, open the devices and printers section of Control Panel, right click on your printer and select "see what's printing" and left click on this. A window will pop up which may or may not contain a list of documents. If it does these must be cancelled (Menu - Printer - Cancel all documents). Once all documents have gone from the list turn the printer on and try to print.
Other than the above suggestions I would need to know more about your OS and exact problem. Hope this helps.
Aug 06, 2014 | Canon PIXMA MX340 Wireless Office...
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
Sep 21, 2011 | Canon Office Equipment & Supplies
We have a Canon Faxphone L170. Someone sent a fax
On the controll panel there is a diamond shape picture with a eye in it.press that bottom and clear the fax that you received.There is no other way.You will have to phone the sender and ask them to change the papersize settings on the fax machine.
Dec 08, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Canon Laser Class 3175 facsimile, incoming faxes are being saved in memory, will not print. Cannot clear error message "check paper size".
The problem is that you have a fax saved in memory that is the wrong size for the paper you have in the drawer. Probably it is a legal size, whereas you have letter size in the drawer.Just place some legal size paper in the by-pass tray to print.
May 11, 2008 | Office Equipment & Supplies
Faxes being sent but stuck in memory, How do I Print them out?
Printing Documents in Memory: From B640 Manual
Except when you run out of paper, the faxphone will automatically print out the contents in memory when you remedy the cause of the problem.
If running out of memory caused memory reception, adding recording paper and press {STOP} to begin printing the stored page(s).
After printing the page(s) in memory the faxphone erases the documents from memory.
Jan 19, 2008 | Canon FAXPHONE B640 Plain Paper Bubblejet
Incorrect paper size
You may have a fax in memory that requires a larger size. Try putting legal in the tray and see if it prints out anything. Also, look in the set up menu to see if there is an "auto reduction" mode. That will make any over sized incoming faxes automatically print out on the size paper you have in the tray.
Nov 17, 2007 | Canon FAX-L380 Plain Paper Laser
Canon FAXPHONE L80 Laser Logo
145 people viewed this question
old marine
old marine
