Question about FireLite (USBFLB80) Hard Drive
Smartdisk Firelite model USBFLB40-c - not recognising - stored data recovery
Dell Inspiron 2650 - os Windows xp - The above external hdd is not recognised when connected to the port. Data from the disk has to be recovered. The light flashes in the disk but not steady. This problem cropped up after the hdd is vacum cleaned when small red ants entered the disk. Prior to that there was no problem with the disk and its function. The data is important for me and has to be recovered.
  • Sarmad59 Jan 18, 2008
    the drive can not be recognized by the USB port and flashes 6 times contineously. I need help retreiving the data on the drive please.
    Novelist:
    Champion:
  • 382 Answers
Most likely the vacuum and not the ants. The vacuum could have given it a dangerous charge or vibration. You may need to extract the drive from the enclosure. It possible ( hopefully) that the enclosures bridge board failed instead of the drive. When you extract the drive, you will see....its construction is made well, and can stand up to crittters..
keep me posted.
Posted on Oct 28, 2007
I need to locate a mother board for a firelite model #USBFLB40-C any suggestion? Or where can I get a new USB power data plug soldered on the old board? Thank you.
Yes I would take the Harddrive out of the SmartDisk FireLite external harddrive, and install it into an economical external enclosure.
Looking up reviews just now I know that it's a laptop sized harddrive that's inside.
(The Harddrive inside is 2.5 inches across in width. 2-1/2 inches)
I don't know however if it is an IDE or SATA unit.
But you will know once you get the case open, and view the Harddrive inside.
One example of a 2.5 IDE external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1086960&CatId=2782
One example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
One example of an external enclosure that will support IDE or SATA harddrives that are 2.5,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Regards,
joecoolvette
Jul 04, 2011 | SmartDisk FireLite 40 GB Hard Drive
I have a SmartDisk FireLite Model Number USBFLB40-C. I took it to some local data recovery specialists, but I think they said the motor was out. They said I'd have to send it into the company. However,...
After a quick check, it seems as if SmartDisk have disappeared off the face of the earth (or at least the internet). Strange. I did find the following phone number (which you may have also found in your search), it might be worth trying that if you haven't already (note I have not checked it myself, so no idea if it still works):
01252 530960
Note also this is a UK number (I can't find a US one). To be quite honest, I doubt this will work.
If that doesn't work, then I'm afraid there's not a lot you can do yourself if its the motor that has broken. The next move would be to take it back to the recovery specialists, explain your situation, and see if they can recommend anyone who might be able to replace the motor (if they won't do it themselves).
By the way, thanks for clearly wording your question, it makes life a lot easier when people do that.
May 31, 2011 | SmartDisk FireLite 40 GB Hard Drive
My external firelite model #USBFLB40, stop work today, i tried in other laptoop, and its work but after i disconnect, i want to used it again, and dosent work, ether my lap, nether the other lap... ...
1. It may be due to the electronics in the USB case.
You can purchase a new case and install the hard drive and connect to the USB port to your laptop/PC.
If the drive is not seen after this then the drive itself may be damaged.
If you disconnected the USB drive without "safely removing it in Windows it may have damaged the hard drive controller.
Mar 18, 2011 | SmartDisk FireLite 40 GB Hard Drive
How do I open a smartdisk firelite model # USBFLB40
Go ti My computer icon, right click on it and click on explore. Should be show your new drive. If this is the case, right click the new HD in click on explore to see what is in there. My PC Doctor NJ
Mar 26, 2010 | FireLite (USBFLB80) Hard Drive
I have a firelite smartdisk portable hard drive usbflb40. I need th driver for it. Where can I down load it. Thanks
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/SmartDisk-FireLite-Driver.shtml
there you go!
Feb 25, 2010 | FireLite (USBFLB80) Hard Drive
External hard drive not recognized
where can i find the software for my smartdisk firelite 160gb
Dec 18, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
New computer won't recognize my Firelite, works on old computer
You need drivers for USB, if you remember when you bought smartdisk you got the installation disc, that you now need for a new computer.
Oct 31, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
External hard drive does not display icon in My Computer
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Mar 03, 2009 | Verbatim 160GB USB FireLite: The "drive...
Won't recognize on windows XP(SP3)
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
Aug 10, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Smartdisk firelite
please use a recovery program for mac and then once all files are recovered then repartion hdd in disk utility then copy back all files to hard drive or change your external drive as you are the fourth person to have this problem with firelite hard drive for the mac sounds like a compatabilly issue with mac os systems
Jun 01, 2007 | SmartDisk FireLite 40 GB Hard Drive
FireLite (USBFLB80) Hard Drive Logo
1,185 people viewed this question
Top FireLite Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a FireLite Computer and Internet Expert? Answer questions, earn points and help others
