Question about Conair Health & Beauty
Can't snap on blade for dog clippers
I have just gotten a pair of conair pro 2 speed dog clippers with snap on blades. Thought the snap ons would be easier-not for me. Was able to change them 3 times and took it off to clean and cannot get back on, I've tried for 3 weeks now and the clippers work wonderfully, but I'm ready to throw them out. Please help! Joann
  • ajjl76_2 May 13, 2009
    Thanks so much, I'll try that. And thanks for the advice on the best clippers, appreciate it. Joann
Not sure why they won't go back on unless the clip has collapsed in which case you would need to take a screwdriver and pop it back up. Andis and Osters are the best clippers out there however.
Posted on May 13, 2009
Can I swap sharp cutting blade from one size blade to another?
Well you can either buy a new one from a local shop
http://www.angliaclipperservices.com/dog
Or wait a while and send them off for sharpening
http://www.angliaclipperservices.com/Clipper_Sharpening
May 26, 2016 | Andis Dog Clippers - AGP Super 2-Speed...
Why won't blades stay aligned?
Ok either the 2 screws that hold the blade to the clipper are loose or the adjusting lever on the side could be loose please check both.
P.S you must align blade before you tighten the screws.
Anglia Clipper Services professional dog grooming equipment
Aug 25, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
How do I change the blade?
There is a small button at the bottom edge of the blade, push it in and at the same time push the blade teeth away from the clipper. The blade will hinge away from the clipper, you then lift the blade up off the tongue. When fitting another blade pop it onto the tongue, turn the clipper on and snap the blade shut.
Mar 31, 2015 | Oster Turbo A5 2-speed Dog Pet Clipper...
My clippers are pulling the dog hair instead of cutting, why?
Most common cause will be the blades have gone dull and should be sharpened or replaced. Check that the 2 screws on the blade latch assy are tight where it screws onto the front housing, blade off to check them. 3rd thing to check is for excessive wear in the lever that drives the blades, if it is worn replace it.
Nov 24, 2012 | Wahl KM2 Speed Electric Clipper: Two Speed...
Andis clippers are shaking and loud
sometimes it is the blade and not the clipper
Jun 20, 2012 | Andis Agc Super 2-speed Clipper...
Blades fell off oster dog clippers but can't fit them back on. Please help !!
With the hinge of the clipper facing you:
Make sure hinge is open, if it is not, prize it open with a flat head screwdriver.
Slide the blade on with the blade siz/number faceing you.
Snap shut.
If this fails, try again, but push the latch in as you snap them shut.
If this fails, you may need repair!
www.sheareaseltd.com
May 15, 2010 | Oster Golden A5 2-Speed Universal Motor...
A5 dog clipper or blades may need tune up or
some times the link and gear inside the front part of the clipper wears out and the blades just wont cut. try this, remove the clipper blade on the front of the clipper their is a lever color red grab this part with your 2 fingers and move it side to side if it moves and feel sloppy your gears and link are worn out. you need to replace, also check the hinge for spring tension. if you need help Contact mannyssharpening@yahoo.com
Feb 22, 2010 | Oster Golden A5 2-Speed Universal Motor...
Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Andis pm-3 dog clipper won't cut anymore!
I have had this same problem!  I bought new blades, sharpened old ones, and nothing worked.  Finally, I went to an authorized service center and they couldn't figure it out.  Then the tech. pressed on the blade (the outside bottom one) and it cut!  When you remove the blades with the 2 big screws, there are 2 more smaller screws inside under the smaller blade.  One of those was not screwed in tightly.  That was all it was!  I guess they jiggle loose.  I hope this helps!
peony
Mar 02, 2009 | Andis ProMotor PM-3 Hair Trimmer
Putting blade back on my Andis dog clipper
It sounds like you may have a bent hinge which is what the blade slides onto. Please call Andis customer service at 1-800-558-9441 to speak with a customer service rep. They can give you instructions on where to purchase a new hinge or send or clippers in for repair.
Thank you,
Jun 17, 2008 | Andis 29745 Clipper Headliner Hair Trimmer
Health & Beauty Logo
453 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
