Question about Nintendo DS Console
Displays "no game pack inserted"
When a game is securely in the ds, it still reads this...if tyou take the battery pack out and put it back in it works for a couple of minutes and does this again...all games are gone, nothing is saved
  • 1 more comment
  • trudisail1 Nov 12, 2007
    does the ds play game boy games it says no game pack in it. what is the small hole in the back becase it says no ds card inserted. i baught it off of ebay and it didn't come with the book.
  • adacatdog Nov 20, 2007
    Same thing all ds games not recognized when inserted.
  • w6j6vp1 Mar 15, 2008
    M3 DS simply card not recognised, eventhough it works on another console
Take the game out then blow really hard into the game slot. Re-insert game - it should work :-)
Posted on Apr 24, 2009
  • 52 Answers
Clean the game pack and clean the game reader with compressed air (low pressure)
Posted on Mar 17, 2008
3 ds will not turn on
1. Make sure the battery pack is charged: Connect the 3DS to your charge cable or place it on the cradle. Make sure that the battery is charging. (Indicated by the orange light on the front. Even if the battery is fully charged, this light will come on briefly and then turn off.)
2. Press and power button and make sure the blue power light turns on. If this light turns on but you do not get any picture or sound, you may want to consider sending your system in for repair.
3. Make sure any DS or 3DS game card inserted is properly inserted into the game card slot. The game card should be inserted with the label facing out and then pushed into the slot until it clicks into place.
4. Check that the battery has been inserted properly. Unscrew the back panel of the unit, remove the battery and reinsert it, making sure that the contacts on the battery match up with the contacts on the system. The battery should be inserted so that the "positive" (+) and "negative" (-) icons on the battery are facing up. CAUTION: There was a known glitch in the system at launch that prevented players from tagging other systems that they've already tagged if the battery is removed for a certain period of time.
If none of the above works, you may need to send the system in for repair. Check Nintendo's support site for repair information.
Read more: http://wiki.answers.com/Q/How_do_you_troubleshoot_a_3DS_that_won't_turn_on#ixzz274f71pEg
Sep 21, 2012 | Nintendo 3ds Handheld Game Console- Cosmo...
Tip
How to reset Nintendo DS Lite.
Remove the cover for the battery compartment. At the back of the DS Lite, the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not cause a reset in the unit.
Put the battery pack back. Just line it up in the compartment and push it back into place.
Replace the cover. Replace with the screw.
Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
on Feb 12, 2010 | Computers & Internet
How to reset your nintendo DS
Hi. Here's the procedure on how to reset the console. Take note that if you are going to do this procedure this will erase all of the data saved on the system and restore the unit to its original factory settings.
Remove the cover for the battery compartment. The compartment is located on the back of the DS Lite unit, and the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
  • 2 Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
  • 3 Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not reset the unit.
  • 4 Put the battery pack back into the unit. Just line it up in the compartment and push it back into place.
  • 5 Replace the cover. Secure the cover back into place with the screw.
  • 6 Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all-new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
  • Sep 12, 2010 | Nintendo DS Console
    I want ot sell ds i want to no how to wipe the whole thing
    Remove the cover for the battery compartment. The compartment is located on the back of the DS Lite unit and the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
    http://vodpod.com/watch/2607802-nintendo-ds-lite-reset
    Mar 16, 2010 | Nintendo DS Lite Console
    How do you restart nintendogs
    No No No! Bad Silver! Before You See The Nintendo Sign (It may be after) Press and Hold A +B + X + Y + L Trigger + R Trigger and that's all. Taking Apart Your DS gives you a 99% Chance of epic fail. -_-
    Feb 12, 2010 | Nintendo DS Lite
    No ds game inserted
    okay all you will need to do is un skrew the back and where the battery is there is this hole and you will need to take a q-tip and put some water with some dish cleaner and put the q-tip in the hole and move it around and it will work just fine...
    Jun 02, 2009 | Nintendo DS Lite Console
    No ds game inserted
    it is a very common problem with the nintend DS console, its to do with dust or dirt being trapped between the connectors that the game cartridge connect too. make sure that this is clean, properly, (not by just blowing into it) my advice is to use a DRY cotton bud or something allong those lines.....hope this helps, if it doesnt get back to me
    Jun 01, 2009 | Nintendo DS Lite Console
    Message reads no ds card inserted even though there is a card present in slot
    well if thats the problematic case,
    if it says no game inserted and theres a game in the slot,
    this reallt worked
    1 turn the ds off
    2 take out the ds game
    3 turn on the ds(remeber the game is out of the slot)
    4 turn off the ds
    5 carefully blow on the ds game all around
    6 then blow in the slot were the ds game goes.
    7 now put the ds game back into the slot.
    8 now finaly trun on the ds and it should say theres a game in the slot
    Apr 04, 2009 | Nintendo DS Lite
    Fire card read ''there is no ds card inserted''
    the ds is set to not work on illegal games /items
    Mar 14, 2009 | Nintendo DS Lite Console
    Nintendo DS Console Logo
    702 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Zhenya Ogorodnikov
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
