Error 32 message on pc start up - Computers & Internet
  • 20 Answers
Is this a windows error? DOS error? what is the complete message if you can boot to safe mode (after knowing the exact error) try replacing the INI file that gave you the error... go to search find type in the exact name then find it and replace that file from one you pulled off of a working computer using the same method ... both comps should have the same OS
Posted on May 11, 2009
    President:
  • 2,653 Answers
Try booting into safe mode.
Press F8 every few seconds after you start the computer.
Let us know what happens.
2 Suggested Answers
MrDallasIT
  • 91 Answers
SOURCE: error 32 message on pc when starting up
I would recommend your perform a system restore!!! You file system is definitely corrupt... If you have accidentally deleted any crucial files in the system 32 that is need during the POST, this will fix it it. It will revert back to the original settings the way it was before the issue happened. After you get past the POST and log into windows, run Malware Bytes software ( its a free download from Cnet.com, Trial version) And it will detect any viruses that may be responsible as well!! It has an excellent rating too!!!
Problem with windows 8 pro 32 bit: Fatal error couldn't create device directX error message: dderr_unsupported project igi i m going in
not sure if this question is about windows XP or windows 8.
sound as if directx/java was not installed correctly or not enough memory.
how many times has this happened? if more than one i would reinstall.
good luck
Dec 11, 2013 | Microsoft Windows XP Professional With...
Error No. 32
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details Hope it helps.
Jan 09, 2013 | Microsoft Windows XP Professional
Windows cannot connect to printer. Operation failed with error 0x0000007e.
This problem happens when you are trying to share printer between 32 bit (x86) and 64 bit (x64) Windows. The 32 bit driver not compatible for 64 bit operating system. At this situation you may get error message like this "Windows cannot connect to the printer Operation failed with error 0x0000007e".
But there is an alternate way to add printer from 32 bit Windows to 64 bit Windows.
Start >> Devices and Printers >>
Then Add Printer with the help of IP address of 32 bit Windows computer.
Detailed steps with screen shots are given in the following link.
[Solved] Operation failed with error 0x0000007e
Solved Operation failed with error 0x0000007e Share printer between 32...
Apr 11, 2012 | Xerox Office Equipment & Supplies
Cannot start cp message system32 is missing is there an easy fix
use your cd windows to make system recovery or you can connect your hard disk to other same operating system pc then copy your windos fail and do a scandisk on your hdd
Mar 09, 2012 | Gateway MX Computers & Internet
Hi I am Farah, and as I wanted to download java , it came thet" " is not valid win 32 application'. What shoudl I do? Thx
It is possible that you are attempting to install a 64-bit version of Java when you have a 32-bit operating system. Check your operating and confirm this. In Vista you can find this using Start > Control Panel > System. This is similar if you have Windows 7. Here is what it looks like:
If after that you, you follow these instructions from Sun (Java) to locate and install the 32-bit version.
Error: x64.exe not a valid Win32 application This article applies to:
  • Platform(s): Windows 7, Vista, Windows XP, Windows 2000, Windows 2003
  • Browser(s): Internet Explorer, Firefox, Mozilla 1.4+
  • Java version(s): 6.0
SYMPTOMS
While trying to install Java a user gets an error message similar to:
' ... x64.exe not a valid Win32 application'
CAUSE
The error message is a result of trying to install a 64-bit version of Java on a 32-bit operating system.
SOLUTION
User needs to install a 32-bit version of Java software, since a 64-bit version is not compatible with their 32-bit operating system.
Follow these steps to download 32-bit Java
  1. Go to Manual download
  2. Click Windows XP/Vista/2000/2003/2008 Online.
  3. The File Download dialog box appears.
  4. Choose the folder location.
  5. (Save the file to a known location on your computer, for example, to your desktop).
  6. Click Save.
  7. Close all applications including the browser.
  8. Double-click on the saved file icon to start the installation process.
Nov 07, 2010 | Computers & Internet
My computer screen has error message Frequency out of range. This happened when running Google Earth, it changed the color quality from 32 bit to 8 bit. When I tried to change the bit back I get this error...
Right click on the free space in the desktop and select properties. Then go to display properties and change settings to 32 Bit and Change the screen resolution to 1024 by 768 Pixels.
Apr 05, 2010 | Gateway GT5220 PC Desktop
Error 32 message on pc when starting up
Sounds like possibly a corrupt file system or possibly a bad program install.
Try to boot to SAFE MODE. Restart your computer and press F8, select safe mode from the boot choices. If Windows loads try to use system restore or remove any program you may have installed just before this happend.
If it still won't start restart, press F8 and select the repair option then follow the onscreen prompts
Hope this helps.
Mary
May 11, 2009 | Computers & Internet
My pc won't install I Spy Junior.
You have given no information on your PC hardware, what OS you use, or if it is 32 or 64 bit.
Here is the link to the Tech Support site:
http://support.scholastic.com/faqs.asp?sid=102838090427012117185062&pid=424&dbg=&seid=1937&pnm=I+Spy+Junior&pos=Windows+XP&tnf=14&top=Error+Messages
Apr 25, 2009 | Scholastic I Spy Junior for Windows
Computer starts up fans and all that work but no image on screen
this may be because of your registry.. can below link that might be helpful for your problem...
http://etech.maiila.com/repair-kernel-32-errors-and-fix-dll-file-error-messages
hope this helps...
Nov 03, 2008 | HP Computers & Internet
Runtime error 32
it could be the memory moduls
Sep 27, 2008 | Intel Motherboard
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
