Question about Samsung LA40A450 40 in. LCD TV
Broken screen i have a 40in that looks like it was punched in. half the tv work but on the other side a huge portion is a mess, what can i do?
    Scholar:
  • 66 Answers
If it is within warranty, return it, send it in for repairs. if your tech savvy find parts for it and replace the screen yourself. if neither of these suit you i would say your looking at buying a new one, sorry to say this but there isn't much help for it. you could also find a local TV repair store and consult them but with it being a physical problem it will require a physical fix. not really something we can talk you through. i hope this helps and wish you the best of luck.
Posted on Jun 14, 2009
My hisene 40in tv screen is half white. How do i fix it?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 03, 2016 | Televison & Video
After awhile my t.v. has been on, half the screen will go black. How do i fix this??
May I know what portion on the screen turned to black, is it top half, bottom half, left/right side. Also please confirm if your TV's model no. is 50PQ30C, it is printed at the rear panel, manual, and receipt.
Dec 15, 2011 | LG 50PQ30C 50 in. Plasma TV
I have a Mitsubishi 60"
there may be dust behind the screen & also on the reflecting glass. u will see that upper back portion cover is removable. remove it & see that glass there is glass on inner side of cover. clean it, also clean the screen. u will see there are 3 picture tubes faces on bottom side, clean all of them.
if it does not work then u can increase brightness of tv by increasing "screen" control of tv which is on the lower back portion of tv. this can be done by any tv repair expert only.
Sep 05, 2011 | Philips Magnavox 51MP392H Rear Projection...
MY PICTURE SETTINGS KEEPS RESETTING ITSELF AFTER ABOUT 40 MINS.
I have got a Samsung LE40R88BD 40in lcd tv that after about half an hour the screen goes black and then comes back on after about ten secs but the picture is very much darker. what is the problem?
Nov 02, 2010 | Samsung LA40R81BDX 40 in. LCD TV
The bolt broke off with the lug nut. how to take out the old bolt.
If it is like a VW Jetta lug bolt, soak it with PB Blaster.
Take a sharp center punch and a heavy ball pien hammer and drive the broken threaded portion the bolt in the direction it goes to remove the bolt. Hold the center punch at appor 60 degree angle to the plane of the drum or disk and hammer away.
If it is a splined threaded bolt soak it with PB Blaster and drive it out from the back side of the drum or disc. Use a pin punch or rod or old bolt slightly smaller then the splined broken off portion and hammer away.
Above proccdure saves my bacon countless times!
Good luck
Terry
Sep 19, 2010 | 1985 Toyota Tercel
3 year old Viera with half white screen?
hello, you have a half screen what side? the fualt may be a board or a couple of boards it depends what side is off and what part, lower half, half, left or right sides. let me know i will check the results. it is servicable if your electronicaly inclined you can find the fualt by finding a service manual for this set, i have one. if you tell me what side is white and what portion i can tell you what board it is.. hope this helps
Jul 13, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Screen is half picture and half black with vertical colored lines
I had the same issue. I could get the tv to work intermittantly by pressing on the boards while playing. This points to bad solder joint, so I resoldered every molex plug connector, and it nows works like a charm.
Apr 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Samsung refrigerator RS267LABP icemaker
it could that your thermostat is set too cold making the ice crack and brittle
Mar 18, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Samsung LA40A450 40 in. LCD TV Logo
71 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
