Question about Dell Dimension 5100 (D51L1) PC Desktop
At bootup: "drive 1 not found;" neither CD or DVD drives work, although they start to run when I put in a disc, then stop.
When I boot up my computer, running Windows XP I get a message "drive 1 not found." I can hit F1 to get into windows, or F2 for setup. Neither of my drives, CD or DVD, are recognized.
  • billtetz May 18, 2009
    Both my CD & DVD drives show up in setup, & each will spin up when I put a CD in, but then stop. I did try to resolve my problem by uninstalling (not physically) & then reinstalling each drive, but that didn't work either, & the MS help on my computer suggested my registry was corrupted.
    This problem occurred immediately after I used a Kingston flash drive to back up Quicken. I also had used a program recommended by PC Magazine, Advanced System Care, which included a number of features dealing with the registry. And I did try System Restore, but there were no dates prior to my use of the System Care program.
    I assume I can make the change in setup to avoid the computer trying to boot from drive 1, but the larger problem, of course, is the non-functionality of the drives.
  • 20 Answers
When you boot go to your bios (probably f12) go to drives under there and see if your drive is present! if you have not changed any phiscal parameter on your computer it should be if it is not you may want to check the phisical cables in the computer to make sure they are attached and if so boot the computer with your hand on the drive do you feel it spinning up? is there a secondary drive present that has been added since the problem started? if so check the jumper settings on both (the drives should have a little picture that shows what for what) your main drive is primary and your second drive is secondary unless there older drives it may be labeled slave... let me know if it helped
Posted on May 11, 2009
What is the fault when the battery light flashes orange (suspect dead batt), also the unit will not boot, nothing from the screen, and the blue power and Wifi lights are illuminated?
1. Suspect dead battery- Your battery might be dead. just replace your battery.
2. Cd-drive spin but cannot run
- solutions is -
1. Please check if the support DVD has been damaged
2. Please check if the external optical DVD drive can work normally
3. Please unplug other USB devices
4. Please disable [Boot Booster] in BIOS
4.1 Start the system and press on bootup to show the POST screen. Press again to enter the BIOS setup.
4.2 Set Boot Booster to [Disabled]
4.3 Press to save the configuration and restart Eee PC.
Alos with other solutions,
ASUSTeK Computer Inc Support Troubleshooting EEE PC 1000HE
Jan 19, 2014 | ASUS Eee PC 1000HE Netbook
ECS K8T890-A (V1.0A): (Conditionally) Refuses to let me boot from sata CD/DVD drive. How to fix/workaround?
this could be that your cd/dvd is not being recognised by the computer
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Aug 15, 2012 | EliteGroup ECS K8T890-A (V1.0A) Socket 939...
I have an Insignia d400a, given to me by my mother. I know it discontinued but i needed a pc so i wanted to wipe the hard drive with the dvd and Im having a really hard time. I reconfigured the BIoS to run...
It should be able to boot from the DVD or CD rom drives before checking the hard drive by default, but somebody could have changed bios settings which could cause it to not work. The factory (OEM) restore disk is DVD media, so you would need to use the DVD drive.
F2 during bootup to enter BIOS and check your boot sequence to make sure that the DVD drive comes before the hard drive. Also, the card reader on D400's tend to fail and no longer work, so it may be a good idea to dissable that from the boot sequence. The card reader can usually be found as a USB device in the boot sequence menu.
Sep 10, 2011 | Insignia D400a PC Desktop
Solutions for "HP Pavilion dv5
File: \BOOT\BCD Status: 0xc000000F Info: An error occurred while attempting to read the boot configuration data. First try going into Windows safe mode with command line utility enabled. (F8 on bootup). In command console typechkdsk /f /r and enter Y for yes at the prompt. Wait for it to finish, it may take a while and then test the issue. If the problem persists, please continue with the following instructions. Rebuild BCD 1. Put the Windows Vista installation disc in the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. (Click the operating system that you want to repair), and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type BOOTREC /FIXMBR, and then press ENTER. 8. Type BOOTREC /FIXBOOT, and then press ENTER. 9. Type BOOTREC /REBUILDBCD, and then press ENTER. Use the Windows Recovery Environment (WinRE) to run System Restore 1. Insert the Windows Vista installation disc into the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time and currency, and a keyboard or input method, and then click Next. 4. Click Repair your computer. 5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next 6. At the System Recovery Options Dialog Box, click on System Restore. 7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point. 8. Click Finish to restore the system. Startup Repair from the Windows Recovery Environment (WinRE) 1. Insert the Windows Vista installation disc into the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time and currency, and a keyboard or input method, and then click Next. 4. Click Repair your computer. 5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next. 6. At the System Recovery Options Dialog Box, click on Repair your computer. 7. (Click the operating system that you want to repair), and then click Next. 8. In the System Recovery Options dialog box, click Startup Repair
finaly if you do not have the cd you can use a copy too.
Kronoguy
Jul 04, 2011 | Computers & Internet
Windows 7 laptop won't boot to OS , only has a black screen with a blinking cursor
Insert your system recovery disc to repair your startup.
1. Change your Bios to boot from disc:
When your computer powers on, hit F2 (on some computers, F8 on others). Use your arrow keys and move to the right to your BOOT option. Hit the down arrow until you select your CD/DVD drive. Look at the bottom of your screen, and it should say to change the option hit F7 or F8. Use the specified keys, and move your CD/DVD drive above your hard-drive. Save your settings.
2. Boot from your disc. Insert your system recovery disc and restart your computer. Let the recovery disc load. If the option comes up to hit any button to boot from CD/DVD, then hit any button. Once it loads, it should come to a spot where it wants your language. Select your language, then select the option "Startup Repair". Click on it, and let it repair the startup. If it automatically starts correcting your startup then great! If not, then select your operating system from the list and click the Repair Startup option. Restart your computer, and hopefully it will boot from your hard-drive correctly.
Hope this works.
P.S. If it continues to boot from your recovery disc, then using the same method in step 1, go to your bios, and move your CD/DVD drive below your hard-drive.
Mar 01, 2011 | Computers & Internet
How do I enable the drives on my Gateway 505GR?
Enter BIOS SETUP.
Change the "boot order" to put the CD/DVD drive as the _first_ boot-device.
Save/Exit, insert the CD-ROM containing the Operating System, and your computer should boot from the files on the CD-ROM.
Apr 08, 2010 | Gateway 505GR PC Desktop
My d600 will not bootup. i press f2 or it goes to a blank screen with a blinking line. what order do i put my boot order in so it will reboot
I usually put them in this order.
1. CD/DVD
2. Floppy Drive
3. Hard Drive
If your computer does not boot this way put the original operating disk in and try to boot from CD.
If your machine boots with the CD you can try to repair your operation system.
Mar 09, 2010 | Dell Latitude D600 Notebook
Laptop wont boot from cd/dvd drive, hard drive is cleasn, no viru
Hi usavahe.
Booting from CD should be possible.
1) When the laptop first starts to power up, repeatedly press the F12 key. This should bring you to a screen that lets you select the boot device.
2) For the Satellite, it may show icons across the bottom of the screen. You want the one that looks like a CD.
3) It should the start to boot from the Windows CD (if it is indeed a bootable disc) and you will see the message "press any key to boot from cd".
4) Press any key you want on the keyboard and the Windows CD installation process should begin
Hope that helps
Feb 12, 2010 | Toshiba Satellite A105 Notebook
Need to reconfigure start up on IBM computer. Windows xp at present, want to put Ubuntu on instead. When I press F8, I get safe mode options etc. Need to get to page before this, re: make cd drive the...
to make cd/dvd drive the primary one..all u gotta do is to configure the bios(press DEL/F1/F2/F10 briskly, as applicable while at the system boot, this'll enter u in the CMOS utility, search for boot Device Priority)..make cd/dvd drive the primary or 1st boot device n 2nd device @ HDD 0..
download n install any boot manager (various are available)..eg. Power quest Boot Magic..it'll b quite useful when u wanna selective startup using Multiple OS like win xp pro sp2+ubuntu..
the best is to install ubuntu first in raw/undefined hdd space next go for xp..
always better to seek professional supervision of ur System admin/vendor....
Nov 04, 2009 | IBM NetVista PC Desktop
I have a HITACHI 60 gb hard disk. tried to install os but "cant find any hard disks" appears. i can see the disk in the BIOS also suse linux does not find the same. it is a toshiba laptop i am using. will...
there are many reasons why, the computer would,nt find or see the Drive.
1:) the laptop drive, may need formatting.
2:) the drive, is not cabled correctly.
3:) the drive is faulty.
go into the bios setup, usually F2 Or esc Or Delete at setup. options sometimes appear briefly on screen. ** to enter setup press F2 Or similar**
find boot sequence or bootup order. and set the CD/DVD to become the first boot device.
Put your setup-install disk, in the dvd drive.
When rebooting the system, the computer will start a setup from CD/DVD. this will tell you that the drive is not found, or needs to be formatted. follow the on-screen options.
Finally, certain laptops only recognise, a drive of a certain size. install the original to see if this still works. Also check there are no limitation jumpers on the old-drive. ( small plastic bridging pins )
Mike @ compurepair.
Dec 16, 2008 | Hitachi 60GB Travelstar 5K160 Ultra...
Dell Dimension 5100 (D51L1) PC Desktop Logo
Alun Cox
