Question about HP WanProbe V-Series Network Monitoring Device
Carraige Jam I have an HP V40 (fax, printer ,scanner, and currently a paperweight). It still scans, but any time you try to print or copy, it give the error "Carraige Jam" All parts move smoothely.When you open the door the carraige move to the correct position still. Can you help a fella?
  • Home Dude Nov 11, 2007
    Thanks Verden.
    It still goes right back to displaying the "Carraige Jam" error though there are no obstructions anywhere and all parts seem to move smoothly. Whaddup?
    Problem Solver:
  • 13 Answers
Maker sure the cleanout station is not stuck..it moves also...dont break it just see if it isn stuck...move the carriage back and forth. put paper in it and turn it back on.....if that does not work..take the paper out ..open the back and roll th big wheels a bit and try again.
Posted on Oct 14, 2007
Cant send nor receive faxes
dear sir,kindly follow the below instructions
Instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
Says scanner failure, scan, copy and fax will not work, did the print alignment still not working Only the printer works
try use a high quality usb cable, some usb cables has low bandwith, and give some strange, errors like scanner error, copy,...
Feb 09, 2010 | HP Officejet J5780 All-In-One InkJet...
Help hp psc 1610 all in one printer carraige jam
Try this website:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00107909&cc=us&lc=en&dlc=en&product=79477
Nov 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
How do I use my HP office jet v40
Install software from disk or download from HP site
Apr 24, 2009 | HP Office Equipment & Supplies
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
The scanner keeps saying that my USB is not plugged in and it is
There is a workaround without messing with drivers. I have the same problem if I use the buttons on the v40 and try to scan. I get the V40 can not connect to the PC message.
Workaround:
Go to Control Panel-->Scanners and Cameras
In there you will find: Hewlett-Packard OfficeJet V40 Scanner
Right click and select Scan. It will then start the scan wizard which will scan your document.
Jan 26, 2008 | Office Equipment & Supplies
Scanning to computer
I had the same problem if I use the buttons on the v40 and try to scan. I get the V40 can not connect to the PC message.
Workaround:
Dec 03, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
Hp deskjet v40 printer set up
ADF means Automatic Document Feeder, used to copy, scan or fax multiple pages loaded at one time.
Aug 19, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
HP WanProbe V-Series Network Monitoring Device Logo
88 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
