Question about InFocus LP70+ Multimedia Projector
InFocus LP70 color problem
We have an InFocus LP70 at work. It displays the image with a yellowish, sepia color. For a fraction of a second the color appeared correct, then went back to yellowish. Is this a problem with the color wheel?
    Scholar:
  • 167 Answers
No it's not the color wheel. If the color wheel stalls the lamp will shut off immediately which is a built in protection mechanism. On the LP70 and 70+ there is a multi pin connector inside located at the rear lower left of the projector. This connector connects the main board to the DLP engine electronics. This connector is horizontal and approx 2 1/4" wide and 1/4" thick and about 100 pins. I have seen this connector not seated completely and many various video artifacts occur (even the one you describe) If you or someone you know is electro-mechanically savvy it's not difficult to open the projector and make sure this connector is seated properly.
You will need a TORX T8 screw driver.
Cheers
Posted on Jan 16, 2010
  • Ed Rivera Dec 18, 2012
    Thank you for the suggestion. I used a thin 12" ruler to carefully push the circuit board in which I could actually see was not square with the horizontal board. The projector work great now. Thank you
  • 2,237 Answers
Try resetting the settings to factory default through the menu. if there's still a problem, take the cover off. if you look from the back of the machine, inside on the bottom left, you'll see the main board attached by a large white plug. use something thin and non-metalic to push the bottom of the board towards the plug to tighten it. now do the same to the other side of the plug. this should solve it. if it doesn't, you need to replace the main board.
Posted on Jun 05, 2009
Process to upgrade firmware for InFocus lp70 ... can some describe this for me please? I've got the firmware downloaded, but my PC does not see the projector .. Help!! I also can not find the USB drivers...
Go here: https://portal.infocus.com/support/Product%20Pages/downloads.aspx?mic=LP70%2b&on=downloadsthen down load the file then find the text document "D3 D3+ firmware upgrade instructions.pdf" in C:\LP70plus\002-0870-08\I , or where ever you saved it. That will give you the complete instructions on how to upgrade.
Apr 27, 2011 | InFocus LP70+ Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70
Have you tried another lamp? Sometimes thats your problem, but I've seen a several occasions that the a defective power supply causes this symptom. Do you see an image flicker before the projector shutsdown? I do have some spare parts for this projector.
I'm on Ebay - gtitubro if you want to contact me through there.
Sep 17, 2009 | InFocus LP70+ Multimedia Projector
Lp70 flickers and color wheel chirps at the same time. It's worse with more white in the image. Colored screen shots or dark movies have limited flickering. No issues prior to hookup to computer (Infocus...
it's chirping because it's trying to keep in sync with the dmd chip. for the refresh rate, go into the menu and first reset the settings to factory default. if this doesn't clear it up, try matching the signal.
Jun 09, 2009 | InFocus LP70+ Multimedia Projector
Olympus FE 330
Unfortunately the camera does not have a menu option to take images in black or white or sepia. You can take them in color and then using photo editing software modify the image to be monotone or sepia in color.
May 06, 2009 | Olympus Cameras
Infocus projector lp70
in order for the lamp to strike and stay on, the fans and the colorwheel must be spinning and up to speed. if you remove the lamp and start it up, see if the 2 fans are spinning. and look inside to see if the colorwheel (a colored glass disk) is spinning. you'll also be able to hear a high-pitched squeal coming from it. unfortunately, you'll need to take it in to a repair center to have them replaced.
Jun 21, 2008 | InFocus LP70+ Multimedia Projector
Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Nov 20, 2007 | InFocus LP70+ Multimedia Projector
Additional viewing features
You can select several options via the EDIT tab in the MODE MENU, when the camera is set in PLAYBACK MODE. These include adding a frame to the image, Black and White, and Sepia tone, and there is also an option to “resize” the image to 640 x 480 pixels or 320 x 240 pixels in order to have a larger file for printing and a smaller size for emailing. When using any of these features the camera will display the image in B&W, or Sepia and if you press OK a copy of the image is produced in B&W or Sepia, which ensures that your original full color image is also kept .In the case of adding a decorative frame, after selecting your choice of a frame, when pressing the OK button the camera’s LCD screen will display the options of creating a new file with the frame on it or canceling the frame option. When you select “NEW FILE” you are creating a copy of the image with the frame around it, and the camera is also keeping your original image file.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
InFocus LP70+ Multimedia Projector Logo
893 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
