Question about GE 24 in. GSD4000J Built-in Dishwasher
Installation We are remodeling our kitchen and would like to install the dishwasher in the island instead of by the sink. Does it have to be hooked to the sink or can we hook it up independently?
    President:
  • 331 Answers
The incoming hot water can be hooked up independently. The thing you should consider is the drain line. The drain hose and the pump are (obviously) below the tub of the dishwasher (DW). If you route the drain hose through the floor directly, the water in the tub will siphon out. You'll need to route the drain hose to keep this from happening. The way to do that is to route it in such a way that it forms an almost upside down "J", then down through the island. The upper portion of the "J" should be about the same height as the top of the DW.
Also consider the electrical hook up. The proper way to wire it is through a SPST switch (like a light switch) so you can turn power off in an emergency or a servicer can kill power without having to locate the breaker. Some contractors "hard wire" the DW's in (with or without a SPST switch)... others mount a wall outlet so you can plug and unplug the DW if necessary. Either way is OK, only mentioned it so you'll know how your contractor will be doing it.
Just some things to consider. Good luck with the renovation and I hope you enjoy your new Kitchen.
Posted on Oct 13, 2007
What do I need to hook up my new portable dishwasher to my kitchen sink?
Go to a hardware store and get a Dishwasher Hook-up Kit. It will include a flexible hose along with several adapters. You dishwasher should come with a drain hose. You will also need a 3-wire "pigtail" (an extension cord with no receptacle or socket at the end). Your dishwasher whould have come with installation instructions, but seriously, if you've never done that before (or done similar work before), you should call a professional installer or at least and experienced handy-man.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 27, 2014 | GE GSC3500RWW Portable Dishwasher
Our dishwasher, a kitchenaid kuds230 model isn't clearing the water in the bottom. We had a new disposal installed yesterday and the problem with the dishwasher started afterwards.
The dishwasher's old water is pumped into the same drain that your kitchen sink operates off of. i would recommend that you check the hose that runs out of the dishwasher to the pipes under the sink to make sure that the line is, a) hooked up, b) that it is not crimped and causing the water not to flow.
Mar 06, 2011 | KitchenAid KUDR25 Dishwasher
I have a dishwasher whirlpool DU945PWSQO I like to know if i have to used hot & cool water install to the dishwasher. Or i have to used hot water only
You only need to hook your dishwasher up to the hot water only. You can run a separate pipe from any hot water pipe, but in most kitchens the dishwasher is next to the kitchen sink, so the hot water is just teed off of the piping under the sink...
Heatman101
Feb 22, 2010 | Dishwashers
In a kitchen remodel, I am installing the dishwasher about 3 feet from the sink. How do I plumb it?
If it were me I would use a small hole saw and run my braided stainless lines below the kick plate if code allows or at the back of the adjoining cabinet at a height which would not conflict with contents. You can buy an ABS dishwasher drain kit at Lowes or HD
Sep 14, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Can i connect my Hoover HD73M Dishwasher to a cold feed?
First off, you need a hot water feed line for your dishwasher, not cold water
Secondly, if you have a garbage disposal installed on your sink you can connect the dishwasher drain hose to the side port on the garbage disposal. That's what that little port is for anyway. If you do have a garbage disposal and hook the dishwasher hose to it then make sure you take a hammer and screw driver and knock out the little plastic plug that's inside the garbage disposal port before hooking up the hose to it, if you don't you'll flood your kitchen.
If you don't have a garbage disposal on your sink, then you're going to have to replace a piece of your sink's drain piping with a wye (Y) tailpiece. The tailpiece has a small branch that comes off it to where you can connect the dishwasher drain hose.
Regardless of which way you hook up the drainage and water lines, make sure you test out the work you did by running the dishwasher and keeping an eye on it. I can't tell you the number of times i've seen people hook up stuff like this and not test it and then when they go to use the dishwasher it floods the kitchen..... usually when people are sleeping at night. Test your work.
Aug 01, 2009 | Hoover 24 in. HD73M Free-standing...
Remodeled kithen; when dishwasher reinstalled, water backs up
OK, I have made this error before.
When you install a new garbage disposal, it comes with a "plug" that fills the hole of the little pipe that the dishwasher drain hose connects to (if there is a dishwasher.)
Remove that plug (see instructions for the disposal) and you should be all set.
Also, if you ever get the chance, consider installing a dishwasher AirGap valve between your dishwasher and garbage disposal. They are almost free at any hardware store.
Good Luck! Please report back with what you find.
Apr 06, 2009 | Dishwashers
Water gets into disher when not inuse
dishwasher drain enters sewer system tapped into waste pipe below kitchen sink
water flowing from kitchen sink passes the opening of the dishwasher pipe
If the dishwasher hose does not loop up higher than the kitchen sink before going down to the bottom of the dishwasher water may flow downhill through the dishwasher drain into the dishwasher
ensure the dishwasher drain hose is screwed to the underside of the kitchen counter, to provide a stop to water flow.
The installation instructions suggest this
but often the dishwasher is at the end of its 'stretch'
and the installer assumes looping is just to use up excess hose, and doesnt.
an extension drain hose is available at most appliance stores
Oct 27, 2008 | Kenmore 22422 Top Load Washer
Diswasher drainage in an island
Dbootin,
I suggest just putting a dedicated Drain in the island next to the Dishwasher. You can hide it in side the island. Under the house, tee into the Main Sewage drain.  You should not need to vent it as the sinks vent is near enough to keep you from worrying about that.
Oct 31, 2007 | GE 24 in. GSD4000J Built-in Dishwasher
Dishwasher intallation
the waste water piping must be on the downhill side of a drain trap. the trap prevents bad gasses from entering the house.
Oct 13, 2007 | Miele Incognito G818SCVi Built-in...
GE 24 in. GSD4000J Built-in Dishwasher Logo
168 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
