Question about Sharp AL 1631 Copier
AL 1631 - Give me blank copies, Shape tech. sadi scanner was stuck.
  • DanakaDan May 11, 2010
    Did you get a error code like L4-00 or anything? your still able to make copies?
  • 125 Answers
Hi:
If your not comfortable with disassembly then you should have it repaired by a qualified tech. With that said you need to remove the glass that you rest your documents on. Undre that you will see a round silver tubular shaft that the scanner rides along. This shaft needs to be wiped down with alcohol. The shaft can be spun around as it is cleaned. When this shaft gets dirty and black it will cause the scanner to stall and if it does not scan the document then you get a blank copy.
Andrew
Posted on May 12, 2009
Its a Sharp AL-1631. It'll copy from the auto feed
Check under the scanner, there is a scanner lock that you may have hit removing copies. Its most likely in the locked position and stopping scan.
Jun 03, 2011 | Sharp AL 1631 Copier
New toner blank copies
Problem on corona wire. You check it charger and rewire again
or problem on scanner unite or scanner ribbon.
Feb 18, 2011 | Sharp AL 1631 Copier
When I try to make a copy the machine make a screeching noise and a blank copy comes out.
Leave the lid up when you make the copy and see if the light bar moves from left to right when copying. Check the scanner lock knob under the left hand side where the papers come out. Make sure it is not locked. Sometimes the scanners get stuck a lot and can cause blank copies. If it is stuck then you just have to remove the glass and then clean and lubricate the steel bar at the back that the whole unit rides back and forth on. Once that is doene it should work fine. Make sure to manually run the scanner bar out and back a few times so that you can get the whole rail lubricated. Do all this with the power turned off.
Good Luck and Thank You for using Fixya.
If I helped, please let me know via a testimonial today!
Oct 08, 2010 | Sharp AL 1631 Copier
SHARP AL-1631, SCANNER NOT MOVING WHEN MAKING
You try any zoom copy, I maen 80% small then move scanner.
Apr 21, 2010 | Sharp AL 1631 Copier
Sharp al-1631 error L1
Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting.
If its the scanner, unlock the scanner lock above the paper exit tray.
Nov 25, 2009 | Sharp AL 1631 Copier
My Sharp 1631 sounds like it is working fine but blank copies are now coming out
Make sure thee scanner lock isn't locked and after you clean the scanner rail, use only 3n1 oil on it.
Sep 24, 2009 | Sharp AL 1631 Copier
Sharp Al 1631 prints half a page
Sometimes the originals hesitate using the document feeder, which can cause the problem you are describing. Do you get the same rsults if you lay the original on the glass?
Apr 29, 2009 | Sharp AL 1631 Copier
Scanner bar will not move to scan the paper to be copied.
a piece of plastic locks your scanner in place, it is under the scanner up above where the copies come out. It turns 90 degrees.
Maybe some one turned and locked it.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 ---- Getting blank copies
Hi, you can stop a copy half way to see if it image is on the on the drum if not check and make sure toner unit is turning. if not main charge. thanks dale.
Jan 22, 2009 | Sharp AL 1631 Copier
Al 1631
Simple you get a PM, new developer.. call an authorized Sharp Tech...
Oct 21, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
94 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
