Question about Garden
I cant get gas to spark plug ive cleaned everything throughly but still wont get gas
  • katman_43 May 13, 2009
    hey thanks for the info on the carburetor.....but i don't know if this is any help to you and my pronblem...but there is no air/mixture screw or idle air screw. There is no series number like (9200) and it's a 1995-1996
    thanks
    katman_43
  • 246 Answers
Hello katman_43:
If you Cleaned the Carburetor with Spray Cleaner, then it is Still Dirty and Restricted.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I Suggest you Make Sure the Gas is Free Flowing to the Carburetor Inlet Port (if the Model does Not have a Fuel Pump). If the Gas is Free Flowing to the Inlet Port, then
>>**Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk).
>>The Primer Bulb is Held in Place with a Locking Collar at the Base of the Primer Bulb. Use a Small Flat Screw Driver and Carefully Pry the Lock Ring Up in Small Amounts All Around the Lock Ring until the Lock Ring and Primer Bulb can be Removed from the Carburetor Body. Usually a New Primer Bulb is Required when you have to Soak the Carburetor. The Rubber is Usually Rotted to Much for the Primer to be Reused.
>>Your Primer Bulb May Differ Slightly, but Removal is Usually Almost the Same Except for the Primer Bulbs that are Bolted to the Carburetor. These are Simply Unbolted and Changed with the new Primer Bulb.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve and Needle Valve Seat if Applicable. This is a Flat O-Ring Located in the Inlet Port the Float Needle Rests in. Use a Strong Wire with a Slight Bend to Remove the Old Seat. Sometimes a Small Pocket Screw Driver can be Use Also.
>>The New Seat will have a Slightly Beveled Side and a Flat Side. The Flat Side goes Towards the Carburetor Body when Inserted into the Inlet Port. Spray the Seat with Spray Lubricant to make Installation Easier. The End of a Drill Bit that is Slightly Small than the Seat can be Use as an Insertion Tool.
>>Wear Gloves or Use a Rag when Handling the Sharpened End of the Drill Bit. Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. Even the O-Ring Around the Bowl can be Reused if it is Not Broken. The Only Parts you May Need to Replace is the Float Needle Valve (and Seat if Applicable).
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
If you are Sure the Carburetor is Clean, then make Sure the Intake Bolts are Tight.
I am Assuming that you have made Sure that it is a Gas Problem and Not a Valve Clearance or Ign (spark) Problem.
If the Carburetor is Clean and you have Fire to the Spark Plug, then Check the Compression.
>>The OEM Says to "Quickly" Turn the Engine in Reverse Rotation and if you Get Good Kick Back the Compression is Good. However, I haven't had Much Luck with that Test. Depending on the Model, If this is the OHV Engine, then Remove the Rocker Arms and Remove the Exhaust Valve Push Rod. Check the Compression. If Not the OHV Engine, it More Complicated. If you need the Instructions for a Non OHV Engine (Flat Head/LHead), then Let me know.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • John C Bridgers Sr May 14, 2009
    Hello katman_43:
    If there are NO Adjustment Screws, then you have the Non-Servicable Carburetor and Most Times if Soaking and Cleaning as I Suggested in the Instruction File does Not Correct the Problem, then a New Carburetor is Required.
    >>I Purchase these Carburetors from www.outdoordistributors.com/ @ 877-707-2787.
    >>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
    Best Wishes and Good Luck
    Respectfully
    jbridger (John)
  • 181 Answers
Have you checked for a head leak or a valve being stuck open.either will give you a no fuel problem.if the unit has been stitting for some time both can occure.have you checked to see if there is any compression? if either of those problems exist the motor will not pull any fuel into the cumbustion chamber......i will try to help you any way i can,just let me know....................
Posted on Jun 03, 2009
Toro power clear wont start change oil and fuel replaced carb gaskets thought I cleaned the carb cleaned spark plug and started with the choke still WON'T START HELP PLEASE
Plug must not only clean but filed flush and reset. have socket ready , pull engine over several times , remove plug right away if wet with unburnt gas then REPLACE plug. If no sign of gas on plug then your gas is not getting through. check gas lines and blow through filter to make sure it is not plugged. Water in your gas?
Dec 14, 2017 | Toro Garden
Ive just brought a new spark plug but when tryiny to fit it wont screw in and now cant get the old one back in any suggestions to how or why this is
probably you damaged the internal thread, check with a lamp if the thread is clean from metal chippings, clean everything with a brush without let entering something inside engine, if the thread is damaged you need to do a new one with appropriate equipment or take it to a mechanic
Jun 08, 2016 | Motorcycles
On my 2003 kawsaky 250 bayou wont start but I have compreshen and spark and is gein gas and ive cleand the carb what do I do next
hi craig first of have you changed the spark plug ? it may look good but might be breaking down inside was it running then stopd or has it been stored >
Feb 06, 2015 | kawasaki Motorcycles
The saw has good compression! ive done everything i related to running and still cant get it to start im stumoed any suggestions?
For all small engines, check for spark (pull the plug, ground the plug's metal body to metal engine block, pull cord and look for spark in the gap). If you have spark, prime the head with about 1 teaspoon of gasoline or a squirt of starter fluid through plug hole, replace plug and try again. If it runs for a few seconds and quits after several attempts at priming, your carburetor needs cleaning. Probably gummed up with old gas (not drained)... a sticky situation. Remove, dismantle and clean with carburetor cleaner or replace. Next time, empty gas and run it dry.
Oct 28, 2013 | Husqvarna Garden
Mtd yardman wont start getting feul no spark detected
they go bad rarley make sure your blade brake switch is not ingage killing spark
Apr 19, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
I cant get my chainsaw to start i have changed the spark plug new gas and oil cleaned internal and external very well but just wont start
If there is a good spark at the plug ( check this by resting the plug against the cylinder, away from the plug hole and crank the engine ) and there is signs of fuel at the plug after cranking the engine, then it may have picked up on the piston, remove the muffler and check the condition of the piston through the open exhaust port, any sign of scuffing on the piston skirt and it will have to come apart to assess the damage.
Nov 22, 2012 | Garden
Poulan p1500 16"/25cc trimmer wont start
If there is a good spark and good fuel getting to the plug, it may be the ignition timing is out, remove the flwheel and check the flywheel key has not sheared, if ok, pull the muffler off and take a look at the piston skirt through the open exhaust port, any signs off scuffing and it will need to come apart to assess the damage.
Oct 18, 2012 | Poulan Garden
I have a 1979 yamaha enduro 125cc i cant get it to start... i ran when i first got it and then it just died and i havn't been able to get it started... i changed the spark plugs cleaned the gas tank...
Did you squirt some gas in the cylinder to see if it would fire? Check the spark by laying the spark plug on the head, or holding it there with rubber handles, attached to the plug wire, see if you get a spark, if that checks out, you have spark, open up the air filter and peek in the carb, twist the throttle to see if gas comes shooting out. If not, squirt a little gas in the carb, try it, fire? check the fuel filter, pump, carbs could be gummed up. Did you get the jets clean? Run a wire through them to see if they are clear? Blow through them to check. Check it out.
Jun 23, 2010 | Motorcycles
81 jeep cj7 wont start after rewiring
check this,
remove a convenient spark plug, stick it on it's wire and place where you can see it, stick you finger over the spark plug hole and have a friend crank the engine, note whether the air blast and spark are the same instant if not the distributor's out of time
Aug 30, 2009 | 1983 Jeep CJ7
Garden Logo
849 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
