Question about Garden
PRESSURE WASHER OIL
I HAVE A PRO 1600PWA PRESSURE WASHER THAT I NEED
TO REFILL WITH OIL.
WHAT OIL DO I USE.
Non-detergent oil
Posted on May 26, 2009
How ofte I have tochange the water pump oil
every time it gets corrupted with water , it will turn from golden/clear to gold/milky when its time to replace it
an allways ck your oil level in pump and engine an refill if needed when adding gas to tank , its natural to be missing some each time as equipment gets older an older
Nov 07, 2015 | Dewalt Pressure Washer. 4200 PSI 4.0 GPM...
Oil is milky colored on my kingcraft pressure
Milky-looking oil is a sign of water mixed-in with the oil. This is often a sign of severe engine damage (cracked block, cracked head) in a water-cooled engine. (i.e., one having internal water jackets such as a car engine). On a pressure washer it is sometimes an indication that the owner used the pressure washer on itself, i.e., so as to clean the pressure washer with the pressure washer - very bad idea. If this is the case, then the pressure washer is most likely ruined. In any case the milky-looking oil is a sign that the oil has become contaminated with water, and probably a lot of water. I would drain the oil completely and replace the oil filter too if it has one, then refill the crankcase with new oil. Then try using it again for 10 or 15 minutes or so, then reinspect the oil. If it's milky-looking again then I'd set it out at the curb on trash day.
Oct 20, 2014 | Garden
Location of pump oil input valve
Hi
Im surprised that this model pump has a oil refill. Most pumps of this size arent refillable. This looks to be a pump made by FAIP. Its an ok pump but I would recommend using it until it fails and then replace with an AR RMW pump. Much easier to get parts for. Here is a diagram of your pump...The oil refill plug is on the side of the pump...that is located under your engine. You want to get the recommended oil for your pump. Most pump oils are 30 weight non-detergent but these small pumps take an oil specific to only them. So follow your specs...your diagram is here http www searspartsdirect com Craftsman Power washer Parts Model 580752330...
and your manual is here 580752330 CRAFTSMAN PRESSURE WASHER Manual
Hope this helps
Sep 20, 2014 | Craftsman Garden
I have a pro 1600pwa no22049022491 and it leaks from the gun i took gun apart to find that the small tube comes up the handle inside bends then gos on the end of the trigger in the bend ther is a small...
No parts for the gun. I'm not sure what model you have for sure, I don't recognize 1600 PWA, see link.
http://www.ppe-pressure-washer-parts.com/job-mate-1600-power-washer-parts
Apr 19, 2014 | Garden
Where do you add the pump oil and where do you add the engine oil on husqvarna 020490 pressure washer. I see a yellow oil plug on both sides.
Hi Andy.
The yellow oil plugs are for the motor. At the bottom of the crankcase you should also see a screwed drain plug. Remove this, allow the oil to run out, replace and refill with a good quality multigrade engine oil.
The water pump oil may or may not be accessible, depends on the pump manufacturer. If you have a sight glass, you will be able to drain and change the oil. You will also have a filler cap with a breather.
Use a good quality tractor transmission oil or oil supplied by the manufacturer. DO NOT USE ENGINE OIL IN THE PUMP TRANSMISSION. It may aerate and overflow.
In normal use a pressure washer should not use either engine oil or pump oil between servicing. Excessive engine oil consumption indicates a tired motor. Oil consumption by the water pump is a big indicator of overuse.
Nov 03, 2013 | Husqvarna 3100 PSI 2.8 GPM Gas Pressure...
What oil weight is used in the pressure washer pressure unit
Non-detergent 20-30-weight goes into pump port, and is filled about half way.
Ordinary motor oil 10-W30 or 40 goes into engine port.
Nov 11, 2012 | Dewalt Gas Pressure Washer: 4200 psi 4.0...
Oil to gas mixture for a craftsman 3.75 hp pressure washer
There is universal 2 cycle oil available (pro-mix at Lowe's for example) that is good for all ratios from 16:1 to 50:1. With this oil you add the same amount of oil to the gas independent of ratio required. One gas can, no ratio worries. Hope this helps.
Oct 03, 2009 | Briggs & Stratton Garden
I am wondering what type of oil to add to my pressure washer pump. I have lost the manual. It is a MCS Storm HG 202B washer with a honda motor.
They sell 'pump oil' I use the PRO JET brand universal pump oil. It can be hard to find. I get it from a local chain saw shop that sells pressure washers.
May 10, 2009 | Garden
Garden Logo
350 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
