Question about Refrigerators
I need to replace the door gasket. what type of silicone should i use?
  • 306 Answers
No need to use silicone just take loose the screws going around the bulb of the gasket and pull out old and insert new. Be sure to remove door from unit whole lot easier. Set on saw horse's and should only take a hour.
Posted on May 11, 2009
How to repair a lg dryer dlex3470v
See the groove on the edge where the gasket fits onto the door? As you peel away the gasket, you'll see how you need to thread the gasket onto the door flange so that the gasket will fit properly.
Use a silicone-based spray on lube to help it slide back on. Start at the top & work your way around the edge pressing the gasket groove onto the metal as you go. You might not even need a new gasket unless it is damaged.
Aug 14, 2014 | Dryers
Water is flowing enen though the the lid is up
Try running some cleaner through the system. May have to do this a couple of times depending on the type of water you have.
Aug 20, 2013 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
Changing thermostat v6
drain coolant until its below the thermostat.then remove two thermostat housing bolts.remove thermostat housing and thermostat.make note position of thermostat before removing it.then carefully clean all old gasket material from thermostat housing and cylinder block you can buy can gasket remover at any auto parts stores.buy new thermostat gasket.if you have the paper type you need to buy RTV SILICONE to help seal gasket if you have rubber type gasket you dont need RTV SILICONE.make sure both surfaces are clean.then install new thermostat and new gasket.if you have paper type gasket apply thin 1/16 coat RTV SILICONE both sides thermostat gasket.then install gasket to thermostat housing then install housing to cylinder block first make sure new thermostat in place before installing thermostat housing. let RTV silicone sit up about hour before adding coolant.IF THERMOSTAT HAS THE O RING SEAL DONT NEED RTV SILICONE AND THE PAPER GASKET.
Jul 01, 2013 | Mercury Sable Cars & Trucks
Rear Door seal water leak
If silicon is working,I would go with it,silicone last a long time and it's working.
Dec 25, 2012 | 2001 Toyota Sienna
Just got cx500 custom 1981 leaking oil when i start up from small hole on side of cylinder what do i do
If the oil leak is coming out of the spark plug drain hole , the inner valve cover seal is leaking or not installed correctly. Take out the two bolts holding on the valve cover and remove the cover. If the valve cover gasket has silicone on it , pick off all the silicone and put the gasket and cover back on. That should fix the problem. Silicone on the type of gasket can make it leak. If the gasket is hard or cracked replace the soft rubber gasket and put it on by itself with no extra sealant.
Dec 24, 2010 | 1982 Honda CX 500 B
We have a 5 ring Lofra oven (all gas) and live in spain and the seal on the oven door has perished - we need to replace it but it seems Lofra UK has gone bust and from reading reports, Italy is not helpful...
There are many types of seals that can be used which are universal and not specific. You must check with the Kitchen appliances spare parts dealer for assistance. Take along the sample of the gasket to get a look alike type.
Also there are many available in shops that sell penumatic tubings specially silicon gaskets. Only the groove need to match with the heat resistance characteristics.
Sep 15, 2010 | Ovens
Water leaks from the door of countertop model on
My older model had cheap plastic type rivets around the window. Of course they broke and water leaked out the window. I took the door apart and put in a new gasket the siliconed the heck out of it!
Put dishwasher on a counter or floor and put a nice thick phonebook under neath the opened door for support. Carefully replace window with gasket and a bead of silicone. Put enough weight on top to press it down and seal it. Leave for 24-48 hrs. I've replaced the window 3 times and this fix has lasted 2 years now. total cost about $10 and a little effort. make sure you use heat tolerant silicone.
Dec 22, 2009 | Danby DDW497W 22 in. Countertop Dishwasher
Valve cover gasket and grammets
nonono on silicone if silicone is a must use an ultra black not a rtv silicone
May 08, 2009 | 2000 Ford Focus
Refrigerator gasket cement (what is it so I can buy it)
ill assume there is a tear in the gasket? if this is the case you can mend a tear with regular clear(or white) g.e. 100%silicone. apply a little silicone n the seam where the tear is and close the door overnight allowing the silicone to set up. it will remain flexible enought to compensate for the door opening and closing
Nov 18, 2008 | Kenmore 64522 Top Freezer Refrigerator
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
