Question about Eclipse XA5000 Car Audio Amplifier
Amp Kicks on and off
When i first installed it, it was working fine. But the next day the amp out the blue now kicks on and off. With the radio on, the amp with just kick on and off, and sometimes the sound will also play and stop over and over. I just diconnected the radio cause i didnt want to do any damage to the amp. But could it be a amp problem?
    Problem Solver:
  • 18 Answers
First of all you need to check all your connections on your power and ground ... then check the voltage you are getting at the + terminal. Next check the power Remote from your radio and make sure you have power from there.     If  you have PROPER voltage on each of those then yes your amp could possibly be bad or going into protection.
Posted on Oct 13, 2007
My alpine Mrd-1005 has been best amp ever. But the other day it all of a sudden started blowing fuses on the amp and the current protecter mode kicks on.. as long as I keep volume down in works but as soon...
make sure there is equal amps on the fuse under the hood and at the amp...also make sure to never mount your amp to anything metal....wood only! hope this helps, mine did the same thing
Sep 04, 2011 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
Amp slow to kick bass in.
it sounds like you havnt got the memory live conected on your hea duit or it is conected to an ignition live this is no good it needs to be conected to a permenent live to ensure the memory has power at all ties of it coulb be that the amp needs adjusting for low volume use
to set up a sub you turn up the volume to the required level then adjust the amp acordingly hope this helps ben
Oct 11, 2009 | Alpine MRP-M650 Car Audio Amplifier
The power protection kicks in when I turn up my radio volume
ground wire connection or possibly amp is turned up to high when an amp is turned up all the way it starts pushin dc voltage also it could burn out the internal battery check all connections and settings after that make sure subs arent begining to blow a sub that starts to blow kicks of the amp hope this helps
May 21, 2009 | Sony Xplod 500W Bridgeable Multichannel...
Amp and subs cut out when I insert a cd in my radio
You have the amp connected to the blue wire on the radio instead of the blue one with the white stripe. The blue one is the power antenna wire so when you switch to cd, it would close a power antenna. If you dont have a blue /white wire, you can hook it to the red 12v wire. Good Luck
Mar 07, 2008 | Car Audio & Video
No audio from cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go. The same goes if your have an aftermarket amp driving your speakers.
Sep 23, 2007 | Alpine CDA-9885 CD Player
Amp keeps kicking off? Power Protector?
as long as your powers and grounds are good(make very sure your ground is ok) then either you have a intermittent short in one of the subs or the amp is getting ready to die lol.. The sony amps are notorious for faulure-the quality is just not there... Is the amp really hot??? the only other thing you coudl try is to ass a fan or two in it or around it and see if that helps it out..
Aug 18, 2007 | Sony XM-2200GTX Car Audio Amplifier
Eclipse XA5000 Car Audio Amplifier Logo
77 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
