Question about Samsung HP-R5072 50 in. Plasma HDTV
Hl-p5063w( help my tv wont come on
Hello sir my tv is not showing no picture the only thing i am hearing is the sound ......there is a lamp light sign that keep blinking on and off then it shuts off and comes back on......... Can you please help with a solution thank you
  • 1 more comment
  • capsdds Dec 24, 2007
    no picture
  • Anonymous Dec 31, 2007
    Just brought home my samsung plasma . Watched it for 5 hours and the picture went out,but still have sound
  • oneill Jan 01, 2008
    my samsung plasma tv just turnd itself off. Now i have sound but no picture
  • 179 Answers
The first thing to do is remove the lamp and look at it..see if it has blown up or if it looks sounds like you need a new lamp
Posted on Dec 01, 2007
HL-P5063W Turns on, but no picture.
remove and inspect the lamp the model indicated uses---you can usually also look from the rear to see if lamp comes on at all---set also prone to bad color wheel--grinding or high pitched fan like sound--it faces the lamp--with lamp removed look to see it is not shattered or missing pieces and that lamp not shattered inside.
10_22_2012_4_53_15_pm.jpgtypical color wheel
Oct 22, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
Jul 29, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
My problem is: samsung hl-p5063w. I have a new lamp and it works fine. The fans work all right. The color wheel works well. But no picture, only the screen is black. Low light without image. The timer...
I'm not a tech person, but from what I have learned it sounds like your digital board (input) connections. Try diffrent connections to see if you get a picture.
If you are using a coax cable for your input, try the rca type input. If you still get no picture after trying diffrent inouts, it may just be the digital input board. Again Im not a TV specialist, just sort of informed from the net.
Apr 20, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv picture keeps turning off
several things, cooling fan out, bulb going out, lamp ballast or the power supply board could be failing. call 1-800-samsung for nearest service center.
Nov 19, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I just replaced the lamp on my samsung HL-P5063W (DLP TV) the TV will not turn on (no picture...but I do get sound)...when I plug it in, it automatically starts to power on...then it starts making...
Sounds like a bad color wheel. Generally when the color wheel goes bad, when you try and turn the TV on the lamp will ignite for a couple seconds and then turn off. It also makes a rather high pitch squealing noise. should carry a replacement color wheel for your TV
Sep 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
No picture after replacing color wheel
every time I see this itbis a cable or plug that was left out or one that got pulled on and pulled the connector up out of the plug a little, you need, and not by sight by your hands to go over every plug and connector till you find one.
Larry Dillon
Aug 01, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
My picture won't show after replacing the lamp
Actually that humming sound was not the lamp, the humming sounds come from color wheels when they're going out, and since the color wheel is part of the light engine system and it's not working, that's why you don't have an image, you'll probably ask your self why, since it's not the lamp.. the thing is that the light engine system is componed by lamp, ballast, color wheel and dmd board, so when one of these doesn't work, there will be no image reflected, because they work together
Jul 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Sound but no picture
You need to replace your lamp. Part number is on the side of the tv on a sticker LAMP CODE.
Aug 17, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HP-R5072 50 in. Plasma HDTV Logo
83 people viewed this question
Jerry Greenberg
Jerry Greenberg
