Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
What is monoscope signal and ntsc full mode
Can anyone describe what is monoscope signal and ntsc full mode? How do I get them in sony rear projection tv in service mode? Are there any factory set default values for all the grn,red and blu adjustments in service mode? I have the service manual, but I don't know how to find them. any help is appreciated.
thanks a lot folks.
  • sonitv Oct 14, 2007
    Thanks Shuttle83. So, is produced by the TV itself or I need any special instrument to get this?
    Genius:
  • 1,139 Answers
Indian pattern
Posted on Oct 14, 2007
  • Henry McKelvey
    Henry McKelvey Oct 14, 2007
    A monoscope was a special form of cathode ray tube that was used to generate, rather than display, a video signal. Each tube was only capable of generating a single video signal, hence the name.
    Essentially similar in construction to an ordinary CRT, the monoscope contained a formed metal target in place of the phosphor coating at its "screen" end and as the electron beam scanned the target, a varying electrical signal was produced. This signal reproduced an accurate image of the target and so could be used to produce test patterns and the like. For example, the classic Indian Head test card shown on the last post above was often produced using a monoscope.
  • Henry McKelvey
    Full NTSC Mode means the color meets all of the NTSC specs.
Fixing the convergence on a sony rear porjection tv
AUTO CONVERGENCE OFFSETS
IMPORTANT
This adjustment must be performed after registration adjustment
or after readjustment for any reason!
Once registration in all modes is satisfactory, do the following:
1. Darken the room environment near the set.
2. Enter the monoscope signal to set the NTSC Full mode.
3. Select the PJE mode.
4. To automatically store the offset values, press the "FLASH FOCUS"
button on the front panel of the set.
(The offset value is now stored)
5. Select "ERR" of PJE mode.
Confi rm ERR is "00".
If ERR is not "00", recheck. (Refer to section 2-15)
6. Exit the service mode.
To get more details about how to enter service mode option, check this link, and select the site named 'Electro-help'. all details are there.
Jul 10, 2012 | Sony KP-53HS20 TV
Sony KP-51WS510 problem- 1. Picture is not stabilizing while can heard Audio clearly and continuous vertical moving picture. 2. How to connect TATA SKY INDIA DTH TO TV and convert PAL signal to NTSC or...
In your problem #1. try to do a fine tuning of the channel or adjust the horizontal adjustments. For the problem#2. Access the system setup of your television, from there you can choose either PAL signal or NTSC signal to operate in your system.
Oct 30, 2010 | Sony KP-51WS510 51" Rear Projection...
RCA hd52w67 analog convergence problem.
with Tv off press and hold ch- and vol- at same time untill tv turns on then release and you should be in factory settings service mode.
May 26, 2010 | Televison & Video
Monoscope signal how to get it Mitsubishi VS-6043 rear tring to adjust the picture its all warped looking got tv out of ditch tring to make it work
does the convergence align or move? how is the picture distorted? if the picture aligns but is just warped, use a jig or some string to have some straight lines to reference for your geometry and convergence. the monoscope signal is hard to find and mits had it on a vhs tape back in the day. it really just helped you get the horizontal and vertical size and get a round circle to fix the warp.. just try to make all the grid points about the same distance apart and make it an even grid.
May 26, 2010 | Mitsubishi VS-6043 60" Rear Projection...
I want to turn my regular signal into an HDtv signal. How Can I do this?
Your, ahem..., your Regular Signal?
Please describe this more in detail, what you are trying to do?
There are upscaling dvd players these days that can upscale regular dvds to HD...
What regular signal are you talking about? Over-the-air TV went to Digital recently ... so the Regular TV old style signals are mostly gone from the airwaves. That was NTSC (Never Twice the Same Color, no really Nation Television Sub Committee.) Now it is Advanced aka ATSC. Most tuners on newer tv's will do both NTSC and ATSC both on over-the-air and on most Cable TV systems.
Retrievo has you manual. You could probably also find it on the manufacturers web site...
http://www.retrevo.com/support/Philips-60PP9202%2F17-TVs-manual/id/446bh336/t/2/
Nov 23, 2009 | Philips 60PP9202 60" Rear Projection...
Does anyone know if this tv is analog
the tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
Can't display Pal on My Sony 57" KP-57WS520
There are probably a few problems here. What are you using to play the disc? Some NTSC players will "play" a PAL disc but interpret it as NTSC with the symptom you are describing. You need a DVD player that will play PAL. Many of those will output NTSC directly when set up to do so. The other alternative is to have a PAL compatible player that will output PAL into the converter. To narrow this down specifically, please post the model numbers and the connection scheme for your equipment. Once I understand your current setup, I should be able to describe a method to get this to work for you.
Dan
Dec 16, 2008 | Sony KP-57WS520 57" Rear Projection...
PT-53WX42 53 Blue curve problem
If you've already replaced the convergence IC's and confirmed the coolants in each tube are filled, you probably need a factory level convergence done.
The procedure is 18 pages long and requires a NTSC pattern generator to do correctly. You need a funtional remote. Personally I'd recommend finding a well-trained tech to do it for you. Takes
about 2 hours to do both 480 and 1080 modes. Anyone who tries to do it from home without equipment is asking for headaches. It's hard enough to do in our shop... (were factory service for Matsushita)
You might get away with a minor touch-up for any particular area, but going into the factory-level setup mode without knowing what you're doing is not recommended - you may find yourself replacing the EEPROM.
Good luck, Mark
Nov 20, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection.
Put tv in standby then press above said buttons. You will be in service mode.
Be Care Full while in Service Mode data handling.
Oct 03, 2008 | Sony KP-61HS10 61" Rear Projection...
Conversion of PAL (B) into NTSC
you will need a pal/ntsc digital video converter
Dec 01, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
1,306 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
