No output 3020b amp. on power up the power led flickers and rasping noise from speakers. sometimes the amp will cut in and the led becomes steady but after a while it reverts back to the described fault. I have searched for dry joints etc. but none found. r630 & r904 look a little cooked but meter out ok. Any advise would be welcolm Regards Steve UK
  • steve558 May 13, 2009
    Ok Problem solved Fault turned out to be the on/off switch. A large dose of switch cleaner has almost cured it but a replacement switch will make a job of it. Thanks farr64 for your advise as I also found a dry joint on one of the smoothing caps and this also has been sorted.
    Great site keep up the good work
  • colin
    colin May 11, 2010
    check the small capacitors in the power supply these tend to leak or dry up .tap around the power supply to check for dry joints. have you tried checking the web to see if anyone else has had this problem?
dsom
  • 56 Answers
SOURCE: TX-DS575 reverts back to standby mode when turned on
You can find it out by yourself. I have the same device; therefore, I know that this device has a "test" function. Just unplug rear (surround) speakers at first, then test the rest of the speakers if the amp lets you do it. Hook up one of the rear speakers you regularly use to rear left or to rear right in order to test each rear channel. If one of them turns off the amp, you'll be able to understand which side feeding resistor does not work. However, if the amp goes to standby mode as soon as you hook up one of those speakers, you can alternatively invert the relevant rear speaker's input ports for a while. (+ to -, - to +) Don't forget that you have to hook up the other rear likewise. This will allow you to cheat your amp for a while, and let you test your channels without taking care of ohms.
Posted on Apr 20, 2007
  • 4 Answers
SOURCE: nad 214 amp
problem is- intermittent speaker relay. You can cleaned contacts or better upgrade relay to better one (sealed)  Dariusz
Posted on Feb 13, 2008
  • 319 Answers
SOURCE: power fault
You probably have shorted rectifiers and/or transistor(s) on standby board. Trouble-shoot rect bridge and cap. Feel stand by circuit transformer for abnormal heat, sure sign
Posted on May 01, 2008
  • 15 Answers
SOURCE: Speakers Cutting Out
I posted this solution on FixYa to help someone who had the same problem, or at least a similar problem. If you remove the slotted panel underneath the bottom of the receiver, you can gain access to the underside of the main circuit board. There are 3 relay units there, they are blue boxes that can be seen if you shine a torch down through the top. I found the solder joints on these relays looked as though they had broken away from the board, there appeared to be a dark ring around the pin of the relay. I re-soldered 4 of these connections, and, so far, that seems to have done the trick. Time will tell. These relay units connect and disconnect the speakers. There is one other relay that is mounted on a seperate board above the main board, that I can't access easily. If this one is also faulty, I will be un-able to fix it, as it would involve removing the entire guts of the receiver. If any of your technical team disagree with my remedy, or can offer any other solution, that would be appreciated. Thanks.
Posted on Sep 15, 2008
  • 30 Answers
SOURCE: no sound output
Known problem w/Onkyo. Resolder Q710 transistor on DSP board.
Onkyo is aware of this problem.
Posted on Apr 19, 2009
Amp power dips when heavy bass drives my speakers, at low volume, the blue light flickers with the beat of the music. i suspect that the amp itself is the fault. tried a different amp.
Suggest connecting with a fuse to a car battery. The current available from a ATX power supply is about 10 amps for the 12 volt circuit(see link).
For a 100 watt per channel amplifier would require a minimum of 17 amps for a RMS (root mean square/average) It is the peak power requirement which is significantly more that can be the problem.
ei http://web2.murraystate.edu/andy.batts/ps/PowerRatings.htm
26262737-5ntl554mom5lyewa1raj0eax-1-0.gif For a typical high output stereo the fuse would be 40 amps or more!
26262737-5ntl554mom5lyewa1raj0eax-1-2.jpg Hope this helps?
Aug 19, 2016 | RCA Car Audio & Video
Just bought laney rb9 bass amp, the limiter defeater LED doesnt light up when switch is in or out. how do i know if this is working or not?
Best to leave the limiter on unless you want to blow the amp and require repairs. Limiters protect the amp and also sometimes the speakers. The limiters reduce the gain when the amp reaches the maximum swing. If the gain were not reduced the amp would "flattop" which results in the circuitry saturating and massive distortion and if this condition is sustained, components can overheat or short out requiring repair. The LED MAY be just an indicator of clipping rather than an indicator of on/off. I downloaded the manual and what I have just said is CORRECT. The LED is a clipping indicator.
There is a caution regarding this amp and the sequence to turn power on. This amp does NOT have good speaker protection and you have to have the gain control down when turning on. The limiter, if you leave it on, might help protect your speakers when powering on. Most good power amps have circuitry to disconnect the speakers while amplifier is powering up and becoming stable, this one does not, so heed the warning and for certain leave the limiter ON... It just might save the amp and your speakers.
Mar 02, 2011 | Laney RB9 300 Watt Bass Head
Two problem don't know if they're related. I'll sometimes get the dreaded loud POP and then no sound when playing from our cable box or Ipod, I'll lose sound on the speakers in the main room but I still...
I have the same two problems! "Zone 2" works, but the main amp will make a noise and then stop working. Sometimes when I change the listening modes around it will start working. Lately, though, "zone 1" has gone out altogether.
Jan 12, 2011 | Onkyo TX-SR603X Receiver
If i turn the power on , it switch off by it self and the power light flicker red
The set powers off because there is a cut off by the error amp which controls the main relay to switch off for safety from burning out any circuits. It could be failure of the output drive/ the short in the speakers or failure of the error amp section. It is tricky to find out the actual fault because you will have to keep testing by elimination, disconnect power output section, preamp section, and check if this releases the power switching.. Helpful? Good day
Jul 08, 2010 | Denon 3991095008 Rc1068 Remote...
All lights flickering
Turn it off and leave it off till it is fixed.
There is a problem in the PMP5000 that is LIKELY in the PMP3000 as well.
The problem is arcing in the rear-most power amp near the heatsink.
When this gets bad, it will short out and fry the power supply and the amp if it persists. The arcing will trip the overcurrent sense and shut down the unit including the display until it finally goes completely.
I have repaired two of the 5000's now with identical problem. There is inadequate insulation in a multi-layer board in the rear-most power amp. The arcing occurs between the output lead of the switchers and the source lead circuit trace for the 9640 switcher transistors. The output switcher lead unfortunately is an internal circuit trace and hard to fix. Once burned, the board becomes carbonized and conductive.
NEVER run the unit without a speaker load on the unit.
Mar 30, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Does anyone has overheat problem with Behrigher EP2500 power amplifier? We had the amp for abut a year. The amp. has recently become overheat (hand burning) after 30 minutes operation. We set the gain to...
The last time I had a problem like this there was a defective transistor in the from end that was generating noise in the 30K range. Too high to hear and too high for the speakers to reproduce, but enough to put quite a load on the amp. Does this occur even with no speakers attached? If so, then put an osciloscope on the outputs and look for signals. WIth no input, there should be no output at all except for a little noise. You can also see if there is any DC on the outputs as well.
Please update this with what you find.
Thanks,
Dan
Oct 13, 2009 | Behringer EUROPOWER EP2500 Amplifier
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Leem m86t power mixer amplifier
probably blew the amps or the pre amp section
Sep 09, 2008 | Car Audio & Video
PDX 4.100 In Protect Mode..
According to the manual, the issue could be:
  • Internal issue with the amp circuitry.
  • A short on the speaker output(s).
  • Power source voltage is too high (aka above 14.5V).
  • Overheating.
The easiest thing to do is to try removing the connections to the speakers at the amp and see if the issue disappears after each set has been disconnected. Keep removing wires until both LEDs stay blue.
Mar 15, 2008 | Alpine PDX-4.100 Car Audio Amplifier
Technics SU-V2 keeps cutting out
An amp will cut out if the output protection circuit kicks in. This circuit compares output power against the preset level. Each channel has it's own, independent protector. There are calculations that can be done, but for a novice the rule of thumb is to "never use a speaker with a power rating less than the amp AND a lower impedance than stated". Typically using a 4 ohm load on a 8 ohm system is inviting disaster. Even if the system does not become a smoke generator, you might notice that though "louder", the sound quality is deteriorated. Many "audiophiles" often hook up some combinations of speakers to have "surround" without really understanding that the collective impedance actually changes (generally lowers).
Jan 21, 2008 | Audio Players & Recorders
51 people viewed this question
 Grubhead
Grubhead
