Home | Copiers | Smudges on scanner gla...
Copiers
Problem for Copiers
Generic problem for all Copiers
Smudges on scanner glass inside unit
By farcry on Oct 13, 2007
i have a cannon mp390 and there are smudges on the scanner glass inside the unit, is there any way for the glass to be removed and cleaned? any thing scanned comes out with these marks on them.
Comments:
Oct 16, 2007
- i have tried that, the marks seem to inside the unit under the scanning area. it looks almost like condesation, but its got a red sheen to it. i brought the printer a year or so ago but have never need to use the scanner untill now. every thing else is fine with the unit apart from these marks. cannon are not intreasted due to it being out of warrenty by a couple of months.
Clarification Request
Posted by longarche on Jan 09, 2009
The smudges are on the INSIDE of the glass... It has to be opened to clean it, because there's no way to get to them otherwise...
Same Problem
Jan 09, 2009
-   The smudges are on the INSIDE of the glass... It has to be opened to clean it, because there's no way to get to them otherwise... -   longarche
Best Solution
posted on Oct 15, 2007
Helpful)
jules_09
Rank: Wiz
Rating: 77%, 62 votes
hi im jules_09,the scanner glas should not be remove from the unit because if it is remove you might get a error code,so just get a soft cloth or a any kind of tissue and table tissue will do then apply a glass  cleaner on it then gently rob it on the scanner glass until the glass is clean just make sure the unit is off and ulplug.if the scanner glass is cleaned
Comments:
Nov 03, 2007
- hi im jules_09.have you tried cleaning it with a alcohol? or a metal folish?try it if your going to use metal folish on the scanner apply just a small amount let it dry then use a fine cotton cloth must be soft so u can not scrath it.try see if it work
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
I am a student in biomed and i am trying to find the problem with just one of these machianes 1)... (More)
Answer
my iR1022F copier front cover is closed but it still informing that is not close
Answer
When I scan a doc. to my e-mail it doesn't come through but it does show sent on the scanner
Answer
I have a Lanier Ld345c photocopier that has a intermittent paper jamming problem from the high... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 741
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
