Question about Equator EZ 3600 CEE Front Load Washer / Dryer
During short spin cycles between rinses it doesn't pump water out
Hi, I had my washer for 7 or 8 years, no problems except for now. During rinse cycles it's supposed to pump the water out then start spinning and continue pumping water out, then take fresh water and do it over. Unfortunatelly it will pump the water out but when it starts spinning it then stops pumping the water out. The pump makes noise like it's pumping but it's not. I unscrewed the filter during one of those spins and about 2 gallons of water came out to the floor, I then looked inside and it seemed like the water was trying to come back from the pump, like if it was pumping the wrong way. Does anyone have any idea what's going on? It just makes rinse cycles inefficient cause the spin will extract the dirty water but then not pump it and then another rinse cycle just adds clean water to the dirty water instead of an empty machine. Thanks!
  • billybengal May 12, 2009
    The pump works, it only doesn't work during the first 3 spin cycles during the normal wash cycle (I don't use the other cycles). During the final spin the pump works. So the pump itself is fine it's just seems like the washer was "forgetting" to turn on the pump even though it sounds like it's working. I will unscrew the back and observe the pump, or maybe disassamble it (which is a pain cause I have a friend who has the same washer and I put her pump apart and then tried to put it back together and it was a pain). I'll post with the results.
Try looking to see if the little motor is spinning the drain pump. It is in the bottom right. Occasionally I get a small metal shard which locks the pump and therefore-no draining. You can undo everything and check the pump for blockage. Then if need be, replace the mechanisim. The parts are all on line, as is the manual. or call 800 776-3538
Posted on May 12, 2009
3 Suggested Answers
  • 1122 Answers
SOURCE: washing machine is not rinsing and spinning
LID SWTICH BAD,THANKS-MIKE
Posted on Jul 23, 2008
allbrands
  • 600 Answers
SOURCE: My washer only runs until it's time for the
hello, it sounds like a failed lid switch part #3949247 it wont rinse or spin with a bad lid switch. it also wont rinse or spin if there is no cold water to the unit.
Posted on Jun 08, 2011
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
The washer will not drain water during the rinse and spin cycle
The pump is not switched on during the cycle and this circuit must be traced from the timer output. However if the drain works well in the last cycle then the pump is alright. Hence the pump circuit switch during the rinse and spin has to be traced and confirmed. Good day
Aug 12, 2010 | GE Washing Machines
Maytag top loading washer 1994 does not spin during rinse cycle
The problem will be the spinning coil is cut off or short circuited kindly replace the motor and check it
May 17, 2010 | Washing Machines
Agitator won't spin during wash/rinse cycle. It's
There could be several reasons for washer not to fill .Fill washer with water and wait for the timer to get to the drain mode.Unplug the washer from the electric outlet.Open the case, and disconnect the water hose from the outlet of the water pump.If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.Reassemble hose from step 3.Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
Thanks for contacting Fixya.com
Nov 03, 2009 | Washing Machines
Water not draining during rinse cycle
check the drive belt for the pump under the machine
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
429 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
