F9k1102v2 connects to Internet for five minutes then loses connection
SOURCE: Router loses connection to Internet
Note : The steps below are applicable only for Belkin routers.
Note: The wireless card in the computer will
automatically detect the change in channel number on the router and
will update the channel on the card.
CauseYou
are not able to connect wirelessly mainly due to environmental
interference. When the wireless channel is set to auto, the router will
cycle to though channels when it detects significant interference. When
the router changes channel the wireless connection will reset itself
and disconnect all wireless clients connected to the router.
SummaryWireless signals
are prone to interference from cordless phones and electrical
appliances (e.g., vacuum cleaners, microwave ovens). This is the reason
wireless connections can drop. This article explains how to overcome
frequent wireless disconnections by changing the channel number
(frequency) on the Belkin router.
SOURCE: wireless ready laptop not getting connected to internet through belkin router
You may want to check if the wireless switch is "ON"
on the laptop most wireless ready laptops has either a
button or toggle switch to enable the wireless radio..
if it's already enabled and you still cant connect to
the wireless network,try changing the wireless channel
from the router.
SOURCE: Macbook loses wireless internet connection
Hi 8233 is a good choice for a router
Here's your solution
1. These steps are to be performed strictly from a computer which is wired.
2.Even if you are using your mac book turn of the airport and connect it via a cable.
3. Open your router setup page by typing in 192.168.2.1 on your browser tab or typing i http://192.168.2.1 in the run window
4.An rsp will open and on the top right hand corner of the screen it will say Internet status:: connected
5.On the left hand side change you"ll see channell under wireless
6. Select it and change it to 6 or 11 for best signal strength
7.Now to the most important segment 8233 has a piculiar issue with its extra strong security
8.On the left hand side under wireless you"ll will see an option called wi-fi protected setup
9.Select it and turn it off reboot router and wow the problem should definately be resolved .
Then turn on airport and go wireless along with your wife.
10. You will still be secure with your data through security option on your router (wep or wpa )whatever you use .
Thank you and just let me know if it worked or not
SOURCE: Belkin N-150. I cannot connect to the internet. The router and
You may need to call your internet provider if this is a new router.
If this is not new, was it working before?
SOURCE: belkin n150 F6D4230 wireless router. lose ability to
try to upgrade the firmware of the router. that will help you.
For this you will need to connect the computer to the router. Do not upgrade the firmware of the router using the wireless computer.
You will need to download the new firmware from the manufacturer's web site. Then open the router set up page and upgrade the firmware of the router.
Click here for more information about routers and network
