Question about Nokia 6300 Cellular Phone
Music files such as mp3 wma etc etc work , but the ones with a bit rate of 64 do not. Is This normal or can it be resolved??
  • amardeeppuaa May 18, 2009
    Cheers mate got a converter and worked perfectly
    Sniper:
  • 61 Answers
Hie dear,
the standard mp3 song is:
bit rate = 128kbps
channels = stereo
audio sample rate = 44100 khz
reducing bit or sample rate means compressing the song, although it can be played on max of handsets.
bt u can use the mp3 converter softwares to increase or reduce the bit or sample rate to make the bit/ sample rate standard.
bunty
Posted on May 13, 2009
I just bought a iriver E300 which is described as "the new all in one pragmatic player", so far its been nothing but problematic!!! there are no instructions, and i cannot work out how to get my...
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player. For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track. Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Aug 20, 2011 | Audio Players & Recorders
WHEN I DOWN LOAD FILES TO MUSIC IT SAYS IT CANT SUPPORT THE FILE I HAVE HAD PROBLIMS WITH THIS UNIT SINCE I GOT IT.
go to your user manual. The format that the songs are in may not be supported. for example: if your player is a mp3 play the song have to be mp3 formate. it wont play WAV or AAC/MP4. looking at your manual found online here
http://www.p4c.philips.com/files/s/sa5285_37/sa5285_37_pss_aen.pdf
Compression format: MP3, WMA, AAC
•ID3 Tag support: Album title and artist name
•MP3 bit rates: 8-320 kbps and VBR
•WMA bit rates: 5-192 kbps VBR
•WMA sample rates: 8, 11.025, 16, 22.050, 32, 44.1, 48 kHz
•MP3 sample rates: 16, 32, 44.1, 48, 11.025, 22.050, 24, 8 kHz
•Digital Rights Management: Windows Media DRM for Portable Devices, Supports download & subscription music services
these are the formates supported. also make sure the music is in the proper folder
Feb 24, 2010 | Philips GoGear SA5285/37 Digital Media...
Nextar MA933A-20P will only play factory installed files.Music files add are present but will not play. Will only shuttle between classical and fast dance files
The following may help:
1) Ensure that your Music files are of the correct format (usually .MP3 or .WMA suffix and usually NOT .WAV which is the standard CD format)
2) Ensure that you upload your music .MP3 or .WMA files to the correct directory and names are not excessively long as some MP3 will limit the max name length. If you know a working song on your MP3, locate the directory it resides in and put your songs there. 3) If you have uploaded your songs with the correct naming convention/suffix and you now see them in your player list but they will not play, then your MP3/WMA file has non-compatible 'property' whcih is usually the encoding 'bit rate' (usually anything under 128mbps fix rate is good but you can see what is acceptable by looking at the 'properties' of your working songs that are on your MP3 player) ps. To reformat your Music files to the player acceptabel format, you need to download and use a 'Audio Media Converter'.
Dec 20, 2009 | Nextar MA933A MP3 Player
I downloaded music onto my element gc-820 then go to listen and it says no file what the hell
- Ensure that your Music files are of the correct format (usually .MP3 or .WMA suffix and usually NOT .WAV which is the standard CD format). - Ensure that you upload your music .MP3 or .WMA files to the correct directory and names are not excessively long as some MP3 will limit the max name length. If you know a working song on your MP3, locate the directory it resides in and put your songs there. - Lastly, if you have put your song with the correct naming convention/suffix and you now see them in your player list but they will not play, then your MP3/WMA file has non-compatible 'property' whcih is usually the encoding 'bit rate' (usually anything under 128mbps fix rate is good but you can see what is acceptable by looking at the 'properties' of your working songs that are on your MP3 player)
Dec 19, 2009 | Sears GC-820 MP3 Player
It wont play the downloading songs
Dec 19, 2009 | Element Electronics Zr-Element Digital...
Music downloaded as WMA from PC to MP3tech MP3S4 wont play
Your player should support both MP3 and WMA files. What happens when you try to play an MP3 instead? Have you tried other bit-rates? Those you are trying may be too high or low.
Jun 29, 2009 | Audio Players & Recorders
How many songs could 1GB memory card hold?
It depends on the format of the music files, i.e WMA or MP3 ATRAC etc, and the bit-rate(size of the the music in megabyte).
MP3 files tend to have bigger file size compared to WMA.
Mar 02, 2009 | LG Vu CU920 Cellular Phone
MP3 player will not accept WMA files
the wma bit rate might be too high for the player to read it.try reducing the bit rate or convert in into an mp3 format.any normal can do this.for example say audio jack.safe and user friendly software.
here is another software from download.com.it should solve the problem.good luck.
click here to download the converter
Jan 04, 2009 | Philips GoGear SA261 MP3 Player
Can't put new music on player
Hi Raxter. As long as you can save files to the player (seems like pictures and video work just fine, right?), then the player is not experiencing any corruption or firmware issues. Perhaps the issue lies with the songs you're synchronizing to the player. There are several reasons why you would encounter errors when synchronizing songs to the player: (1) File type is not supported by the player -- MP3 (with a bit rate of 128 Kbps) and WMA files (with a bit rate of 64 Kbps) are the only supported music file type. MP3 music normally converted via iTunes is not guaranteed to work on this player. (2) Windows Media Player 10 is the only tested Microsoft player version to work on this player (trust me, I've had my bouts with other Windows Media Player versions lol.) Version 11 works, but I have had issues with the player experiencing errors when syncing songs. (3) If the songs are licensed or subscription, it's probably best that you use the subscription provider's media software to "synchronize" the songs into the player (like Rhapsody or Napster player. Music Match often causes the player to "restart" -- I have no idea why, better call them). Some music providers are unable to actually support the player (or recognize it for that matter). It would be best if you contacted the subscription provider to give you instructions on how to synchronize the songs from their website. If your songs are non-licensed songs (like songs from ripped audio CDs, Limewire, etc), then it's best to switch the player's mode to MSC and transfer the songs by simply "Dragging and Dropping" or "Copy/pasting" the songs to your player. To switch your player's mode to MSC, navigate the Menu as follows: Menu >> Settings >> USB Mode I hope that would resolve the problem you're encountering with your player. There is another way to reset your player, but I'm hoping these options would actually let you transfer files successfully. Let me know the results.
May 16, 2007 | SanDisk Sansa e250 MP3 Player
Empty folder
There may be possible reasons why your Sansa E250 would display an message on the LCD even when you've downloaded files to it: (1) The music file type is not supported by the player. Sansa players support only MP3 and WMA files. To determine what file type your have, right click on the file type and it should display the "properties" dialog box. Check if it is MP3 or WMA. For example, iTunes music files will not work with the player, nor will WAV or MIDI files. (2) Your music files are supported but the bit rate is not within the range that the player supports. Sansa players support MP3 files up to 128 KBPS and WMA files up to 64 KBPS. You may need to use a 3rd party music file editor to convert the files to a supported bit rate (3) You may have saved your music files in a folder and copied the folder to the player. Your Sansa E250 will not recognize folders. Either save them in the root directory or inside the "Music" folder -- your player's default folder for music files. Hope this info helps :)
Apr 12, 2007 | SanDisk Sansa e250 MP3 Player
Nokia 6300 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
