Question about Sony VPL-CX80 Multimedia Projector
Reset Lamp Hours
How do I reset the lamp timer on the SONY VPLCX80 projector? The manual says to press the reset button but when I do it says "NOT APPLICABLE!"
Reset left left and enter
Posted on Aug 18, 2010
Hi have vpl-es3 i changed the lamp but i have massege replace the lamp
Posted on Nov 17, 2009
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    How do I reset the lamp timer on an Acer X1320WH
    Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
    Here is the manual in PDF, on page 33 you can see how to reset the lamp hours.
    http://www.roscorrentals.com/equipment_manuals/Sony%20VPL-PX31.pdf
    Dec 21, 2013 | Computers & Internet
    Need to reset lamp. replaced lamp and installed new lamp.
    Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
    Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
    How do I reset the lamp timer on the Sony VPL-DS100?
    Yes, press RESET, <, >, ENTER keys on remote simultaneously to reset lamp timer. Display of lamp will also change to zero.
    Make sure projector is just plugged in and should not power On (in standby mode) to reset lamp timer.
    Jun 03, 2010 | Sony VPL-DS100 Multimedia Projector
    Sony projector - replacement lamp counter
    • Set the projector in standby mode.
    • Press the following buttons on remote control in following order for less then five seconds each...
    • RESET,
    • ENTER
    Lamp timer is reset now.
    This is also mentioned in user manual page 50
    Thank you.
    Dec 12, 2008 | Sony LMP-H130 Projector Lamp Projector...
    Lamp replacement
    Hi there
    You need to reset the lamp timer.
    Mar 11, 2008 | 3M (EP7640ILK) Projector Lamp for MP7640
    Reset Timer Lamp Sony VPL-HS60 projector
    To reset the lamp timer:
    1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
    2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
    3) Timer should now read '0'.
    Jan 14, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
    Reset timer
    FROM THE PROJECTOR
    Press and hold the EXIT Button for 3 seconds to display the total used lamp time.
    Then Press the MENU button on the projector during the lamp hour message.
    The press the <-- or ---> button to reset lamp hours.
    Press EXIT to leave.
    Nov 15, 2007 | BenQ PB8220 DLP projector 2200 ANSI lumens...
    Sony VPL-CX80 Multimedia Projector Logo
    770 people viewed this question
    Top Sony Office Equipment & Supplies Experts
    shaun taylor
    Jaime Hernandez
    Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
