Question about Dell OptiPlex 170L PC Desktop
Pci simple communications controller not found
    Sniper:
  • 79 Answers
That would mean you need a modem driver installed for that PC, or your modem is bad. Now this is refering to a dialup modem not a broadband modem.Goto Dell website and under support you can enter your PC moodel number and download the Communication Modem Driver. I have provided you a direct link below:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=PLX_PNT_P4_CEL_170L
If this doesn't help, seek out a repair shop and get a new modem installed.
If this helps please rate my solution.
Posted on May 11, 2009
Pci simple communication controller
PCI Simple Communication Controller is a 56k PCI Modem, to know which exactly you have, use Unknown Device Identifier ( Download Here for free ), that will tell your the Model and Manufacturer, then Google for the drivers.
Sep 27, 2013 | Western Digital Computers & Internet
No network driver after reformatting the system.....window 7 ultimate....no PCI Simple Communication Controller....no Standard VGA Graphic Adapter.....
If this is the original operating system you can download the drivers at the hp support website.
Just type in your model number (can be found on a white sticker on the bottom of your laptop).
The pci simple communications controller is the phone modem.
And the vga graphic adapter is your video or video card.
http://www8.hp.com/us/en/support-drivers.html
Jun 16, 2011 | HP Computers & Internet
Drivers for pci simple communication controller for toshiba
Check out the Toshiba Support Site.
Select your Toshiba model to download the require drivers.
PCI simple communication controller - ie the 56K internal modem drivers.
Hope it helps.
Mar 23, 2011 | Computers & Internet
Motherboard Simple PCI Communications Driver Code 28 for modem
Hello, Mike.
In case you still need this:
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
Hope this helps.
Mar 29, 2009 | Gigabyte GA-7VA Motherboard
Need a ethernet controller & pci simple communications controller
Try this link: http://partner.atheros.com/Drivers.aspx
You might be able to find something here.
Mar 14, 2009 | Biostar 945GC-M7 TE Motherboard - v6.0,...
Multi media audio controller pci simple communications contoller sm bus control video controller vga compatable all with yellow question mark against them
multi media audio controller
sm bus control
I Have A Service Tag No. but when i Write the Number He Is Not Working
i Need Your Help
Nov 03, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
Dell OptiPlex 170L PC Desktop Logo
1,111 people viewed this question
Alun Cox
