Question about Garden
Siphon hose sprays water out rather than si phoning chemical into the water mix
  • 1 more comment
  • Anonymous May 12, 2009
    WHEN I TURN THE WATER ON AND START THE ENGINE THE WATER SPRAYS OUT OF THE SIPHON HOSE INSTEAD OF SUCKING UP THE SOAP. I REALLY GOT A SOAKUNG BATH WHEN THE SIPHON HOSE WENT WHIRRLING INTO SPACE THIS MORNING.
  • boskone May 23, 2009
    I have the same problem, It started abruptly. When the wand is in the low pressure setting, the siphon works too well and will **** down a gallon of cleaning fluid in about ten minuites, when it's in the high pressure setting the pressure is greatly reduced due to the water spraying from the siphon port. I have disassembled and checked all of the check valve components and they seem fine, but the problem continues......advice anyone?
2 Suggested Answers
  • 18 Answers
SOURCE: cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
Posted on Jun 27, 2009
How do i prime my troy built 2550 psi pump for the soap?
You have to use a low pressure nozzle ( usually black with very large spray opening) With the low pressure nozzle siphons your detergent in with the spray water . If you are using a high pressure nozzle the soap will not prime.
Oct 26, 2014 | Garden
Why the water is running from detergent siphoning tube?
The siphoning mechanism on almost all power washers use "The Venturi" effect to suck up the detergent. Basically, there's no pump...the force of the water passing the siphon hose causes a vacuum which draws the detergent up the tube. There's a small ball that is supposed to fall and block the tube when the trigger is released so it sounds like it got jammed up in there somehow. You could it apart and free it up but I would recommend just purchasing an external detergent dispenser. Home Depot carries them for about 15 bucks. They allow you to use soap with high pressure and bypass the always problematic siphon system.
Jun 08, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Soap dispenser not working
chemical injector activates only when low pressure is utilized try this remove hose from triggergun assembly with the water turned on engine off allow water to free flow out of hose remove the chemical hose from the barb located at pump with a paperclip or needle insert it into the hole of barb and slowly separate the ball inside the barb you should here it siphon and try not to look directly at the port you may get sprayed once freed reinstall all back together and try again.;0;0
Aug 02, 2013 | Karcher Garden
Husky HU 80522 pressure washer - some pressure to the spray gun. water coming from the pump goes straight to the sifon hose used for detergent. Can this line be clamped of if not used?
This unit has a Faip pump on the unit, no water should come out the chemical injector. The chemical injector can be closed off with no problem by installing a plug where the chemical injector hose bard is currently located.
You can also replace the chemical injector, here is a link to view the part.
www.allpartsinc.com/ProductDesc.aspx?code=KTRI91351
Mar 29, 2012 | Garden
Using Ortho weed and crabgrass concentrate... what setting do i use on my Ortho hose end sprayer
Here is what they say at their site:
How do I use the Ortho Dial 'N Spray Multi-Use Hose-End Sprayer?
Pour product into jar, and set dial to amount indicated on product label and begin spraying. This sprayer siphons product and mixes while spraying; it does not mix inside the sprayer.
http://www.scotts.com/smg/catalog/productTemplate.jsp?bodyCssClass=scotts+blade+scotts+product+faqhelp+en&tabs=help&navAction=push&bodyId=product_faq_help&proId=prod70022&title=p_product_general_help_title&itemId=cat50094&id=cat50008
Which means it is not determined by Scotts, but by the product you want to disperse with the Dial N Spray.
And here is an exact description of the settings:
{ ... There are 14 settings in all and they range from 1 teaspoon per gallon up to 8 ounces per gallon. You will find the dial at the on the top of the sprayer. ... }
http://www0.epinions.com/review/Dial_N_Spray_Hose_End_Sprayer/content_465229876868
Aug 19, 2010 | Ortho Dial N Spray Hose End Sprayer
I have a unionpower up 150 premium pressure washer theirs a small hose that comes out at the back of the engine with a small filter at the end of the hose pipe I dont no what its for
If the hose actually comes out of the pump (look carefully) it sounds like the chemical pick up line. It would most likely be clear plastic tubing with a plastic filter at the end. You drop this into your chemical (soap, etc) container and under low pressure it will siphon the chemical and apply it through the wand.
Jul 29, 2010 | Garden
We have the black tip on and have placed clear plastic hose to black plactic and the brass valve at the bottom of the washer and no siphoning
chemical injectors are terribly designed, Flimsy to say the least. They all use a check valve (ball bearing) held agaunst a steel seat by a tiny spring. Yours is either stuckshut or rotted away from using bleach and not cleaning it well.Feel free to take it apart, clean, inspect and re assemble, If its a low cost machine like a troy bilt or any other that uses an aluminum pump your probably wasting your time. Use a hand sprayer like the one you use for weeds and have someone else spray the chemicals while you use the washer with water only
Nov 07, 2009 | Garden
Need to clean coils
A power (pressure) washer generates too much pressure. It will bend the fins on the tubes.
Always isolate the power from the unit prior to opening the unit to perform any work. Remember that there can be both 220 and 110 volts present (main and thermostat), so be sure that you have it off.
For the outside unit, appliance parts supply stores sell a chemical that you can spray on with a garden sprayer, and then hose with a garden hose and spray nozzle from the inside.
For the inside coils, you can get good results with coil cleaner from one of the "home hardware" stores, or from an appliance parts supply store. It is in an aerosol can. This is sprayed on the coils and also hosed off.
One must be very cautious when using these chemicals, taking precautions to protect your eyes and exposed skin, as these chemicals are caustic or acid in nature and can easily burn your eyes. They also foam up in between the tubes/fins and on the surface, displacing the dirt.
For inside coils, you can remove the outside layer of debris with a medium brush and then spray. Fin brushes and combs are also made for this purpose. I usually follow this with another brushing and spray again, then wash down from the inside. Here again you need to be careful. The aim is to remove the build up, and flush off the chemical residue, without damaging your coils. It usually takes me at least two cans of cleaner for an inside coil. I drag a garden hose in the house and wash the coil down in bursts, to avoid running the collection tray over onto the floor. Outside coils are usually clean enough after one mixed container in the garden sprayer. Some aerosol sprays are deemed OK for both the inside and outside coils, and I have used them satisfactorily. Again, about two cans is what I usually need. The key, in my mind, is to apply and flush thoroughly from the inside towards the outside.
Hope that this was helpful,
--W/D--
Jul 23, 2009 | Heating & Cooling
Instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Mar 16, 2009 | Garden
Got a karcher 410 water pressure passed down to me without directions need help working it
Fairly simple to opperate. Connect water supply hose. Connect wand hose. Plug in, turn on water supply and turn on. Then squeeze the wand handle to spray. With mine, there are times when the unit looses pressure, but if you leave it running, it seems to recover. Also note that you can turn the flare at the end of the wand for a soft stream versus pressure spray. I have had mixed results with the pull out clear tube that is supposed to siphon liquid soap into the mix.
Apr 05, 2008 | Washing Machines
Garden Logo
290 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
