Remove Front panel for cleaning. Frigidaire FAC127P1A4 Air conditioner
Need a part number for a "drain pipe" that would fit in the bottom of the drain pan so I can redirect condensate for Frigidaire Air Conditioner, model FAS257Q2A
Posted on Apr 01, 2010
How do you take front frame off Frigidaire FAS257R2A win dow a/c to clean?
Hello Scott, that's a great question!
In order to remove the front frame of your Frigidaire air conditioner you should be able to pull from the front tabs to remove the front panel. I have included your manual and installation instructions and I hope that this information is helpful for you. -Matt
Frigidaire Manual Search Results
Feb 24, 2015 | Frigidaire Washing Machines
How to remove front cover of FAX050S7A
Good Morning Friend,
I understand you want to know how to remove the front cover of your Frigidaire air conditioner, model# FAX050S7A. Typically, this is not a do it yourself action, as there are no step by step instructions on how to remove the front cover. I suggest either contacting the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire FAX050S7A Air Conditioner
How do you clean the coils?
I understand you want o know how to remove the coils to clean them on your Frigidaire air conditioner, model# FAS257S2A. You will not be removing the coils. If you will please start by cleaning the filter like so:
• Tilt the panel out by grasping the panel from both sides, just below the controls and the air directional louvers, and gently pull to release. Pivot the panel on its hinge's and remove the filter.
• Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing.
• Or, instead of washing you may vacuum the filter clean.
While you are cleaning the filter, the coils will be located behind the filter area, you can clean them with a vacuum extension. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FAS257S2A WallWindow Air...
Can i take my frigidaire ac out of the case without removing it from the window?
Good Afternoon Friend,
I understand that you want to know whether you can take your Frigidaire air conditioning, model# FRA256ST2, out of the case, without removing the case from the window. Yes you are. Below are step by step instructions for removing your air conditioning from the case.
    1)Unplug your air conditioner.
    2)Take the front grill off.
    3)Remove the filter.
    4)There are four panel screws, two on each side of where the front grill and filter were. Remove these screws.
    5)Gently pull out your air conditioner.
    For replacing your air conditioner, follow the steps in reverse. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer light status has changed successfully. Hope this is helpful.
    -Best regards-
    WP
May 31, 2014 | Frigidaire FRA256ST2 WallWindow Air...
How to remove front cover for cleaning
I don't know too much about your particular make / model but most window units have a 1 piece front cover which is usually held on to the main cabinet with 1 or 2 screws at the sides and 1 or 2 behind the filter panel. You will need to remove the front panel to remove the vents as they are usually fitted from behind the panel.
May 31, 2010 | Friedrich QuietMaster SM18J30BR Air...
Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Jun 30, 2008 | Frigidaire FAH08EJ1 Air Conditioner
Front panel FAH125P2T
look for some clips at the sides,or screws at the front. the top portion is also clipped to the metal housing.
Jun 27, 2008 | Frigidaire FAH125P2T Air Conditioner
Heating & Cooling Logo
304 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
