Question about Toshiba Satellite A15-S157 Notebook
92 buick lesabre
Hit on right rear at wheel well, wheel pushed in at top what could be the problem?????thanks
  • whatarush57 May 11, 2009
    it is a car problem
  • Jerry Willis May 11, 2010
    Sounds like a car problem. Not a computer problem.
  • 21 Answers
I'm sorry there must be a mix up. It was posted in the computer section Under Satellite / PC Notebook.
Sounds like the impact from the accident to the rear may have damaged the front end.
I don't have the expertise with vehicles to tell you how to fix it. I'm better with computers.
Posted on May 11, 2009
Upper shock mount rear 97 buick lesabre
bolt at the wheel hub and one at top of wheel arch
Oct 13, 2012 | 1997 Buick LeSabre
How do you change the wheel bearing 92 buick lesabre
Remove wheel, brake caliper & bracket,axle nut then the three bolts holding the hub and bearing in.
Oct 20, 2011 | 1992 Buick LeSabre
How do you change transmission fluid? where is the pan located on 92 buick lesabre? Does it have a blot? Thanks
should be in the front beside the motor if im thinking right they were front wheel drive cars
Nov 10, 2010 | 1992 Buick LeSabre
What size are stock tires for this car?
1999 Buick LeSabre Custom Front and Rear Tires P205/70R15
1999 Buick LeSabre Limited Front and Rear Tires P205/70R15
1999 Buick LeSabre PP (*) Front and Rear Tires P215/60R16
(*) PP = Performance Package
Other details can find in the Buick-Lesabre-Owners-Manual
Hope helps (remember rated and comment this).
Aug 06, 2010 | 1999 Buick LeSabre
Where is the flasher fuse located on a 92 buick lesabre?
the manual said it's under the steering wheel
May 19, 2010 | 1992 Buick LeSabre
Hit on right rear at wheel well, wheel pushed in at top what could be the problem?????thanksComment posted on May 11, 2200+9-
I don't understand your question fully (Hit?). If you were involved and a collision and your tire rubs on the fender, get the fender fixed ASAP! Tires can get peeled like a banana if they come into contact with any sharp piece of metal, and if its rubbing on the inner fender, then friction heat caused by this can cause the tire become weak in that area and subsequently blow out.... If that is not the problem, or case then her are more causes for tires rubbing...
Tires "Out of Alignment", non-factory rims and/or tires, wrong size,width, rim "off-set" etc., suspension coil springs and. or shocks (car sitting lower than usual), twisted chassis due to accident or other impacts
May 11, 2009 | 1992 Buick LeSabre
92 buick front end wobble
if it is a belt in the tire, when you slide your hand over the tire you would feel a bulge that feels like a air bubble. if not than you need to have them check the wheel bearing and the power steering rack.
hope this helped
please rate well.
Mar 04, 2009 | 1992 Buick LeSabre
Power antenna won't turn off
There is not enough information listed here to properly diagnosis the problem, so will I make a guess. I am assuming that the antenna won't go down. The antenna unit is in the rear wheel well on the right side of the car in the trunk area. Pull back the matting to expose the antenna. There you will see a wiring harness. Disconnect this harness. The antenna will then either stay up or down.
Oct 11, 2008 | 1992 Buick LeSabre
Toshiba Satellite A15-S157 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
