Question about Car Audio & Video
Luxman Digit synthesized stereo Receiver AM/FM & Phono not work'g
Hello members:I recently pick up a used Luxman digital Synthesized AM/FM Stereo Receiver R-115 together with disc player D-373 and the cassette deck K-110W from garage sale without remote controls and owner’s manual.  I am a retiree not very familiar with audio connections, without the owner’s manual, I can barely able to put the Compact Disc Player D-373 and the Stereo Dual Cassette Deck K-110W together with the R-115 and it works well. When I connect my old turntable (Lenco L-75) to the R115's  PHONO, it doesn’t work (it works well with my other receiver); also, the AM / FM radio are both quiet.  I check the speaker connections which is OK (as I said before it works well on tape deck & CD player), I don't have an antenna instead, I put a copper wire approximately 24" length to the FM loop, but I don't have an antenna for AM because I don't know how to do it.  The results:- There are different frequencies and signal strength shown on window for AM but no sound even when I cranked the volume to the maximum; on the FM, there are a few weak signals on the window, some of them I can barely hear it  when I crank the volume to maximum.   I have no idea if the R-115 needs repair or just I don’t know how to do the connections.  Members who have the Owner's manual for this model R-115, please jump in (I have checked almost the entire web including dealers and Luxman Corp Japan/Korea without luck). All members in this community, please extend your helping hand for guidelines and suggestions, I need all the helps I can possibly get.  Thank you folks in anticipation.  User-pat4307
  • pat4307 Jul 13, 2009
    Hello Mikegrundy, re Luxman digital syntheszied stereo receiver R115.
    Thank you for your response may 25 but I read it just now, I still need the manual, I really appreciated if you would send me copy. I don't know this work, here's is my email address if you could send it : pat4307@hotmail.com Thank you again.
Unless your record player has a built in ground that you can attach to the luxman,, your luxman wont play it. Luxman requires your record player to be grounded. I had the same problem and my solution was to get a luxman record player so it can be perfectly matched up. Hope that helped
Posted on Jul 07, 2009
My name is Mike Grundy.I have the manual for this amp.Let me know if you syill need it and I can send you a copy.
Posted on May 25, 2009
The problem is still there, but I am expecting HELP fir free.
Posted on May 13, 2009
Is there a way to reset the Onkyo quartz synthesized tuner amplifier R1?
Hi Madaline, all you need to do is to unplug the unit from the AC outlet for a least an hour and the unit should reset, Thanks, JT
Nov 09, 2015 | Onkyo Audio Players & Recorders
How do i hook up speakers to my MCS 3873 integrated stereo amplifier and 3051 quartz synthesized stereo tuner?
have fun trying to find that,why dont you just hook them up by the labels on the equipment,out means from input means to
Jul 28, 2015 | Audio Players & Recorders
Can I put my micro sd 16gd into this and play music through usb on car stereo?
To my knowledge, USB ports on smartphones are only used for transferring files to/from a PC. You'll need either a mini-phono (1/8") input on your car stereo and a male-male mini-phono adapter cord or play to a Bluetooth receiver that either transmits to your car's FM band or has an audio input to your car stereo. (Like the example on Amazon)
Cootree Portable Car Bluetooth 3 0 Audio Music Streaming Receiver Adapter...
May 02, 2015 | Cell Phones
Recently I bought a Harman Kardon HK 3770 Stereo receiver. My question is " can I use a Bose 901 Series VI speaker with this receiver?, since I plan to buy a 901 S VI speaker.. The receiver has no tape...
From the description of the Harmon Kardon, it sounds like you should be able to use the speakers, but you will not be able to use the active equalizer. The equalizer is designed to be cabled into the tape monitoring loop and allows you to listen to the equalized signal coming back into the receiver. Attach the +/- speaker wires to the right and left channel speaker connectors on your receiver.
Jan 15, 2015 | Bose Audio Players & Recorders
The stereo light on my marantz 2226b receiver does not come on even on a stereo fm station
my first question is does the light come on when you turn to Tape, Phono, Aux selection? If no lamp is blown, if it does come on then your tuner need to be serviced. FM tuner work is NOT for a novice. I would be glad to take a look at the unit.
Thanks
www.back2lifeelectronics.com
Sep 23, 2012 | Marantz Audio Players & Recorders
I have an Optimus STA-3500 Digital Synthesized AM/FM Stereo Receiver. If I buy an i-pod is there a place on the back of the receiver that it can be plugged into? If so, what kind of i-pod wire/cable...
It won't have "iPod" functionality but it can be played through the receiver.
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except one labeled "PHONO"). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT one labeled "Phono".
Jul 25, 2011 | Optimus STA-3500 Receiver
I have had the Grundig G400 AM FM LW MW SW FM STEREO PLL SYNTHESIZED DUAL CONVERSION I have no Manual and can,t install my batteries correctly I would like to purchase a Manual if it is possible to do so...
This link will take you to the Grundig/Eton site where you can download and print the complete manual for your radio:
http://www.etoncorp.com/upload/contents/307/G4000A_manual_lowres.pdf
Bill B.
San Antonio
Apr 24, 2009 | Grundig G4000A FM/AM Radio
Car Audio & Video Logo
659 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
