Question about Indesit W 123 Front Load Washer
Wont spin WASHING MACHINE POWERS UP GOES TO START MAKES NOISES AS IF ITS ABOUT TO SPIN THEN TWO GREEN LIGHTS FLASH AND MACHINE STOPS WORKING.
  • Michael Masters
    Michael Masters May 11, 2010
    i need the complete model number and brand.
    Sergeant:
  • 399 Answers
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Aug 13, 2009
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
The machine fills and drains on wash cycle but willnot spin
C1. Your motor was stopped due to overloading, inbuilt device, reduce weight of clothes (put less clothes). Press 'stop' & 'cancel' to clear the display.
How abt a good rating? Thanks
Mar 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Wash light flashes
Hi LIANNEshaun,
I'm Harvey the Master Plumber.
Your problem is: you switch on dishwasher and it seems to start then light goes onto wash and the machine stops and green light flashes
Could we have the make, model and year please?
Feel free contact me again!
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Hotpoint 18 in. DC27 Slim-Line Built-in...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Apr 26, 2008 | Washing Machines
Wont Spin
Hi Vixxy, Which lights flash when you hear the beeping?
Jul 23, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Indesit W 123 Front Load Washer Logo
206 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
