Question about Goodman Heating & Cooling
Air in my condo in not evenly disributed
I have this problem since we moved-in to our 2 bedroom Condo/townhouse and we have a Goodman Airhandler. The air is not evenly distributed over the house. The other room is more colder/warmer than the other. What can I do to boost the fan speed. We have a celing type vents.
By the central air is about 11 years old.
  • Goodman Master
  • 1,144 Answers
I would look at having the ducts checked. Alot of them are "Flex" ducts and they collapse over time. Look for poor installation too. Sagging, hard bends and such. There could be the possibility that a duct may have come loose and some or none of the air is making it to the desired space.
I would also look at installing damper doors in the ducts. This allows for you to restrict air flow to one area which would help force are to the desired area.
I have heard of people installing in-line booster fans but I've never heard of anyone saying they work. Don't reccommend that.
Speeding up the fan will change the temp of the air to the space. Don't reccommend that either unless it has been installed at the wrong speed from day one. Outside shot but worth checking.
Good Luck and let me know how it works out.
Posted on May 11, 2009
Which will be the best location for buying a condo in Singapore?
Choosing a perfect location is one of the important think you should take care of while choosing a condo. The points you should keep in mind while choosing a location for the condo is:
1. The condo which you are choosing should be in the location, where you can get everything you need near you.
2. Must have Peacefull surroundings.
3. All important places should be there near the condo. such as school, restaurants, hang out place, stores, and much more.
I m staying in MARTIN MODERN CONDO, which is located in the perfect location, close to the river valley. I get all the things near me and I don't need to far for my requirements.
May 04, 2017 | Cars & Trucks
A/C compressor noise
It may be your contactor.
May 31, 2013 | Heating & Cooling
I have a Goodman CKL24-1k air conditioner. I live in a townhouse in Louisiana on the 2nd and 3rd floors. I set the temperature to about 73 degrees during the day so I can sleep bc I work the graveyard...
I lost you at my the end but the 2 ton unit should be able to cool 960 sqft. Sounds like a refrigerant problem. Air conditioners should cool the air 15 to 20 degrees. This means 80 degrees going into the machine in the return should be 60 to 65 degrees coming out in the supply. If you are in that range than it's likely never going to cool the space.
Jul 07, 2017 | Goodman Heating & Cooling
I have 2goodmanGKS9 gas furnaces(propane) installed on 27 Dec 2009. Both units are working. One is in the basement adjacent to the rear outside wall. Lower unit heats about 1200 square feet. Lower...
well lets start with the 2" pvc pipe. that is a combustion air intake it does not put air into the room, i hope. this is a 90% furnace and they should have installed it that way. there should be 2 pipes to the outside the other is combustion gases. the dust problem maybe caused by the air return pulling the air to that room. the bedroom normaly does not get the trafic that the rest of the condo does.so it would not have as much dust.
Feb 10, 2011 | Goodman Heating & Cooling
Just moved into a condo with a whirpool tub. the
Jets are in the closed position or the pump is shot.
Sep 25, 2009 | Home
2 to goodman ac unit model a24-08
Replace the fan relay switch in the airhandler(inside unit).
May 19, 2009 | Goodman Heating & Cooling
Smoke coming in my fireplace
try cracking a window so the vacum sucks the ajr up
Jan 19, 2009 | Vanguard International Blue Flame - Large...
Not cooling predictably
Possible causes are dirty filters, dirty condenser coil, dirty evaporator coil, or low referigerant charge. Any one of the conditions will affect heat transfer.
Check the filters in your indoor unit, If they seem to be clean and replaced on a regular basis, your evaporator coil is probably in good shape. Unfortunatley on some Weather King models even checking the evaporator coil is not possible due to the extensive amount of referigerent lines that block access to the coil without some major work including evacuating the refrigerant.
The most likely cause is a dirty outdoor condenser coil. On weather king models you will have to remove the casing that surrounds the coil because is is built in such a way that the condenser coil cannot be properly cleaned with the casing in place. Once it is removed make sure breaker is switched off and clean the coil with a water hose.
If your outdoor coil is not dirty then it is a refrigerent problem.
Jun 10, 2008 | Weather King 10AJA3601AH Air Conditioner
Heating & Cooling Logo
53 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
