Question about Olevia LT32HVM 32 in. LCD Television
I just moved and now have Direct TV and have a big
I moved and now have Direct TV and have a VZIO HDTV, big screen which worked well with my previous service - but does not work for volume on the new remote. It it an RC24 remote and there are no codes in the setup menu for VZIO and the ones the Direct TV guy gave me will not work either. My manual is in storage and the search method the Direct guy gave me has yielded no working code for 30 mins in the search mode - anyone just know it?
    President:
  • 1,077 Answers
Not all Vizio TVs use the same codes with their Vizio remotes also. That's why this is a problem.
Here's the possible codes from my Directv book.
11756 and 10178
If that doesn't work, you may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Posted on May 12, 2009
TV only detecting channels 2-13 should be detecting 2-63
Go back to the initial set up procedure for your Sharp TV and do a search for active HD channels. They will be decimal numbers such as 13.1.
Jan 13, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My big screen tv is about 3 inches to big to take down my stairs into my basement. Can it be dissasembled? Are there any sketches on how to dissasemble the speakers? Thanks Don
Yes but it would be easier to widen the stairs and just moving them can stop them from working so if you decide to take it apart just be careful, Manuals are available online but non are free
Dec 02, 2010 | Samsung HLT6187SAX 61" DLP HDTV
Direct tv plugged into av. tv on av. still says no
Hello. Use the remote control and push the input button on your tv, making sure that everything is on. Go through the input menu until you get your pix back. Regards, Joe
Jan 13, 2010 | Vizio L32 32 in. LCD HDTV
When I turn on the tv, I get the Direct tv signal
It ur Direct tv converter box,unplug and replug or turn power switch off/on again so the box can reboot get a new and updated informations.It well back in the air if not must call the direct tv customer service for the disk check,it not ur tv.
Sep 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Power makes a sound but does not power up
SAME PROBLEM AS YOU ROBERT! Same TV and same problem after pluggin in something else in another outlet. Did you ever solve this issue?
Please e-mail me at yanalou at aol dot com.
Big Screen Blues II
LOU
Dec 02, 2008 | Hitachi 46F510 46" Projection HDTV
Picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Oct 20, 2008 | Vizio L32 32 in. LCD HDTV
JVC HD-56G886 56INCH REAR PROJECTION TV
I fixed it!!!! If you can open one of the sides (on the JVC there is a little door with a screw), then you can clean the projector lense in the middle on the bottom. It kind of looks like a big light bulb. It seems there is just dust on the glass that is projected onto the screen. We had a big gray spot and cleaned it with a damp glass cloth and Ouila! It disappeared. I scored MAJOR brownie points with my husband for this one! He wanted to replace the TV!
Sep 25, 2008 | JVC HD-52G786 52" Rear Projection HDTV
HDMI input
The green screen is caused by light hitting the back of the tv. Either move the tv to a location where direct sunlight will not hit it or put up strong curtains. As for fixing the problem, do a search for JVC green screen reset on AVS Forum, its easy to do just dont have the info with me now. Keep in mind if direct sunlight hits the back of the tv it will do it again. I have put up some good curtians and ensure not to open them when watching the tv. Hope this helps. I am Hayward, have a nice day.
Aug 21, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Olevia LT32HVM 32 in. LCD Television Logo
207 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
