Question about Beyond Micro (BM120MD3U2) 120 GB USB 2.0 Hard Drive
External Hard Drive - Beyond Micro
Beyond Micro seems to have closed their shop and I've lost the power adapter of an external hard drive model - BMMDU2. The drive does not say the type of adapter (power/voltage etc.) needed. Just thought will post this question in case you know either about the power adapter for this specific drive or your recommendation of in general what to try. I have lots of important data on this drive so any help is much appreciated.
I have the same BMMDU2. It's used 12V/1.5A power suply.
Posted on Sep 20, 2009
  • 702 Answers
Most external HDD's require 12V and about max 2A.
Safe way to go is to try a 5V supply first and see if it works, better scale up with the voltage then down, but the 12 V is a requirement for the motor, while a scaled down 5V will be used for the electrics.
Posted on May 11, 2009
Driver window7 bm160md3u28m
You shouldn't need a driver for this. Windows 7 should detect it and be ready to go. Are you sure the power cord for the drive is working? Put your ear close to the drive and plug it in and listen to see if you can hear it "spin-up". It doesn't appear that Beyond Micro is even in business anymore.
Jun 01, 2012 | Beyond Micro Mobile / 160GB / 7200 / 8MB /...
Beyond Micro BMMDU2 wont show up on my laptop
might need to reset by turning both off
keep power for ext drive OFF
turn computer on
plug in ext drive usb(no power on drive)
turn ext drive power on
see if windows can ''see'' it now?
May 14, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Lost or misplaced power supply for Beyond Micro Micro Model BMMDU2 External hard Drive. Need info on Wattage input. Please and Thanks if you're able to hrlp.
Well, looks like Beyond Mico web site has gone to the great Beyond.
From units I have been able to find online, it looks like the power supply is between 20 and 40 watts.
The hard drive unit itself should be able to supply you with the required DC input voltage (hopefully there is some kind of label on the enclosure).
You could try one of these or something similar. It comes with 6 interchangeable heads and has adjustable DC voltage. This is just one of many available.
http://www.amazon.com/Hosa-ACD477-100-240V-Voltage-Adaptor/dp/B000Z31G3M
I cannot guarentee any of these supplied heads will fit your particular drive (same with the dc voltage). But some local retailers often have these types of adapters and you might be able to determine what size you need by looking at one.
I have used DC units similar to these in the past when I have lost a power supply.
Hopefully with a minimum of effort you can get a working solution.
Dec 28, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Beyond Micro BMMDU2 250 GB external hard drive not working
It is highly unlikely that it will work. A circuit board from the same make and model hard drive would be a better choice, but I think a fire damaged hard drive would not work with a functioning circuit board. It depends upon how much heat the hard drive was subject to.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their services. Depending upon how valuable your data is, I suggest you get a quote first.
Apr 01, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
I lost the power cord to my external hard drive.
Hi annabel_nyc,
You need to make sure that you get a compatible power adapter for that model. Most of Acomdata external drives use a 12v adapter, but not all. If you plug the wrong voltage into the drive, you do have the possiblity of frying your external. I'd check with your manual or post back your model number so I can look that adapter up.
Good Luck
Mark
Aug 30, 2009 | Acomdata Computers & Internet
My Beyond Micro External Hard Drive (Model BMMDU2) stopped working. I tried to plug it in to working outlets but it just doesn't power on. Can I access the Owner's Manual online?
Beyond doesn't have much in the way of tech support or manuals, but I can tell you that if it doesn't power up, a new power adapter will cost you as much as simply replacing the whole enclosure.
Take the device to a local PC shop and ask the techs there to move your drive into a new enclosure, they should be able to do that for $20-$40 and you will save a lot of headaches trying to deal with Beyond.
Hope this helps FixYA,
Chris
Aug 27, 2009 | Computers & Internet
I require a driver for our Beyond micro external hard drive.
It looks as though there is no driver support for beyond micro although the specs state that the drive is plug and play. which means you just plug it in and windows sets it up. other than that there are no software or drivers for it.
best of luck.
hope this helped.
please remember to rate me.
Mar 02, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Need to know the Power (Voltage) for buslink
Go to the Buslink WEB site, their support/contact page to requst info and or replacement power adapter.
www.buslink.com
Nov 26, 2008 | BUSlink Computers & Internet
Beyond Micro (BM120MD3U2) 120 GB USB 2.0 Hard Drive Logo
1,206 people viewed this question
Top Beyond Micro Computers & Internet Experts
Dean Rigsby
Dean Rigsby
Level 1 Expert
Joe Bit
Joe Bit
Level 1 Expert
Harry
Harry
Are you a Beyond Micro Computer and Internet Expert? Answer questions, earn points and help others
