Question about Black & Decker D2030 Iron
Iron saying "error"
My black and decker digital iron is saying "error". We want to open it to check any loose wire but can't open it.Any suggestion?
  • Anonymous May 19, 2009
    error message displayed - beeps continuously & won't heat up
My **** is to big for my girls friends ***** how do i get it in?
Posted on Sep 19, 2009
Short in wire - turns on but then shuts off with movement- then on again
THIS HAPPENS WHEN THERE IS A SHORT CIRCUIT OR THE POWER CORD IS DAMAGED.A REPLACEMENT WILL SOLVE THE PROBLEM.
Regards.
DON'T FORGET TO RATE MY SUGGESTION
Jul 06, 2011 | Black & Decker D2030 Iron
I have a Light N Easy iron that I got with points at a Save-On grocery store in September 2010. Today the iron failed to heat when I turned it on.
Check the plug and wire connected inside the iron wiring terminal. You need a multi-tester to do the continuity test of the wire. An open wire indicate a no connection, hence the iron will failed to heat.
So if you can do it, do it. But if you can't ask someone who has knowledge in appliance repair and has continuity tester.
Good luck.
Jun 26, 2011 | Black & Decker Irons
I HAVE A BLACK AND DECKER IRON-DIGITAL ADVANTAGE, POWER IN THE IRON GOES ON AND OFF NEED TO KEEP ON HOLDING THE POWER WIRE INTO THE IRON, SO I TRIED TO OPEN THE WIRE SECTION,BUT IT NEED A SPECIAL TOOL TO...
Bring the iron to a Hardware store, ask for a set of tools right for the type of screws (maybe Torx, Security Torx, tri-wing, bristol and others).
Once you can open the iron and access to the cord you may change the power cord. it is easy.
Power goes on & off because the power cord is broken. This failure is very common on irons.
Good luck
Apr 19, 2011 | Black & Decker Steam Xpress AS250 Iron...
Hi, I have a Black & Decker digital Evolution iron. It has worked fine in the past but now when I turn it on to any temp setting it starts flashing #8 and beeping. I have never seen the #8 on it...
Try this cleaning procedure:
Empty the iron's reservoir.
Fill the reservoir halfway with white vinegar.
Set iron to steam setting.
Steam on a cotton rag allowing the vinegar to clean the holes in the soleplate.
If this cannot be performed, or does not work,
at Black & Decker's normal price point, it is simply easier to dispose and purchase new.
Best regards,
Feb 25, 2018 | Black & Decker AS675 Iron
I have a Black and Decker D1650. It fell off the ironing board onto the carpet. Now I get error message OR and it will not heat up.
hello,
what his sign indicate is that there is disconnection of power connection over to the element i.e the heater (heat provider).
what you need to do to fix up this problem is to open (unscrew) it then trace the wire down to the element inside the system it self the element is silver in colour fix up the wire back, to the back of the element then with this the problem of the error message is solve. disconnect all source of power supply to the connected to it .
thank you.
Jun 13, 2010 | Black & Decker Steam Xpress AS250 Iron...
Same Issues with my Black/Decker 2030
change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside.
Aug 19, 2009 | Black & Decker D2030 Iron
Stopped heating
I work for Black & Decker. Any part that someone is telling you to purchase for that iron isn't from Black & Decker. Their irons are no designed to be repaired. If the iron is no longer heating, it needs to be replaced. Please call our customer service department at 800-231-9786 so that we may determine your warranty status.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 20, 2009 | Black & Decker D2030 Iron
Black & Decker model D1600 iron error message
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the unit isn't heating anymore, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you any way we can.
Please let me know if I can be of further assistance.
Apr 27, 2009 | Black & Decker ICR200 Iron with Auto...
Does anyone know how to open a Black and Decker digital advantage iron? - I suspect a loose connection where the power cord attaches to the iron and have taken the two screws out of the back plate but the...
I think I have the solution now!
First of all, remove the temperature knob. Than remove the temperature indicator (it's like a little disc). Theres a hidden screw under the temperature indicator! Remove that screw and continue with your fixes.
I hope it could help you.
Jardel
p.s. - Sorry for my noob english...
Sep 21, 2008 | Black & Decker D2030 Iron
Black 7 Decker Steam Express AS250 Iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Oct 31, 2007 | Black & Decker Steam Xpress AS250 Iron...
Black & Decker D2030 Iron Logo
527 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
