Question about Clevo Ultimate Plus 2820 (CFDA0000U1KP32) PC Notebook
Screen white Hello, I have one laptop compaq notebook 100 and not the configuration of switch 1, 2 and 3. Laptop does not ignite the screen is totally white. Thanks.
Hello i have a compaq presario cq61 its booting on white screen and never get in i have tried to remove the power hold the power button for 30-60 sec and reinsert the power again but didnt work .....
sounds like a video chip issue. If you have a computer monitor plug it into your laptop then power the laptop on. If you still get a white screen on the external monitor you have a bad motherboard due to the video chip being bad. If you have video then you have a bad laptop lcd.
May 07, 2011 | Compaq Presario Notebook
I have a Compaq Presario CQ60-420US and about 60% of the screen is now white with colored vertical lines. Compaq tells me I can send it in for hardware repair for $370 which of course would be stupid since...
sounds like you have a bad screen...if you are comfortable taking things apart, you can probably replace pretty easily for less money.
I did a quick search on ebay for Compaq CQ60-204NR screen and there were a bunch, prices varied, but were around $100
Basically a laptop screen only has one connector that is pretty easy to connect....the tricky part is getting to it...you need to remove the bezel and trim to be able to get the screen out of the laptop and then to put the new one in.
Mar 30, 2011 | Compaq Presario CQ60-204NR Notebook
White vertical line on my hp compaq nc8000 monitor
Hi there welcome on fixya.com!
Try another screen and tell me if you still have the line !
Apr 04, 2009 | Compaq NC8000 Notebook
Nx7300 notebook black/white screen
Try the switch across screens: FN + key with screen symbol (F4 or F5?).
You'll be going from your main screen to external monitor to both
Jan 11, 2009 | HP Compaq nx7300 Notebook
No Screen on Notebook Compaq nC8000
Hi Tori1206,
Usually Laptops use the F3 key as toggle for switching from laptop monitor another external monitor. So you might try depressing the F3 key to switch back to the laptop monitor...
--RoadHawk
Nov 20, 2007 | HP Compaq ProLiant ML110 G4 Server
How much will it cost to repair lcd laptop compaq presario 2200
Narvie, The problem you are describing can be caused by a couple of things ranging from a loose connection (< $100) to a faulty component (>$100). If you take it into your local repair shop they should be able to give you a decent estimate before actually working on it. If you work on it yourself you save money on labor, however, you?ll probably spend a lot of time. Compaq used to have a program where you would pay a flat fee, ship them your old laptop and then would ship you a working one. Sorry I couldn?t give you a better answer but without having the laptop in front of me it isn?t possible to give a closer estimate.
Mar 20, 2007 | Compaq Presario 2100T Notebook
Clevo Ultimate Plus 2820 (CFDA0000U1KP32) PC Notebook Logo
91 people viewed this question
Top Clevo Computers & Internet Experts
David Payne
David Payne
Are you a Clevo Computer and Internet Expert? Answer questions, earn points and help others
