Question about Northstar Pressure Washer 3000 PSI
My Northstar Pressure Washer Pump does not boost water pressure
I'm looking for a parts/repair manual for the pump
Pump will power up, but when I attempt to use the wand the motor sounds like it is running on one leg & blows circuit breaker----Ser# 1575551-1101 5160 Model #1575551E
Posted on Dec 01, 2009
Need help in getting Honda engine on NorthStar pressure washer to run.
Could be low water pressure I have found.
Also, I purchased a can of "stuff" at Lowes today which allows you to circulate a liquid substance which lubricates the pressure pump....the pump could be frozen up...
I have a rotating nozzle which I bought...and it had frozen up...this stuff works
Aug 31, 2012 | Northstar Pressure Washer 3000 PSI
We have a leak on the pump around the manafold and the gearbox. Has anyone had this problem that you know of? Could it be that the packing has gone out? The washer is 2 to 3 years old and runs great just...
Usually when water is leaking from in between the manifold and the oil side of the pump, the high and low pressure seals (a.k.a. packings) are worn out.
Dec 17, 2009 | Northstar Pressure Washer 3000 PSI
Model #1578961A. The pump pressure cuts in and
usually caused by a supply problem, make sure you have enough water comming into the pump and that the screen in the connection is clean
Nov 15, 2009 | Northstar Pressure Washer 3000 PSI
The water supply to my pump was disconnected while
Yes the impeller is probably shot. If you can find the parts it should be easy enough.
Aug 02, 2009 | Northstar Garden
Had the Northstar 3000 psi Pressure Washer for 2 months and it started leaking oil from the pump during use. Took it to Northern and they are replacing the pump under warranty but said it was likely...
It is easy to check if your hose and quick connects are supplying enough water to the pump. Your pressure washer gallon per minuite requirements are printed on the machine and also on the pressure tips in GPM. Your post indicates 2.5 gpm but check your documentation of GPM. Next remove the tip from the wand and connect your hose with current quick connects to the machine. Start engine and direct the pressure wand into a bucket for exactly one minute. Measure the amount of water in the bucket, it should be very close to stated gallons. Do the same test with tip installed and compare measurement. If pump is starving for water you will not get proper amount of water in the bucket and the water hose will collapse. Two to four gallons of water per minute is not very demanding and should be delivered even with very small opening. You can even just direct the hose into the bucket for one minute and check how much water your hose is capable of delivering. I believe that you will find no problem with water delivery to pump. I would certainly enlighten Northern with your findings and question their evaluation. When you start using your pressure washer again try using it at lowest pressure to get the job done. Lowering the pressure to about 75% of max will increase the life of the pump and engine. Good luck with you pump
May 08, 2009 | Northstar Pressure Washer 3000 PSI
Foaming in pump oil window
I dont know which comet pump you have, but it is just easier to get a new pump from one of the pressure washer companies on the internet and they sell them on ebay. You can also probably get a better pump that will fit your engine as well. Also, have you tried just changing the oil and not fill it too full? On my 5000 lb washer, if i fill the oil too high when I change the oil, it will foam some. Hope this helps you, Rick
Apr 27, 2009 | Northstar Pressure Washer 3000 PSI
I have NorthStar 2000 psi pressure washer with a
1999 campbell hausfield 1800 psi--2.2gpm. weak pressure at the nozzle. water sprays out, but with the pressure of a garden hose.
Mar 20, 2009 | Garden
Northstar Pressure Washer 3000 PSI Logo
836 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
