Question about D-Link DI 514 Wireless Router (DI-514)
I hooked up a D-link DIR 615 wireless router, and the modem lost internet connection. Also, my laptop foud the D-Link network, and it says it is connected, but it still doesn't get internet. Everything is plugged in correctly, I've checked about 50 times. Why does adding the router make my modem internet light go off?
  • 1 more comment
  • Andrew Nash
    Andrew Nash May 12, 2009
    Same prob, ADSL connection, D-Link modem. I can get the internet running thru the router using its LAN connection but as soon as I pull out the LAN cable I get nothing. The network adapter is not D-Link, so that might be a prob. But I think it should work.
  • 73149 May 15, 2009
    I am having the same problem. any suggestions?
  • 73149 May 11, 2010
    i have AT&T DSL and a motorola modem
    Genius:
  • 1,268 Answers
What is the brand of your modem? Are you on DSL or Cable internet?
Posted on May 11, 2009
  • Michael Galve
    Michael Galve May 16, 2009
    @horsechick
    You need to configure PPPoE on your router's setup page
    @kingwally
    You need to configure the wireless settings on your laptop. Right-click on the wireless connection icon on the bottom right hand and click on view wireless networks or connect to a network. Select the signal from your router and connect. If it asked you for a network key, you must enter the router's wireless network key or WEP key. That should do it. Otherwise, the wireless capability of your laptop is turned off, you must turn it on using the wifi switch on your laptop. Good Luck
Cant connect to d-link DIR-615 wirelessly, can someone help me?
What is the operating system on your laptop?
Can you access the Internet if you connect the computer to the router with the Ethernet cable?
If the wired connection is working then it must be the problem with the wireless network.
If the wired connection is also not working then you may need to reset and reconfigure the router.
If only wireless is not working then you can try creating a new wireless network and then connect your laptop to the new wireless netwok.
I can suggest you a website which may help you for Home network connection.
May 20, 2012 | D-Link DIR-615 Wireless Router
Can't have connection with modem
One of the most common reasons for Internet connection problems is incorrect login information. When your computer locates the network put out by your D-Link wireless router, you will be required to enter login information if the network is secured. The DIR-615 model supports WPA and WPA2 security information; if you can't connect, ensure that you do not have WEP security selected on the network settings
Mar 07, 2012 | D-Link DIR-615 Wireless Router
Can't get internet to work with dir-615 router for more than a day or two at a time
If you have more than one device hooked up to the router, when the problem occurs try pinging another device. If you are able to then the router is working fine and most likely the modem is flaky and needs to be replaced. The modem supplies the internet connection, the router just applies NAT so that more than one device and use your public IP address. If this turns out to be the issue make sure you contact your ISP for any special instructions. For instances Comcast requires the MAC address located on the bottom or back of the modem in order for your connection to work, other ISP use proxy settings. Century Link has no requirements.
Jan 22, 2012 | D-Link DIR-615 Wireless Router
I have a Virgin modem & d link DIR 615 router. I am connected to my desktop via ethernet cable which connects to the internet ok & works fine. I wish to connect my wife & son's laptops...
Hi
while your computer connect to the internet so the connection is good ..
but in other laptops please do that change IP mode to the DHCP Mode or give IP in the same network
try to click repair
Apr 25, 2011 | D-Link DIR-655 Wireless Router
DIR-615 Wireless Router: i have a d-link wireless router dir 615 that i've ...
if youve changed the password on the router since the other computers logged onto the network, then you need to delete the network history from those computers.
Otherwise those laptops will be trying to connect to the network with the old details.
May 16, 2010 | D-Link DIR-615 Wireless Router
I have a dir-615 router and have been able to establish a wireless network but cannot get the network to connect to the internet.what can I do?
I assume you have a cable or a DSL modem connectec by a LAN cable to the wireless router.
Have you checked you with your ISP to see if the connection yo your modem is OK?
Have you check the LAN cable from the modem to the wireless router is good and it in plugged into the WAN/Internet port on the wireless router?
Have you installed the latest wireless card driver in the computer/laptop?
For instructions on setting up the wireless router and the wireless card in the computer/laptop, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance please leave me a comment.
Dec 23, 2009 | D-Link DIR-615 Wireless Router
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
Set up a d-link 615 wireless n router with laptop?
Assuming you have a broadband connection, yes, the D-Link 615 router can be set up to share your internet connection with your laptop. Please consult with your router manual on the proper steps to configure the device. http://www.dlink.com/products/?pid=565
Oct 12, 2009 | D-Link DIR-615 Wireless Router
Using a HN9000 modem and D-Link dir 615 together
change your routers IP address to IP address. 192.168.1.1.
Jun 06, 2009 | D-Link DIR-625 (790069292637) Wireless...
D Link DIR 615 and Acer notbook not talking
Run the windows wizard to setup a network connection from the control panel. Be sure you have the security type and code if you have security enabled on the wireless router.
BXH_5
Jun 17, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DI 514 Wireless Router (DI-514) Logo
491 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
