Question about Epson Stylus Pro 7600 InkJet Printer
Epson Stylus Pro 7600 - Oversize Printing
I am trying to print a document 500 mm wide by 1700 mm long but the printer wont let me select these sizes despite having a full width roll 30 m long loaded! What am I doing wrong?
At the bottom of the paper size drop down menu, select: Manage Custom Size. There you can enter the paper size. Also the maximum length you can print on the 7600 is 90".
Posted on Dec 10, 2009
Select the proper page size in the page setup dialogue box and again in the various print dialogue box sub menus. Also make sure your printer is selected and you are using the correct drivers.
If all of these things are in place you should get a long list of paper types in the pull down menu when you attempt to print.
Posted on Aug 22, 2009
Ink is full but not printing properly
I've had the same problem, and when I checked the dampers one of them was clogged, I flushed it carefully with warm water and it started to work. If u decide to take the print head out to flush it make sure u unplug the machine or u will blow the fuse on the mother board..it will go trough the motions of printing but nothing will print..be careful..
Mar 21, 2013 | Epson Stylus Pro 7600 InkJet Printer
My printer prints well, but with a displayed problem
This indicates that the Pump motor operation count has reached its limit. The remedy is to Perform Maintenance Mode 2 [CLEAR COUNTERS / CLEANER]
Sep 21, 2009 | Epson Stylus Pro 7600 InkJet Printer
Will not print to size
There are "default" paper options that can be set from the epson software you may need to alter these to suit your regular paper size.
Also if you are printing from MS office you can select sizes from there too.
It is better if both are set to the same.
Aug 11, 2009 | Epson Stylus Pro 4000 InkJet Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Lines in print?
It could be that the module unit of the 7600 needs to be replaced. If you don't want to pay for that, you could try cleaning off the wiper blade in the cleaning unit. You can kind of reach that from through the front door, but it is better to remove the side panel. The wiper blade will get ink built up on it, causing it not to clean well.
Also, when doing a cleaning, run it about eight times. After each cleaning, run a nozzle check. This causes the 7600 to do a more thorough cleaning job.
May 12, 2009 | Epson Stylus Pro 7600 InkJet Printer
Printing from InDesign CS3
even if you have the same document size and paper size the printer will not print exactly to edge to edge... so please select scale to fit and check the percentage of scaling if it is more than 95 then your document should look as big as it is desired
Mar 13, 2009 | Epson Stylus Pro 4800 InkJet Printer
Epson Stylus Pro 7600 InkJet Printer Logo
221 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
