Question about Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range
Baking element not working
I have a maytag admiral range purchased in 2005. The baking element snapped in half. Do I just unscrew the two screws in the back and pop the new one in. Does the power need to be turned off at the circuit breaker. Thanks. Alex
  • dyan270 May 12, 2009
    Thank you sirwriter. Alex
  • 323 Answers
Alex, you should turn the breaker off just to be safe. And yep, those two screws come out and the new one goes in, and the two screws go right back in.
Posted on May 12, 2009
Electric range heating elements don't work at all for "bake" function, but "broil" function works (top element) & stovetop works.
The bake (bottom) element has probably burnt out. It's very easy and inexpensive to change them.
First order a new one. Get the range model number and search Google for the element part number. You will get a number of appliance parts suppliers. Check a couple of them for prices and record the part number. (A few suppliers use private part numbers. Most use the manufacturer's part number which will be the one which appears most frequently.)
You could then order from the least expensive supplier, but don't do so. Now search Amazon and eBay for that part number. You will find the part for less than half the price. Order one.
When it arrives, do this:
  1. Unplug the range or make SURE it is turned off.
  2. Remove the old element. It will be held in place with a single Phillips head screw or a hex-head screw. Use the right sized screwdriver or nut driver or socket-wrench as appropriate. The screw will be tight after years of baking. After removing the screw, pull and wiggle the element until it comes unplugged.
  3. Push the new element into the socket and secure it with the screw.
Turn on the oven and let it heat for 5-10 minutes before baking to burn off the bad-smelling coating on the new element.
Mar 02, 2015 | Kitchen Ranges
Bake element for Maytag MER5765RAS did not work. Replaced bake element but Broil and Bake element still do not work but burners do
look inside the breaker box..find the 220 breaker to the range...make sure both sides are in the on possition....if not then only 110 volts are going to the range instead of 220...hope this helps..thanks
Nov 08, 2009 | Maytag MER5765RAS Stainless Steel Electric...
MY STOVE WON'T GET UP TO BAKING HEAT
if it only gets to 160-170 your bake coil has blown
and your preheating on the broil element
Sep 27, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Maytag performa model per4311acw
The oven's element may be defective. Take a look at the heating element and look to see if there are any unusual 'marks' on the element.
It is a simple fix.
Unplug the stove, unscrew the screws holding the element to the back of the stove, gently pull the element a few inches towards you, pop off the connectors, take the element out and take with you to the store. It is a good idea to take the model nukber with yoy when you go to the store.
To replace, just reverse the steps above.
Sep 07, 2009 | Maytag PER5710 Performa Electric Kitchen...
Bake and broil do not work
assuming that the worst case senario has taken place
first thing i would check is ensure i have proper voltage at the outlet, 120 from each side to ground
220 across L1-L2
the elements are the only thing on the range that uses 220v
if you know how to use a mutimeter
you can test both the elements
disconnect the range at teh breaker
take out the screws at the back wall that hold the elements in
pull out about an inch becareful they dont leave much slack on the wires
disconnect on element terminal and apply your leads your looking for continuity, your meter should beep
if not replace the element
if yes, let the element hang ensureing niether terminal touches anything, reconnect the other terminal
now turn the stove on bake if your doing the lower
turn you meter to ac voltage
you should read 220v
anything less than that, your problem is before that
Aug 02, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Heating element does not work in oven
you can unplug the stove and unscrew the bottom heating element and go to a appliance store or home depo and purchase a new one and screw it but on that should solve the problem...
Jul 13, 2009 | Frigidaire GLGF386DC Stainless Steel Gas...
Bottom oven heating element turned white hot and broke in the middle. Can I replace myself?
This is a common problem and easy repair. Locate the model number onside the oven door frame. Purchase the element based on the model number. TURN OFF the power to the oven. Unscrew the 2 screws inside the oven holding the element to the back wall. Gently pull the element forward. The wires will be short.Remove the wires from the broken element. Place them on the new element. Re-insert the element terminals and attach the screws.
TURN ON the power. Bake me some cookies and send them to me.
Jul 05, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Hi, UNPLUG the oven! Remove the screws that hold the element in and pull it toward you. Hopefully they were kind enough to give you plenty of wire to pull it out. Then just unplug old element and plug in new one. Some models have a screws on the element to hold the wire on to it.
I hope this helps.
Please let me kow if I can assist you further.
Thanks
Vic
May 30, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range Logo
131 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
