Recently posted problem and accepted solution from LOCALWONDER
This message is for LOCALWONDER. I recently listed a problem about my 65 inch tv and posted it with wrong model # it was posted with ws65809 but the model # is actually ws65615. You gave me your solution and mentioned a couple of parts I may need which were discontinued. I'm hoping with this correct model # maybe you have some different news for me. I already accepted your solution but didn't realize it was the wrong model #. Hope you can help me. Here's the problem and solution for wrong model#65809---correct # is ws65615
Tv turns off after hitting device or video-audio...posted by waynebaenen on May 06, 2009
can watch 65 inch mitsubishi tv but when I hit the device button to watch a dvd or any other device the tv just goes off after about thirty seconds and then the dreaded green light starts blinking. so basically can watch tv stations but cant watch any devices because turns off when pressing device. Can anyone give me a simple solution?Comment posted on May 06, 2009
my tv is a mitsubishi 65 inch medallion hdtv 1080. my tv will power on fine. I can watch regular tv programs for as long as I want. The problem is when I hit the DEVICE BUTTON on my remote or on tv itself or any AUDIO/VIDEO BUTTON the tv turns off after about 30 seconds and then the green power button blinks. During that 30 seconds I have no control with ANY BUTTONS on the remote or the tv itself. I have to reset it in order to turn the tv back on. In a nutshell, I can use any buttons on remote or tv unit but as soon as I hit the DEVICE OR AUDIO/VIDEO BUTTON I lose all control of any buttons and tv powers off and green power light blinks. Can anyone help, Thank youComment posted on May 06, 2009
tv is not lcd it is digital ready hdmi projection tv about 4 or 5 yrs oldComment posted on May 06, 2009
the tv works fine as long as I dont Hit the DEVICE or VIDEO/AUDIO BUTTONS. I dont always have a blinking green light. It only blinks after hitting DEVICE or AUDIO/VIDEO BUTTONS. I can reset it and it powers on fine and I can use any buttons on remote or tv unit. ITS only when I hit the DEVICE OR AUDIOVIDEO BUTTONS THAT causes green blinking light. can you help thank youComment posted on May 06, 2009
thanks for answering me. do you have a model # for these parts your talking about. I trust that you have done your research but if I could have somekind of part # or something where I could try a desperate search. If discontinued like you say then I will do my crying and go from there. Thanks again, WAYNE
Best Solutionposted on May 06, 2009Asker's Rating
localwonder
Rank: Guru
Rating: 88%, 541 votes
HI, i have some very bad news to relay so please understand that i am simply the messenger at this point.
OK, the issue you are experiencing at this time is due to a major control fault within the main control board inside the TV cabinet. The bad news is, this part has been discontinued and is not available as of January of 07'. There is another part that has been discontinued as well and that is the Convergence assembly.
I have done some additional searching for the main control board and it is defiantly not available. I even tried to find the actual IC chip that is damaged and it is not available as well.
Ok, the first discontinued part that you need at this time is the PW Control main. this has been totally wiped from the system. i tried to retrieve the part numbers from Mitsubishi to no avail. it was wiped in 07'. Now, the Convergence assembly is another discontinued part that i discovered when i was searching for the Main Control board. i have located the part number for this as it was just recently discontinued this year. it is 935D601001.
How do I get David Hill back on Linda DeBoe messenger list on Linda DeBoe Facebook messenger list?
Send a Friend Request to David Hill and once he accepts it you will be able to send your first Facebook Messenger message. When you have done that first message, you will see him in 'Recent Messages' and he will be on your Facebook Friends list and Facebook Messenger list.
Dec 31, 2015 | Facebook Computers & Internet
How do you fix dead pixels on a 65 inch Mitsubishi tv?
most likely if model listed is correct live with it----optical light engine would have to be replaced which is major parts and labor cost.
Aug 26, 2012 | Mitsubishi WD-65731 65" HDTV
FixYa Expert Rating: I wanted to give guru localwonder a 4-thumbs up rating on solving my problem (and any other positives I can!!), but I was never given the chance--just a box appeared to write in my...
It is possible, please post new question and heading / label it as 'For Localwonder Only' so that expert will get it and you can give 4 thumbs rating to him along with comments.
Hope this info will help you.
Thanks.
Jan 07, 2010 | Refrigerators
Toshiba 65" Rear Projection DLP TV
Hi my name is Roety,
I can help you with your issue ,
Most likey you need the Lamp replaced
Use google to buy one using the model #
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 19, 2009 | Toshiba 65HM167 65" Projection Television
Air flow blocked...turning off in a few seconds message
"air flow blocked" means its getting too hot. or it thinks it is. it is quit common on these set that the thermal sensor has malfunction replaceing this sensor is your solution. since this is service bulliteen item at service centers of mitsubidshi products this may be an item covered under warrenty. so i would first check with you local service shop too see before
Jun 04, 2009 | Mitsubishi WD-65731 65" HDTV
Televison & Video Logo
292 people viewed this question
Top Televison & Video Experts
Electro Med Services...
