Question about Hotpoint 23 in. BF50 Built-in Dishwasher
Lower spray arm
The lower spray arm kept jumping off the tube that it fits onto during washing when the water was circulating. I realized it was worn at the point where it fits to the tube. I purchased a new one and fitted it but now during the wash cycle, water sprays out of the machine under the door in waves as the arm spins round. I have studied both the old and new arms and they are identical so cannot understand how this can happen.
Please can you help me.
Regards
Andrew
  • Andrew Tissington Oct 22, 2007
    Brilliant solution, I had not spotted the split before, thanks a lot.
  • Anonymous Mar 25, 2014
    The bottom arm on Blanco BFDW6 Dishwasher falls off during the cycle. I thought the problem was a missing 'milled bush', part number 320 but having ordered and attempted to install this item, it won't fit on the mounting spindle and although it fits snug on the actual arm, when it is fitted, the arm will not snap onto the mounting spindle.
New Spray arm split around center joint so when it gets hot it opens up spraying water under door
take it back for another
Alan
Posted on Oct 22, 2007
Lower spray arm dislodged during wash cycle
Hello Megan Quintas,
I have had the bottoms of the Frigidaire DISHWASHER rotted out AND their center-shaft NEVER LOST IT'S vertical alignment...
So my personal opinion...
You are good once you replace your defective spray arm..
Put your model+make+spray+arm
or better yet the ORIGINAL PART NUMBER to get three estimates...
Good luck, happy hunting!!
- Some example parts houses:
Sears (priciest... but improving)
appliancepartspros.com
partsselect.com
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
May 12, 2016 | Frigidaire Dishwashers
Dirty Dishes
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Sep 28, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Kenmore ultra wash III portable dishwasher. Model #1765991. Lower wash arm came off. How do I re-attach?
Hello. The lower spray arm screws down onto the center, round, plastic part (spinner) that has threads on the center portion. It's very loose and spins easily because it uses the water spray to drive it. At the top of the threads, there will be a flat piece of plastic. Set the spray arm down onto the threads. Hold the flat plastic area that sticks out above the arm with pliers. Spin the spray arm counter-clockwise while holding the spinner. It will thread itself down about a turn or so. Snug firmly--DON'T OVER-TIGHTEN the spray arm onto the spinner. Remember, it only uses water pressure to spin so it doesn't have to be "gorilla tight"! I hope this helps you!
Oct 14, 2015 | Kenmore Dishwashers
GE Profile dishwasher too loud during the washing cycle
It has been my experience that water doesn't damage motors it destroys them! While it is possible I guess I would look and see if there is any kind of drive mechanism between the motor and the arm that could have been damaged. A warped shaft, bearing or bushing or something of that nature.
Mar 09, 2014 | General Electric PDW7880J01SS Dishwasher...
Kitchenaid dishwasher - small pieces of food are left on otherwise clean dishes. Water level comes to about 1 inch below heater coil. I ran it without dishes (or soap) and added about a quart of water so...
hello
contact the Help line
Call 1-800-334-6889
Major Appliances:
8 am - 8 pm EST (Mon - Fri)
Countertop Appliances:
10 am - 5 pm EST (Sat)
KitchenAid Experience® Store
1-888-886-8318
Thank You
Sep 11, 2008 | Dishwashers
Top spray arm not turning
Water-inlet valve
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Note: Dishwashers are usually wired directly to the home's electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you're not sure you've shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
The inlet valve is usually near the front of the dishwasher. Attached to the valve you'll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 7. Label the wires to the valve so you'll be sure to reattach them correctly.
Internal filters
Drain valve
Spray arms
Water temperature
Aug 10, 2011 | Kenmore 49203 Dishwasher
The bottom rack is getting clean. The top rack is not cleaning inside of glasses or dishes no matter what they are made of (plastic, glass, etc). The top & bottom blades are turning but I don't...
Hello there and welcome to fixya
Water-inlet valve
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Internal filters
Drain valve
Spray arms
Water temperature
Aug 10, 2011 | Maytag MDB3100 Dishwasher
Top rack does not wash dishes.
Possible causes of spray arm inefficiency:
Loading large or tall items in the lower basket which stops the arm revolving.
Upper spray arm split along seam.
Upper spray arm blocked.
Under dosing of powder causing foam and reducing upper spray arm water pressure.
Blocked strainers reducing water to circulating pump, therefore reducing upper spray arm water pressure.
inefficient wash motor impellor (faulty)
Dec 21, 2009 | Kenmore Dishwashers
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
Hotpoint 23 in. BF50 Built-in Dishwasher Logo
201 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
