Question about Hotpoint Ultima WF860 Front Load Washer
H2o error on my machine pls helpppp - Hotpoint Ultima WF860 Front Load Washer
  • 34 Answers
Hello 7tulay1,
Remove the lid. Just behind the soap drawer is a round component with a clear tube attached to the bottom of it. A lot of times when you have that error it is because that tube has come off and the vaccuun switch can no longer operate. Hope this helps.
Thanks,
edgin96
Posted on May 12, 2009
Not letting water in,error code h2o.tap on display.making buzzing noise
replace the water control solenoid in the machine for the tap that is in use
Jan 26, 2016 | Washing Machines
INDICATING h2O CONTINEOUSLY draining water
h2o is the chemical symbol for water. But if the water keeps running and does not stop, even when the machine is full it could be the machine has a defect level indicator, or the water lock does not work. When the lock even don't closes what you remove the power the lock is defect.
Mar 24, 2015 | Ariston Technologies Washing Machines
Ariston ARF 105 H2O error!
I had this issue also and it was because I started the machine and had not turned on the water to it. However, it cleared when I unplugged the power cord, waited about ten seconds, then plugged it back in. I guess they need a "reboot" once in awhile, like a computer - at least mine did. Hope this works for you, too.
Nov 05, 2013 | Ariston Technologies Washing Machines
What is F1 failure code on a kenmoore oasis washer
check your owner manual section troubleshooting for error code very important.
Normally this error code can be meansL a) pressure out of range.
or b)eepron error.
or call the factory and get support online via chat or phone for to fix it.
God bless you
Sep 25, 2012 | Kenmore 4.7 cu. ft. High-Efficiency Top...
I have a hotpoint Ultima WT741, and it doesnt stop filling up whilst in use on a wash/spin and says H2O, and then overflows out the top of the washing machine. Whats the matter with it?
If the flow at the inlet valve is good and then the water comes into the system. Now if the WATER LEVEL SENSOR - normally a pressure switch- does not activate at the preset/chosen level to give the signal to the program controller to switch off the INLET VALVE , it will overflow. So the fault is the water level sensor and showing the error H2O.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 22, 2011 | Washing Machines
Tub does not fill, it cycles through to finish no H2O in tub , but on ground. no error code
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 21, 2011 | Washing Machines
After about 10 mins error code H2O is displayed.
the h2o message means the machine isn't getting enough water. check pressure and water intake pipe.
Mar 15, 2009 | Washing Machines
H2o error
I checked everything I posssibly can and ended up booking an engineer who will be here Monday. I'll post what he says and whether or not it's DIY fixable.
Apr 03, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
244 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
