Question about Frigidaire Freezers
Frigidaire LFFU1153DW2 : not working
I have a Frigidaire Model LFFU1153DW2 unit. It's 4 yrs old. Noticed its not working. I turned it off completely and turned it back on. The unit comes on, but don't hear the compressor turning on. I heard some clicking noise around the left of compressor (around defrost timer), so I turned a few clicks on the defrost timer. The compressor comes on. At this time is my unit on defrost timer ? did I turn on the defrost timer manually ? Should I change the defrost timer ? or is it any other issue. Note: My wife had the freezer full, so full that the door will not shut. Is the overload sensor busted ? please help which part I need to replace. thx
...How will I know if the timer is busted ? When I first noticed this issue, my products inside the freezer was all thawed & pretty much at room temperature. So I figured the unit did not come off the defrost cycle. Can you please list some of the check's I need to do to isolate and change the right part. Thanks in advance for your help
  • 1462 Answers
SOURCE: freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Posted on Sep 07, 2008
jumptrout51
  • 3361 Answers
SOURCE: Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Posted on Mar 27, 2009
  • 358 Answers
SOURCE: Frigidaire for Kenmore Freezer-Compressor won't start
Set the thermostat to the coldest and check if there's power to the compresor relay , if yes the relay or the compresor are bad (in this case replace the relay which is the cheaper first step ,but if the compresor still won't start probably is burned out) If there isn't power to the compresor put a jumper wire to the thermostat if the compresor runs replace the thermostat.
Posted on Aug 07, 2009
hiltonjug
  • 612 Answers
SOURCE: Frigidaire Ultrafreeze upright just stopped working
It sounds as if your compressor it's running. This could be a bad compressor, bad capacitor, bad thermostat. See that there are no fans or defrost, it is one of the other. I would start with checking the capacitor. You can replace it with a Supco 3 in 1. It cost around $30.00. Anything else is going to start costing $100.00 and more. If you need a freezer that big, I would have it fixed unless it ends up being the compressor.
Please rate solution
Posted on Sep 05, 2009
  • 288 Answers
SOURCE: My Frigidaire upright freezer is only 4 years old & isn't working
freezers have safety devices to protect themselves. The compressor has an internal overload to keep it from overheating. some have external reset buttons and some do not. either way the cause must be corrected. if the freezer was low on refrigerant you would see signs of oil near the coils, tubing, or compressor. If there is no leak, it overheats when there is airflow restrictions(dirty coils) or a fan has stopped working. only a few screws keep you from seeing all there is to see. If it is clean and the fan is running, then the compressor may just be the culprit
Posted on Nov 27, 2009
Testimonial: "Thanks so much for your advice. Freezer seems to be working after being thoroughly thawed. Fingers are crossed."
I have a Frigidaire FFU17F5HWD upright. I noticed
Reset the circuit breaker. It too maybe a GFI circuit.
Oct 11, 2013 | Frigidaire FFU17F5HW
I have a Frigidaire A Rated Frost free fridge freezer Model FRC150FF 13 months old. I have noticed a build up of ice under the bottom drawer of the freezer compartment in the last few weeks. It is easy...
there is a chance that the drain hole in the back of the freezer is plugged or block and needs to be clean when the unit is defrosting the water is dripping in the cabinet instead of out the drain.
Feb 27, 2011 | Frigidaire Freezers
My deep freeze is running non stop ,i have noticed it this weekend after going to get grociers and now it is kinda packed but i have noticed it running all the time why? what should i do?or look for? it is...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 16, 2010 | Frigidaire 14.1 cu. ft. / 399 liter...
I keep my freezer in my garage, and It is warm out there, but I've noticed that the sides of my freezer is very warm to touch,on sides is this natural. it has been a very good freezer, and is almost 20 yrs...
Most units now use condenser coils hidden inside the walls of the unit verses exposed in the back. If your unit does not have exposed coils or a forced air cooled condenser then they are most likely in the walls which would make what you are describing completely normal. Just make sure you allow 3 to 4 inches of room around them to let the system cool itself.
Jul 08, 2010 | Kenmore Freezers
Frigidaire, chest freezer only 2 or 3 yrs old, was...
See if you have 120 volts at the compressor if you do do you hear any clicking sound at compressor if not replace compressor Start Relay/Overload if you hear clicking sound the compressor may be bad or Start Relay/Overload the only way to know is to replace the compressor Start Relay/Overload. If you do not have 120 volts at the compressor jump out the thermostat you should have 120 volts at the compressor now if not you may have a defrost timer Prob. if this is shelf defrost unit check timer turn knob to see if it starts.
May 19, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Sep 04, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezers Logo
222 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
